Author Topic: What do YOU have running under WINE?  (Read 20748 times)
Offline DiscipleOfDante
  • Sr. Mitglied
  • Branch: Unstable
  • Desktop: Plasma 5
  • GPU Card: Intel HD 4000
  • GPU driver: Free
  • Kernel: linux-ck-x64
  • Skill: Intermediate
Re: What do YOU have running under WINE?
« Reply #15 on: 01. January 2014, 08:14:58 »
TERA Rising, and Amazon Kindle. I can get a ton more games running but I mostly just play TERA and use kindle on wine.
Offline Verändert2.0
  • Held Mitglied
  • Ni Dieu ni maître
  • Skill: Novice
« Reply #16 on: 01. January 2014, 11:03:02 »
Only games (Panzergeneral 3d & AoE II)
Offline 4exNinja
  • Neuling
  • Skill: Novice
« Reply #17 on: 01. January 2014, 21:42:56 »
Metatrader 4...not really a game, but I like to think of it as one sometimes  :P
Works flawlessly with the latest Wine version!
Offline africantreebass
  • Neuling
  • Branch: Stable
  • Desktop: XFCE w/Compiz
  • GPU Card: Geforce GTX 650 ti boost 2gb
  • GPU driver: nonfree
  • Kernel: 3.12 x64
« Reply #18 on: 02. January 2014, 07:01:58 »
Torchlight, Mount & Blade: Warband, Multimedia Fusion 2, RIFT
Tried Rome II Total War, works decently but not well enough but I'm a bit anal these days about performance, I'd rather just use Windows over wine limitations. It's getting ported soon anyway, so I can wait.
Offline Lukimya
  • Held Mitglied
  • Branch: Unstable
  • Desktop: Gnome 3.20x
  • GPU Card: Intel HD4400
  • GPU driver: free
  • Kernel: 4.4.5-1-ARCH
« Reply #19 on: 02. January 2014, 12:28:46 »
actually I only use wine for silverlight. On the game front i am a purist and use only steam games released on linux.
Offline ryanmusante
  • Vollwertiges Mitglied
  • Branch: Stable
  • Desktop: Cinnamon
  • GPU Card: Intel HD4000
  • GPU driver: Free
  • Kernel: 4.1 x64
« Reply #20 on: 06. January 2014, 23:13:58 »
Absolutely I use WINE. Mostly for Netflix in the wine-pipelight package. Until netflix is supported natively, Pipelight is where its at, highly recommend.
Offline Zileene
  • Held Mitglied
  • Branch: Stable
  • Desktop: awesomeWM,Gnome
  • GPU Card: various
  • GPU driver: the one that works
  • Kernel: 4.1
« Reply #21 on: 09. January 2014, 01:07:16 »
Eve Online is usually the first non-native game installed on my systems.  8)
While I may not always have the correct solution, my input could lead you in the right direction...
If you don't know what a command does, then type 'man <command>' or '<command> --help' to find out.
Offline b0f00nmanjaro
  • Neuling
  • Branch: stable
  • Desktop: i3
  • GPU Card: Radeon HD 6770
  • GPU driver: non-free
  • Kernel: linux310-x64
  • Skill: Novice
« Reply #22 on: 09. January 2014, 01:45:53 »
I m not running anything under wine yet. I will try to run Diablo III and Torchlight II. Hope all will run okey.
Offline 4exNinja
  • Neuling
  • Skill: Novice
« Reply #23 on: 09. January 2014, 03:12:24 »
Most...addictive...game...EVER!!
Offline Thom
  • ManjaroBox -- maybe this it is
  • Branch: stable
  • Desktop: manjaroBOX 0.8.9
  • GPU Card: video-nouveau 2012.09.18
  • GPU driver: free
  • Kernel: 3.14.1-MANJARO x86_64
« Reply #24 on: 09. January 2014, 09:11:46 »
Hello Manjaro World,
I run with Wine:
Biet-o-matic
the best to use Ebay
http://www.bid-o-matic.org/hp/
Wave Agent Beta 1.17
good Tool to work on your sound files
http://www.sounddevices.com/products/waveagent/
Better performance and easy install You get with CrossOver  Linux
http://www.codeweavers.com/products/
I run Office 2003, 2007,
Sennheiser Wireless Systems Manager
http://de-de.sennheiser.com/service-support-services-wireless-systems-manager
Wireless Workbench (Version 5.0.5)
http://www.shure.de/supportdownload/downloads/software-drivers/wireless-workbench
thanx Thom
Don´t ask what Manjaro can do for You. Ask what You can do for Manjaro
in the office openSUSE 13.1 LTS KDE now testing manjaroBOX and manjaroNET
Offline Thom
  • Branch: stable
  • GPU driver: free
« Reply #25 on: 09. January 2014, 09:36:57 »
I forgot teamviewer uses wine. This program made it possible to help a friend in the distance.
http://www.teamviewer.com/de/index.aspx
thanx Thom
Offline tun in a cellar
  • Held Mitglied
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Hybrid graphic card (Intel/ATI)
  • GPU driver: free (the discrete card is switched off)
  • Kernel: linux313-x64 (the latest if possible)
  • Skill: Advanced
« Reply #26 on: 09. January 2014, 09:45:09 »
My son plays GuildWars.
I use wine for some Roland applications which monitor my synthesizer keyboard (Juno Di)
Why doing it yourself when manjaro-system can do it for you?
Offline Ayceman
  • Core Team
  • Security Chief :P
  • Branch: stable, unstable
  • Desktop: Xfce
  • GPU Card: GTX780/HD3000/AMD8400
  • GPU driver: Nvidia/Intel/Catalyst
  • Kernel: latest stable+lts (64)
  • Skill: Advanced
« Reply #27 on: 09. January 2014, 10:57:46 »
Game: World of Tanks
Game/Simulator/Sandbox/3DEngine: Space Engine
Offline Warez
  • Mirror Support Team
  • Branch: Stable
  • Desktop: Cinnamon
  • GPU Card: GeForce GT 740M / Intel® HD Graphics 4000
  • Kernel: 4.1.6-3-MANJARO x86_64
« Reply #28 on: 09. January 2014, 12:20:38 »
I used PlayonLinux to set-up League of Legends, all worked ok, but some low fps here and there.
Windows 60fps constant
Manjaro Wine 45fps and drops not constant and unplayable at competitive level.
Dual boot rullez.
  • Neuling
  • Branch: stable
  • Desktop: i3
  • Skill: Novice
« Reply #29 on: 13. January 2014, 19:58:02 »
I run Diablo III :), very pleased with that.
