Author Topic: [Quick Fix] Enable scrolling in Pamac apps in KDE  (Read 7716 times)
Offline FadeMind
  • Support Team
    • gravatar
  • Branch: Arch x86_64
  • Desktop: Plasma 5
  • GPU Card: Intel + NVIDIA
  • GPU driver: Intel + NVIDIA
  • Kernel: linux
  • Skill: Intermediate
« on: 25. November 2013, 20:56:39 »
In default scrolling don't working in any GTK applications. This is bug in oxygen-gtk theme. Solution for now is adding
Code: (sh) [Select]
GDK_CORE_DEVICE_EVENTS=1to command. For Pamac I wrote a simple fix script.
Create the new file fix-pamac.sh in text editor:
Code: [Select]
kate fix-pamac.sh with code:
Code: [Select]
#!/bin/bash
# RUN THIS SCRIPT AS ROOT
# FIX SCROLLING GTK APPS IN KDE (BUG IN OXYGEN-GTK THEME) FOR PAMAC APPS.
sed -i 's/Exec=pamac-updater/Exec=GDK_CORE_DEVICE_EVENTS=1 pamac-updater/' /usr/share/applications/pamac-updater.desktop
sed -i 's/Exec=pamac-manager/Exec=GDK_CORE_DEVICE_EVENTS=1 pamac-manager/' /usr/share/applications/pamac-manager.desktop
sed -i 's/Exec=pamac-tray/Exec=GDK_CORE_DEVICE_EVENTS=1 pamac-tray/' /usr/share/applications/pamac-tray.desktop
sed -i 's/Exec=pamac-install %F/Exec=GDK_CORE_DEVICE_EVENTS=1 pamac-install %F/' /usr/share/applications/pamac-install.desktop
sed -i 's/Exec=pamac-tray/Exec=GDK_CORE_DEVICE_EVENTS=1 pamac-tray/' /etc/xdg/autostart/pamac-tray.desktop
Next run command:
Code: [Select]
sudo bash fix-pamac.sh && killall pamac-trayLaunch pamac-tray by command:
Code: [Select]
GDK_CORE_DEVICE_EVENTS=1 pamac-tray &Close a terminal window.
NOTE: Launch script fixing this issue always after upgrade pamac application.
« Last Edit: 15. December 2013, 10:54:07 by FadeMind »
Offline Techinstein
  • Neuling
  • "Where all Technology Matters."
    • TiTechZone
  • Branch: Stable
  • Desktop: KDE
  • GPU Card: Radeon R9 270 dual-x OC with boost
  • Kernel: Updating w/ rolling release updates
  • Skill: Advanced
Re: [Quick Fix] Enable scrolling in Pamac apps in KDE
« Reply #1 on: 20. May 2014, 19:44:18 »
Code: (sh) [Select]
Code: [Select]
Code: [Select]
#!/bin/bash
Next run command:
Code: [Select]
Code: [Select]
Does scrolling work on 8.9 now with their new themes for GTK applications.
Manjaro Linux <3 <!--Geek inside -->
New #1 blog for all things tech (Check it out click add? :D)
http://TiTechZone.com
Offline spider623
  • Vollwertiges Mitglied
  • Branch: unstable
  • Desktop: xfce, gnome
  • GPU Card: nVidia GTX970[ZOTAC GeForce GTX 970 AMP! Omega Edition]
  • GPU driver: video-nvidia from mhwd
  • Kernel: x86_64 Linux 4.4.0-1-MANJARO
« Reply #2 on: 09. July 2015, 13:51:39 »
how can i make this system wide cause it seems that all gnome apps have scrolling issues
CPU: Intel Core i7-6700K CPU @ 4.2GHz
GPU: GeForce GTX 970
RAM: 0MiB / 15979MiB
