Hi, Guest
Manjaro will automatically will automatically check and notify you of any updates available for your system and installed software applications, in addition to providing the very latest Manjaro-related news.
Can I suggest? It will be helpful to put some basic commands there for newbie to learn. I'm new to Arch-Linux and will appreciate if there is commands like how to install and how to remove softwares. (or I haven't explore the Wiki yet?)
There's a guide on using the pacman-gui for software management: http://wiki.manjaro.org/index.php/Pacman-GUIA terminal-based guide is also available: http://wiki.manjaro.org/index.php/PacmanSome basic terminal-command guides are also on our "to-do" list (in fact, should be up by the end of next week).
