Author Topic: Manjaro 0.8.8 installation Guide for Experienced Users  (Read 15889 times)
Offline eskaini
  • Security Team
  • I eat deleted accounts
  • Skill: Novice
« on: 22. October 2013, 00:10:18 »
New Wiki page on how to use the graphical installer's partitioning abilities: http://wiki.manjaro.org/index.php?title=Graphical_Installation_Guide_for_Experienced_Users_0.8.8
It's been written with the assumption that experienced users know what they are doing. If it is considered too vague or such, then please let me know.
Offline jonathon
  • Core Team
  • Technologist - Teacher - Tea drinker
  • Branch: Unstable
  • Desktop: MATE 1.14
  • GPU Card: Nvidia GTX680M
  • GPU driver: Bumblebee nvidia+intel
  • Kernel: 4.6.0-*-MANJARO x86_64
  • Skill: Advanced
Re: Manjaro 0.8.8 installation Guide for Experienced Users
« Reply #1 on: 22. October 2013, 01:48:15 »
Looks good!
MSI GT70: Core i7-3630QM, 16GB, Nvidia GTX680M, Intel 2230, Manjaro-MATE-amd64-EFI
Lenovo X230: Core i5-3320M, 4GB, Intel HD4000, Intel 6205, Manjaro-MATE-amd64
Dell Studio 1749: Core i5 540, 8GB, ATi HD5650, Intel WLAN, Manjaro-Xfce-amd64
Let's go in the garden; you'll find something waiting.
Offline Robin0800
  • Vollwertiges Mitglied
  • Branch: Stable
  • Desktop: Cinnamon as KDE Dolphin doesn't like my phone or tablet
  • GPU Card: Nvidia gt 520
  • GPU driver: non free
  • Skill: Intermediate
« Reply #2 on: 22. October 2013, 02:43:56 »
One Question can you choose GPT at the partitioning stage if the DVD has not been booted in uefi mode and if you can does it work?
Offline jonathon
  • Core Team
  • Branch: Unstable
  • Skill: Advanced
« Reply #3 on: 22. October 2013, 12:46:19 »
You can do that with the 0.8.7 live-installer - not sure about Thus. If not, it would be a significant regression!
Offline eskaini
  • Security Team
  • Skill: Novice
« Reply #4 on: 22. October 2013, 12:56:49 »
You would - in principal - do this at the stage where you select your partition table type. I left this out of the guide as I don't know if the installer has been tested properly with this. Unfortunately, my onyl UEFI system is also used for development, so I can't use it for testing purposes!
Offline fassil
  • Support Team
  • Branch: stable/unstable
  • Desktop: E19/E20
  • GPU driver: free
  • Kernel: Linux314 & 318
« Reply #5 on: 22. October 2013, 13:23:12 »
Hi all,
With the 8.8pre3, the advanced partition of Thus way doesn't work on my 32 bits machine?
I wipe out more than 5 times the setup-running to find out a solution, & it finished with CLI.
Because of my particular multiboot partitioning with three Os + a data partition ??
"Are you enlightened ?"
Offline eskaini
  • Security Team
  • Skill: Novice
« Reply #6 on: 22. October 2013, 14:00:51 »
Hi all,
CLI? What - if anything - is displayed on the screen? Does it say anything about bootable mediums?
Offline fassil
  • Support Team
  • Desktop: E19/E20
  • GPU driver: free
« Reply #7 on: 22. October 2013, 16:19:07 »
Hi,
Sorry, I say again, differently:
After more than 5 attempts with Thus wich disappeared sudainly in the section name, pwd, ect (& with not working "advanced partitioning" just before, I used "along side other Os"), I finally used the installer Text to put Openbox on my HD.
A +
Offline archiebunker
  • Branch: Stable
  • Desktop: OB, FB, Mate
  • GPU Card: A10/APU/GPU/7670M
  • GPU driver: AMD/ATI OpenSource Graphics
  • Kernel: manjaro-*.*-x86_64
« Reply #8 on: 22. October 2013, 16:22:48 »
".... for Experienced Users".
well, that ain't gonna help, I thought I was an "Experienced User" until I found out, I had no idea what I was doing half the time. -it's the constant "challenge" thats fun.
 But seriously though, thanks for the Guide, so far so good
Offline Lukimya
  • Held Mitglied
  • Branch: Unstable
  • Desktop: Gnome 3.20x
  • GPU Card: Intel HD4400
  • GPU driver: free
  • Kernel: 4.4.5-1-ARCH
« Reply #9 on: 22. October 2013, 18:46:31 »
very nice. I believe to understand it :)
Offline eskaini
  • Security Team
  • Skill: Novice
« Reply #10 on: 22. October 2013, 20:50:20 »
*cough*
Well clearly it's not going to be "advanced" for intermediate and experienced linux users.
In fact, I would be very disappointed if such users didn't stick with the CLI...
Offline eskaini
  • Security Team
  • Skill: Novice
« Reply #11 on: 22. October 2013, 21:09:07 »
Hi,
A +
Ah. If anything like that happens again, please could you run the installer from the terminal:
Code: [Select]
sudo thus
And post the output of the terminal. Phil has done a couple of updates to the installer for the stable release. I used the updated version, so the issue might have been fixed.
Offline jonathon
  • Core Team
  • Branch: Unstable
  • Skill: Advanced
« Reply #12 on: 23. October 2013, 00:33:30 »
Should people be using gksudo for GUI programs, rather than sudo?
Offline eskaini
  • Security Team
  • Skill: Novice
« Reply #13 on: 23. October 2013, 08:06:02 »
Usually, but it doesn't matter in this instance. Running sudo routinely may end up changing file permissions to root, but then Thus gets deleted at the end of the process anyway...
Offline jonathon
  • Core Team
  • Branch: Unstable
  • Skill: Advanced
« Reply #14 on: 23. October 2013, 18:30:33 »
Ah, very true. :)
