Author Topic: Manjaro 0.8.8 Installation Guide for beginners  (Read 17875 times)
Offline eskaini
  • Security Team
  • I eat deleted accounts
  • Skill: Novice
« on: 20. October 2013, 21:37:51 »
Hi Guys,
For those of you thinking about trying out Manjaro for the first time with the next ( 0.8.8 ) release, a new installation guide has been added to our wiki: http://wiki.manjaro.org/index.php?title=Graphical_Installation_Guide_for_Beginners_0.8.8
With our newest installer, getting Manjaro on your computer couldn't be any easier!!!
Offline cumali
  • Support Team
    • http://www.manjaro-tr.org/
  • Branch: stable
  • Desktop: Manjarobox, Xfce
  • GPU Card: ─░ntel
  • GPU driver: free
  • Kernel: Linux38-x86
  • Skill: Novice
Re: Manjaro 0.8.8 Installation Guide for beginners
« Reply #1 on: 20. October 2013, 21:47:26 »
Was a great document. Nice instructive. You were before me this time. Thank you @Carl. ;)
Offline eskaini
  • Security Team
  • Skill: Novice
« Reply #2 on: 20. October 2013, 21:54:59 »
My pleasure!
Offline cumali
  • Support Team
  • Branch: stable
  • GPU Card: ─░ntel
  • GPU driver: free
  • Skill: Novice
« Reply #3 on: 24. October 2013, 15:42:20 »
Manjaro 0.8.8 Installation Guide for beginners (Turkish )  http://manjaro-tr.org/forum/viewtopic.php?f=38&t=647#p4206
Offline poker98face
  • Held Mitglied
  • Open your Source, Open your Mind
  • Branch: stable Arch
  • Desktop: KDE
  • GPU Card: ATI 5470
  • GPU driver: free
  • Kernel: 3.15 Arch
  • Skill: Intermediate
« Reply #4 on: 24. October 2013, 15:53:44 »
Is installer based on Ubiquity   ??? Not in all but.. example:
Also "who are you" and "Choose Your Installation Method" are very similar.
« Last Edit: 24. October 2013, 15:55:35 by poker98face »
PC: Windows 7 Notebook: Arch
Offline jj1two3
  • Neuling
« Reply #5 on: 31. October 2013, 22:23:03 »
Hi Forum,
I really love manjaro linux. I have been using it for a long time. Yesterday I downloaded Manjaro 0.8.8. openbox edition and burned the image to the disk. When I try to boot from the cd it says isolinux 6.02 - ETCD. And thats as far as it goes, it will not boot from the disk. Anyone have any ideas ?
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • GPU driver: non-free
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
« Reply #6 on: 24. November 2013, 19:05:40 »
We fixed the issue with syslinux 6.02 by using syslinux4 for our final images.
Offline jj1two3
  • Neuling
« Reply #7 on: 26. November 2013, 17:35:29 »
Thanks for the reply Phil. I will go grab the latest image.  :)
Offline PH
  • Vollwertiges Mitglied
  • Branch: Stable
  • Desktop: XFCE
  • GPU Card: Intel Corporation
  • GPU driver: Non-Free
  • Kernel: x86_64 Linux 3.18.19-1-MANJARO
« Reply #8 on: 27. November 2013, 13:02:57 »
WOW
Looks really good, just starting to configure now.
Only one issue I had with installation.  Got to setting location from the map, but also had an error, unable to partition drive.
Re-booted and manually partitioned and installed OK
Thanks for a really great release  :)
"Whenever you find yourself on the side of the majority, it's time to pause and reflect."
-Mark Twain
Offline Genuine
  • Neuling
  • Desktop: Openbox
  • Skill: Novice
« Reply #9 on: 28. November 2013, 03:41:51 »
I'm stuck on partiontining on a Mac OSX.  Any tips?
Offline mips
  • Held Mitglied
  • Valkyrja
  • Branch: Testing
  • Desktop: XFCE
  • GPU Card: GTX 960
  • GPU driver: video-nvidia
  • Kernel: 3.16
« Reply #10 on: 28. November 2013, 06:55:10 »
cli installer maybe...
refit installed?
« Last Edit: 28. November 2013, 07:01:51 by mips »
Offline Fnux
  • Neuling
  • Branch: stable
  • Desktop: Cinnamon
  • GPU Card: Asus NVidia 210 silent
  • Kernel: linux 3.9.10-1-MANJARO
  • Skill: Novice
« Reply #11 on: 27. January 2014, 16:07:03 »
Hi all,
An first of all, happy new year.
I just downloaded the Manjaro 0.8.8 Cinnamon 64-bit iso and tried to install it on a VM prior to install it on a real hard drive but I've not been successful, both using the cli or the graphical installer.
Note: I'm using VMware Workstation 9.0.3 on my host Ubuntu 12.04.3 LTS 64-bit.
Of course, I've checked the sha1num prior to perform the install and it's OK.
Further, as said in the manjaro-cinnamon-0.8.8-MUST-READ-BEFORE-INSTALL.txt file, I've used the command:
Code: [Select]
sudo sed -i "s|_desktop_|/bootmnt/manjaro/x86_64/cinnamon-image.sqfs|g" /etc/thus.conf && sudo thus
Then, the problem using the graphical installer is that after responding to all the questions, nothing appends (even waiting for one hour) and the install status bar doesn't move.  ???
Now, the problem using the cli installer is not better. The install process seams to be fine, but at the first boot, I get a grey screen with only a terminal window open, and no desktop.  :-\
So, where am I wrong and what should I do?
TIA for any tip and trick to install this nice distro (I do like Cinnamon). :-*
Before to send the arrow of truth, plunge the head in the honey pot. - Cheyenne worlds.
CM Asus Sabertooth 990FX, AMD 8150FX 8 core@4.2 GHz, RAM 32 Gb, HDD: 2xCrucial SSD 240Gb, 1xWD 3Tb, 1xWD 150Gb, 2xHD17A 1280x1024, 2xDVD/RW-dual, 15 different Nux including Manjaro-64-3.9.10 & Windows 7 & 8: LoL
Offline Lukimya
  • Held Mitglied
  • Branch: Unstable
  • Desktop: Gnome 3.20x
  • GPU Card: Intel HD4400
  • GPU driver: free
  • Kernel: 4.4.5-1-ARCH
« Reply #12 on: 28. January 2014, 14:05:12 »
The NET version guide should be updated. It has mentions about KALU and some other issues that are are irrelevant these days.
Offline dooblem
  • Neuling
    • Libre Things
« Reply #13 on: 08. February 2014, 16:05:05 »
I noticed that after a fresh Manjaro 0.8.8 install, my other OS (Ubuntu) is not detected and do not appear in the Grub menu.
Running 'sudo update-grub' from Manjaro fixes the problem.
Maybe something to fix in the install process ?
Offline klompen
  • Neuling
  • Skill: Novice
« Reply #14 on: 23. February 2014, 08:16:06 »
I have experienced the same problem as reported by FNUX and was hoping to find an answer here. The XFCE version installs just fine on the same PC, but the Cinnamon version starts doing something after responding to the questions (as indicated by disk activity), but then simply stops and the % meter never moves past 0%.
