Author Topic: Yes, you can safely remove UEFI on some systems  (Read 14261 times)
Offline mattnmag
  • Neuling
  • I'm new. Be nice!
  • Branch: ManjaroLinux 15.12 Capella - stable
  • Desktop: Xfce 4.12.3 (Gtk 2.24.28) -
  • GPU Card: Intel Mobile 945GM/GMS 943/940GML
  • GPU driver: Free Driver
  • Kernel: 4.1.15-1
  • Skill: Novice
Re: Yes, you can safely remove UEFI on some systems
« Reply #15 on: 26. December 2015, 04:37:37 »
In the picture with your Security tab - try going into the "I/O Interface Security" setting, and then check to see if there is a "Secure Boot" setting that you can disable.
Our passion for learning ... is our tool for survival.
— Carl Sagan
Offline austino71
  • Neuling
  • I'm new. Be nice!
  • Branch: Stable
  • Desktop: KDE
  • GPU Card: Nvidia 610m
  • Skill: Novice
« Reply #16 on: 26. December 2015, 07:50:43 »
It's not there too
Offline austino71
  • Neuling
  • I'm new. Be nice!
  • Branch: Stable
  • Desktop: KDE
  • Skill: Novice
« Reply #17 on: 26. December 2015, 09:47:15 »
Solved=https://bbs.archlinux.org/viewtopic.php?id=169354
Offline eduardo
  • Sr. Mitglied
  • Branch: testing
  • Desktop: KDE plasma 5
  • GPU Card: Intel HDGraphics 4400 / Nvidia Geforce 960M
  • GPU driver: non-free on nvidia
  • Kernel: linux44, linux45_RC
  • Skill: Novice
« Reply #18 on: 18. January 2016, 05:24:45 »
what does this means? I think the solution I need is there, but I just dont understand what to do, since I dont understand how it can overwrite a file with a different name. Any help will be welcome.
