Author Topic: Manjaro LTS kernel with ck1(BFS)+BFQ patchsets (64bit/32bit/32bit-PAE)  (Read 29301 times)
Offline masolit
  • Vollwertiges Mitglied
  • Branch: stable
  • Desktop: KDE
  • GPU Card: intel-nVidia
  • GPU driver: non-free
  • Kernel: 3.14.20-1-MANJARO
  • Skill: Novice
Re: Manjaro Kernel with ck1(BFS)+BFQ patchsets (incl. binary repo)
« Reply #30 on: 10. September 2013, 16:27:21 »
waiting for 3.11 ... :)
Offline Rob
  • Core Team
  • Alias: Korrode
  • Branch: Unstable
  • Desktop: Xfce+Compiz
  • GPU Card: nVidia GTX560Ti
  • Kernel: linux314 x64
  • Skill: Advanced
« Reply #31 on: 12. September 2013, 15:00:11 »
I'm somewhat conservative with my kernel version choice, generally I wait a little while for any new kernel to prove itself before I move to it myself, and thus before I compile a new ck1bfq kernel (which perhaps doesn't line up with the usual preference of the type of user who runs custom kernels)...
That said, so far the feedback for 3.11 has been very uneventful, which is exactly what we want it to be, so i'm thinking this weekend 3.11 will hit the repo (and also 3.10.11).
« Last Edit: 12. September 2013, 15:08:19 by Korrode »
Offline Arup
  • Sr. Mitglied
  • Branch: unstable
  • Desktop: XFCE
  • GPU Card: nvidia
  • GPU driver: no
  • Kernel: 3.13
  • Skill: Advanced
« Reply #32 on: 25. September 2013, 15:05:59 »
I can tell you 3.11 is a beauty and is rock stable. Intel Pstate works brilliant with my IVB, so does thermald. The system also responds far better as compared to older kernels.
Offline eskaini
  • Security Team
  • I eat deleted accounts
  • Skill: Novice
« Reply #33 on: 01. October 2013, 09:09:28 »
I just came here to say thanks: This kernel is rock-solid while being even more responsive on my systems. I absolutely love it. And i really look forward to 3.11 for my Ati-Laptop.
Offline Rob
  • Core Team
  • Alias: Korrode
  • Branch: Unstable
  • Skill: Advanced
« Reply #34 on: 01. October 2013, 13:32:52 »
64bit 3.11.2 is building now, I'll use it for a few hours and build 32bit and 32bit PAE kernels on it, should be in repo tomorrow.
Offline Rob
  • Core Team
  • Alias: Korrode
  • Branch: Unstable
  • Skill: Advanced
« Reply #35 on: 02. October 2013, 08:53:27 »
3.11 series ck1bfq kernels are up.
3.11 32bit PAE kernel is now also available.
Offline eskaini
  • Security Team
  • Skill: Novice
« Reply #36 on: 02. October 2013, 09:00:05 »
updating now...
Offline Judge_Dredd
  • Neuling
  • Branch: stable
  • Desktop: OpenBox
  • GPU Card: nvidia gtx 670
  • Kernel: linux39-x64
  • Skill: Intermediate
« Reply #37 on: 02. October 2013, 14:50:15 »
Downloaded and have been playing about with it!
A bonus of the 3.11 kernel - my WiiU Gamepad pro  (just the joypad NOT the tv tablet thingy)  now works perfectly in Linux!  The Wii remote also works great aswell now
Thanks for uploading this
Offline eskaini
  • Security Team
  • Skill: Novice
« Reply #38 on: 04. October 2013, 14:12:43 »
Works great for me, thanks !
Offline Rob
  • Core Team
  • Alias: Korrode
  • Branch: Unstable
  • Skill: Advanced
« Reply #39 on: 04. October 2013, 15:26:26 »
what about virtualbox-host-modules ?
Host and guest modules for 64bit 3.11 kernel are now in the repo.
Offline aaditya
  • OpenRC Team
    • My Website
  • Branch: Testing
  • Desktop: Xfce, Openbox
  • GPU Card: Intel HD 4000
  • Kernel: Linux 4.4 x86_64
« Reply #40 on: 04. October 2013, 15:48:09 »
Thanks Korrode :D
Downloading now.
Code: [Select]
sudo pacman -S linux311-ck1bfq linux311-ck1bfq-headers linux311-ck1bfq-virtualbox-host-modules
resolving dependencies...
looking for inter-conflicts...
Packages (3): linux311-ck1bfq-3.11.2-1  linux311-ck1bfq-headers-3.11.2-1
              linux311-ck1bfq-virtualbox-host-modules-4.2.18-0
Total Download Size:    54.01 MiB
Total Installed Size:   109.31 MiB
:: Retrieving packages ...
Offline aaditya
  • OpenRC Team
    • My Website
  • Branch: Testing
« Reply #41 on: 04. October 2013, 16:04:13 »
The kernel works ;)
A small inconsistency :)
Code: [Select]
[2013-10-04 19:25] [ALPM-SCRIPTLET] ===> You must load vboxdrv module before starting VirtualBox:
[2013-10-04 19:25] [ALPM-SCRIPTLET] ===> # modprobe vboxdrv
[2013-10-04 19:26] [PACMAN] installed linux311-ck1bfq-virtualbox-host-modules (4.2.18-0)
But in modules-load.d, /etc/modules-load.d/linux311-ck1bfq-virtualbox-host-modules.conf has been automatically created, which automatically loads the vbox modules at startup :D
Edit-
I think I see it in the normal kernels also. no problem then :)
« Last Edit: 04. October 2013, 16:14:18 by aaditya »
Offline jonathon
  • Core Team
  • Technologist - Teacher - Tea drinker
  • Branch: Unstable
  • Desktop: MATE 1.14
  • GPU Card: Nvidia GTX680M
  • GPU driver: Bumblebee nvidia+intel
  • Kernel: 4.6.0-*-MANJARO x86_64
  • Skill: Advanced
« Reply #42 on: 05. October 2013, 00:49:25 »
I don't suppose this kernel has the Thinkpad SMAPI (tp_smapi) modules included? It's an extra package for the standard Manjaro kernel...
MSI GT70: Core i7-3630QM, 16GB, Nvidia GTX680M, Intel 2230, Manjaro-MATE-amd64-EFI
Lenovo X230: Core i5-3320M, 4GB, Intel HD4000, Intel 6205, Manjaro-MATE-amd64
Dell Studio 1749: Core i5 540, 8GB, ATi HD5650, Intel WLAN, Manjaro-Xfce-amd64
Let's go in the garden; you'll find something waiting.
Offline Rob
  • Core Team
  • Alias: Korrode
  • Branch: Unstable
  • Skill: Advanced
« Reply #43 on: 05. October 2013, 06:11:41 »
There isn't and i'm reluctant to take on too many extramodules to maintain...
However I did quickly make a source package for you (for 3.11 kernel), you can do:
Code: [Select]
wget http://www.paradoxcomputers.com.au/manjaro/packages/linux311-ck1bfq-tp_smapi-0.41-1.src.tar.gz
tar -xf linux311-ck1bfq-tp_smapi-0.41-1.src.tar.gz
cd linux311-ck1bfq-tp_smapi
makepkg -csir
and you'll have the modules for linux311-ck1bfq.
Do note that you should keep the linux311-ck1bfq-tp_smapi folder you extracted around so you can re-build the module package when the kernel gets an update (like when I update it from 3.11.2 to 3.11.3 in a few days). When the update comes in and your current modules stop working just open a terminal in that linux311-ck1bfq-tp_smapi folder and do:
Code: [Select]
makepkg -csirf.
Offline anion
  • Neuling
  • Skill: Novice
« Reply #44 on: 06. October 2013, 13:18:55 »
Thank you very much for providing a pae kernel  :D
