Author Topic: Manjaro LTS kernel with ck1(BFS)+BFQ patchsets (64bit/32bit/32bit-PAE)  (Read 31275 times)
Offline masolit
  • Vollwertiges Mitglied
  • Branch: stable
  • Desktop: KDE
  • GPU Card: intel-nVidia
  • GPU driver: non-free
  • Kernel: 3.14.20-1-MANJARO
  • Skill: Novice
Re: Manjaro Kernel with ck1(BFS)+BFQ patchsets (incl. binary repo)
« Reply #15 on: 26. August 2013, 20:38:56 »
what about virtualbox-host-modules ?
Code: [Select]
sudo pacman -S virtualbox virtualbox-host-dkms
sudo dkms install vboxhost/4.2.16
sudo usermod -a -G vboxusers <username>
add a new line for each module to /etc/modules-load.d/virtualbox.conf
Code: [Select]
vboxdrv
vboxnetadp
vboxnetflt
and reboot
love this kernel :)
« Last Edit: 26. August 2013, 20:46:06 by masolit »
Offline Rob
  • Core Team
  • Alias: Korrode
  • Branch: Unstable
  • Desktop: Xfce+Compiz
  • GPU Card: nVidia GTX560Ti
  • Kernel: linux314 x64
  • Skill: Advanced
« Reply #16 on: 27. August 2013, 03:57:40 »
I am an occasional virtualbox user, i just haven't needed a VM yet since installing Manjaro, sometime soon i'll be sure to put pre-built module package in the repo too... but until then anyone can build it (or any module) themselves so long as they have the -headers package is installed, as shown above by masolit. :) Thanks for posting the instructions here. :)
Offline masolit
  • Branch: stable
  • Desktop: KDE
  • Skill: Novice
« Reply #17 on: 28. August 2013, 20:04:02 »
I receive an error message
Code: [Select]
┌─[masolit]─[masolit-alienware]─[~/Desktop]
└──╼ sudo journalctl | grep cgroup
Aug 28 21:20:33 masolit-alienware systemd[1]: Failed to create cgroup cpu:/: No such file or directory
Is it safe to comment out that line?
Code: [Select]
ControlGroup=cpu:/
in /usr/lib/systemd/system/rtkit-daemon.service
Offline masolit
  • Branch: stable
  • Desktop: KDE
  • Skill: Novice
« Reply #18 on: 29. August 2013, 00:30:55 »
and how to install bbswitch
Code: [Select]
yaourt -S bbswitch-dkms ;)
Offline Rob
  • Core Team
  • Alias: Korrode
  • Branch: Unstable
  • Skill: Advanced
« Reply #19 on: 29. August 2013, 05:41:01 »
Code: [Select]
Code: [Select]
ControlGroup=cpu:/
I'm afraid I cannot give you a reliable answer on whether you can safely comment out that line as I don't know exactly the effect it would have on rtkit.
I can tell you that this issue is known about:
https://bugs.freedesktop.org/show_bug.cgi?id=56971
I can tell you that any assertions that it is because something cgroups related is not enabled in the kernel config is not what causes the error, as this kernel has everything enabled that the official Manjaro kernel does.
On a sidenote, I don't actually get this error personally as when I gutted pulse out of my system it included the removal of rtkit, since pulse was the only thing requiring it.
Personally, if i did still have rtkit installed and was getting this error, so long as it's not causing any actual problems with the system, i'd just ignore it for now expecting it will get fixed upstream soon.
« Last Edit: 29. August 2013, 05:43:18 by Korrode »
Offline masolit
  • Branch: stable
  • Desktop: KDE
  • Skill: Novice
« Reply #20 on: 29. August 2013, 10:31:44 »
Ok, thx!  :)
Offline dsngjoe
  • Jr. Mitglied
  • Branch: stable
  • Desktop: Cinnamon
  • GPU Card: 780 GHZ
  • Kernel: Linux311-x64
  • Skill: Intermediate
« Reply #21 on: 31. August 2013, 03:51:29 »
Korrode will this have the patch on the kernel for bbswitch to be working on my nvidia laptop?  Thanks and we appreciate everything you do.
Offline Rob
  • Core Team
  • Alias: Korrode
  • Branch: Unstable
  • Skill: Advanced
« Reply #22 on: 31. August 2013, 05:56:02 »
It doesn't.
Also the commit patch we revert for the 3.9 kernel fails to revert the 3.10 code.
Like how you pointed me to the relevant kernel commit originally, if you find similar information for the 3.10 kernel let me know... but otherwise, you're stuck on the 3.9.11 kernel for now. Lucky it's a good kernel ;p
EDIT: Did Linux 3.4.x bbswitch work for you?
You could always just use the official Manjaro linux34 if it works for you, then you still get continued security updates and bugfixes.
« Last Edit: 31. August 2013, 06:09:54 by Korrode »
Offline Rob
  • Core Team
  • Alias: Korrode
  • Branch: Unstable
  • Skill: Advanced
« Reply #23 on: 31. August 2013, 12:48:56 »
Another idea is to put it to Phil to include the patch with the 3.8.x kernel, which he plans to keep around a bit longer.
EDIT: For that, the modifications to the linux38 PKGBUILD are:
Code: [Select]
--- a/PKGBUILD 2013-08-31 07:10:26.000000000 +1000
+++ b/PKGBUILD 2013-08-31 21:03:57.014343000 +1000
@@ -48,6 +48,7 @@
         "3.8.13.5.patch"
         "3.8.13.6.patch"
         "3.8.13.7.patch"
+        "http://git.kernel.org/cgit/linux/kernel/git/stable/linux-stable.git/patch/?id=b842701f3d800a0fba3cee5ec4163a2356f3aaa5"
 sha256sums=('e070d1bdfbded5676a4f374721c63565f1c969466c5a3e214004a136b583184b'
             'abc523f59e4c7a4c8ccadd7fd3cd03b7ae8788b399040a1c949c4232601cfd5b'
@@ -76,6 +77,7 @@
             '5bf544c716d05fb50dbce2f6705d23e5f46a4afcbda7039781d5d631ed9b89dd'
             'ff6f4e3612e7293ddb11b0693488dbcad1256161e89cdefc445211d0753e1fb2'
             '5bc0d17d70a12a8d535c5e464744e56801a8345625e89650dd3da65941fc2241'
+            '65292cc6568c80b603cefd0c401e24258805f2daf3081eb794c3f4e7aa2195cc'
 ## modules.symboles md5sums
@@ -132,6 +134,9 @@
   patch -Np1 -i "${srcdir}/aufs3-loopback.patch"
   patch -Np1 -i "${srcdir}/aufs3-proc_map.patch"
   patch -Np1 -i "${srcdir}/aufs3-standalone.patch"
+  # ACPI related patch reversion to fix bbswitch for some users
+  patch -Rp1 -i "${srcdir}/?id=b842701f3d800a0fba3cee5ec4163a2356f3aaa5"
   if [ "${CARCH}" = "x86_64" ]; then
     cat "${srcdir}/config.x86_64" > ./.config
« Last Edit: 31. August 2013, 13:07:39 by Korrode »
Offline dsngjoe
  • Jr. Mitglied
  • Branch: stable
  • Desktop: Cinnamon
  • GPU Card: 780 GHZ
« Reply #24 on: 31. August 2013, 17:04:26 »
It doesn't.
3.4 won't even load. I think its due to Haswell.
Let me do some research for 3.10 and let you know if I find anything useful.
Thanks
Offline kremator
  • meh...
  • Branch: unstable
  • Desktop: KDE5
  • GPU Card: m8600GT
  • GPU driver: Nvidia nonfree
  • Kernel: 4.xx
« Reply #25 on: 02. September 2013, 17:50:46 »
any chance to somehow make it more official and be able to use mhwd-kernel command?
Offline Rob
  • Core Team
  • Alias: Korrode
  • Branch: Unstable
  • Skill: Advanced
« Reply #26 on: 05. September 2013, 15:37:33 »
Update: 3.10.10-1-MANJARO-ck1bfq
Not for now, maybe later.
Offline were4994
  • Neuling
  • Branch: stable
  • Desktop: Cinnamon
  • GPU Card: Geforce 8500GT
  • Kernel: linux34, linux39
« Reply #27 on: 07. September 2013, 16:00:33 »
The ck1 and BFQ patchsets combined provide optimisations, including a CPU load scheduler (BFS) and an I/O scheduler (BFQ), each designed with desktop system performance and responsiveness in mind.
Any chance adding the PAE extensions also?
Thanks.
Offline Warez
  • Mirror Support Team
  • Branch: Stable
  • Desktop: Cinnamon
  • GPU Card: GeForce GT 740M / Intel® HD Graphics 4000
  • Kernel: 4.1.6-3-MANJARO x86_64
« Reply #28 on: 07. September 2013, 23:40:43 »
This will be nice to be added to manjaro repo and you mantain it. Contact Phil.
Offline Rob
  • Core Team
  • Alias: Korrode
  • Branch: Unstable
  • Skill: Advanced
« Reply #29 on: 10. September 2013, 08:38:16 »
I'll add another i686 kernel that has PAE enabled soon.
Yeah I've been meaning to contact Phil since he mentioned working with custom kernel packagers, but i've been busy with work recently. Once it settles down I will.
