Author Topic: Improve your browsing experience with Profile-sync-daemon!  (Read 17672 times)
Offline eugen-b
  • Support Team
  • Branch: testing
  • Desktop: LXDE, Fluxbox, JWM, LXQt, bspwm
  • GPU Card: Intel 82945G/GZ
  • GPU driver: free
  • Kernel: 4.5, 4.6
  • Skill: Intermediate
Re: Improve your browsing experience with Profile-sync-daemon!
« Reply #60 on: 05. May 2016, 17:32:21 »
the new commands are
psd p for checking the status
systemctl --user enable psd
systemctl --user start psd
https://wiki.archlinux.org/index.php/Profile-sync-daemon#Start_and_stop_psd
To enable overlayfs you need to edit sudoers as root, visudo doesn't work well, but you can try
Code: [Select]
# visudo -f /etc/sudoersand add
username ALL=(ALL) NOPASSWD: /usr/bin/psd-overlay-helper
MSI Wind Nettop, Intel Atom 230 1.6GHz (64bit), 2GB RAM
DEs: NET-minimal + (LXDE / Fluxbox / JWM); LXQt OpenRC
how to install on btrfs subvolumes
http://manjaro.github.io/donate/
Offline Citroen
  • Held Mitglied
  • Branch: Stable.
  • Desktop: Xfce, what else?
  • GPU Card: Intel Device 22b1
  • GPU driver: free driver
  • Kernel: 4.4LTS- x64
« Reply #61 on: 05. May 2016, 17:45:00 »
I have done what you told me to do, but no luck.
[richard@richard ~]$ systemctl --user enable psd
[richard@richard ~]$ systemctl --user start psd
[richard@richard ~]$ psd p
 This version of psd does not support /etc/psd.conf since it runs as your user.
 Recommend that you remove /etc/psd.conf and run it in systemd's user mode:
   systemd --user <action> psd.service
And visudo says no. ;)
Je kunt vrouwen in twee groepen verdelen… maar ik zou het niet doen.
Herman Finkers.
Offline eugen-b
  • Support Team
  • Branch: testing
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #62 on: 05. May 2016, 17:51:12 »
do you have ~/.config/psd/psd.conf ?
you can use nano as root to edit /etc/sudoers
Offline torvic9
  • Sr. Mitglied
  • Hello world!
  • Branch: stable
« Reply #63 on: 05. May 2016, 18:05:59 »
I started all over again, since FF has been fresh installed, but after installing psd this happens.
$ sudo systemctl enable psd.service psd-resync.service
Failed to execute operation: No such file or directory
I have a psd.conf and filled it with the lines as told in the first post.
PSD has to be started in user mode (no sudo):
Code: [Select]
systemctl enable --user psd.service
Overlay mode doesn't work here, so I just use the normal mode which is fine enough.
« Last Edit: 05. May 2016, 18:15:44 by torvic9 »
i3: i7-5820K | 32 GB | GeForce GTX 960, nvidia | linux44-custom
KDE: i7-920 | 12 GB | GeForce GTS 450, nouveau | linux44
Gnome: Thinkpad X200s | linux41
Offline Citroen
  • Held Mitglied
  • Branch: Stable.
« Reply #64 on: 05. May 2016, 18:07:54 »
Hi Eugen,
Yes, I have a .config/psd/psd.conf, but no browser is commented out, there is a # in front of every one.
I edited etc/sudoers with gedit.
I think I have to remove etc/psd.conf since it seems obsolete?
Edit: I've removed etc/psd.conf and added firefox in .config, and I think I'm getting somewhere.
« Last Edit: 05. May 2016, 18:18:15 by Citroen »
Herman Finkers.
Offline eugen-b
  • Support Team
  • Branch: testing
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #65 on: 05. May 2016, 18:31:59 »
No, don't comment them out, you need a line
BROWSERS="firefox"
Offline Citroen
  • Held Mitglied
  • Branch: Stable.
« Reply #66 on: 05. May 2016, 18:35:01 »
Oh. okay, I did both.  ;D
Herman Finkers.
