Author Topic: Improve your browsing experience with Profile-sync-daemon!  (Read 17661 times)
Offline bloomode
  • Vollwertiges Mitglied
  • Branch: testing
  • Desktop: varies
  • GPU Card: ATI
  • GPU driver: open source
  • Kernel: x86_64 GNU/Linux
  • Skill: Advanced
Re: Improve your browsing experience with Profile-sync-daemon!
« Reply #15 on: 07. October 2013, 03:11:48 »
 @handy ya otta wikify it
end~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                ((((((((([ 'Karma..........  she always waits' ])))))))))
                        https://www.noisebridge.net/
Offline handy
  • Global Moderator
  • Desktop: Openbox 3.6.1-3 & Worker :)
  • GPU Card: intel...
  • GPU driver: open-source
  • Kernel: OpenBSD
  • Skill: Intermediate
« Reply #16 on: 07. October 2013, 09:00:25 »
Why don't you?
The ultimate tyranny in a society is not control
by martial law. It is control by the psychological
manipulation of consciousness, through which reality
is defined so that those who exist within do not even
realize that they are in prison.
  —  Barbara Marciniak
Offline bloomode
  • Branch: testing
  • Desktop: varies
  • GPU Card: ATI
  • Skill: Advanced
« Reply #17 on: 07. October 2013, 11:02:09 »
 well as we speak Im on low power for a few days working on backup
 whilst I put together a new machine but I might take that challenge in
 a few days
Offline handy
  • Global Moderator
  • Kernel: OpenBSD
« Reply #18 on: 07. October 2013, 12:19:08 »
You can practice somewhat with Zim wiki, it gives you a good head start on the job & automatically codes things for you. I've don't have the need to create documents in Zim & then transfer them to the Manjaro wiki, but I think you could, after which you would likely just need to do a little additional formatting to the text (or maybe not).
If you get the page there (one way or another) & need some help, just give me a yell & I can tidy it up for you & also tell you how I did it.
  —  Barbara Marciniak
Offline moumin
  • Branch: stable
  • Desktop: xfce 4.10
  • GPU Card: intel
  • GPU driver: free
  • Kernel: linux312-x64
  • Skill: Novice
« Reply #19 on: 10. October 2013, 03:47:43 »
Tested and looking great so far ;) :)
Offline Ameyuri
  • Neuling
    • Adminstealth
  • Desktop: Xfce
  • Skill: Novice
« Reply #20 on: 12. October 2013, 19:42:57 »
i have a probleme :(
when i use this command
sudo systemctl start psd.service psd-resync.service
it return
Code: [Select]
Job for psd.service failed. See 'systemctl status psd.service' and 'journalctl -xn' for details.and when i
systemctl status psd.service, output:
Code: [Select]
psd.service - Profile-sync-daemon
   Loaded: loaded (/usr/lib/systemd/system/psd.service; enabled)
   Active: failed (Result: exit-code) since Sat 2013-10-12 17:10:26 CET; 15s ago
     Docs: man:psd(1)
           man:profile-sync-daemon(1)
           https://wiki.archlinux.org/index.php/Profile-sync-daemon
  Process: 14843 ExecStart=/usr/bin/profile-sync-daemon sync (code=exited, status=1/FAILURE)
 Main PID: 14843 (code=exited, status=1/FAILURE)
   CGroup: /system/system.slice/psd.service
Oct 12 17:10:26 stealth systemd[1]: Starting Profile-sync-daemon...
Oct 12 17:10:26 stealth systemd[1]: psd.service: main process exited, code=...RE
Oct 12 17:10:26 stealth systemd[1]: Failed to start Profile-sync-daemon.
Oct 12 17:10:26 stealth systemd[1]: Unit psd.service entered failed state.
Hint: Some lines were ellipsized, use -l to show in full.
idk what's the probleme tbh :(
Offline handy
  • Global Moderator
  • Kernel: OpenBSD
« Reply #21 on: 12. October 2013, 21:37:20 »
Had you killed your browser before trying to start the process?
I had to kill mine & restart Openbox before starting psd.
  —  Barbara Marciniak
Offline Ameyuri
  • Neuling
    • Adminstealth
  • Desktop: Xfce
  • Skill: Novice
« Reply #22 on: 12. October 2013, 22:19:49 »
worked, thanks <3
Offline jonathon
  • Core Team
  • Technologist - Teacher - Tea drinker
  • Branch: Unstable
  • Desktop: MATE 1.14
  • GPU Card: Nvidia GTX680M
  • GPU driver: Bumblebee nvidia+intel
  • Kernel: 4.6.0-*-MANJARO x86_64
  • Skill: Advanced
« Reply #23 on: 12. October 2013, 23:04:22 »
Before you set this up, make sure you have a backup of your profile. Don't assume it will be fine.
On my main machine, it looked OK for a while. Then I noticed recursive symlinks appearing in the ~/.mozilla/firefox profile directory and within profiles themselves. Not sure why this was happening. However, the strangeness got worse and profiles started disappearing after reboots.
I can only assume that having a symlinked "nightly" profile between .mozilla/firefox and .mozilla/firefox-trunk was messing things up.
MSI GT70: Core i7-3630QM, 16GB, Nvidia GTX680M, Intel 2230, Manjaro-MATE-amd64-EFI
Lenovo X230: Core i5-3320M, 4GB, Intel HD4000, Intel 6205, Manjaro-MATE-amd64
Dell Studio 1749: Core i5 540, 8GB, ATi HD5650, Intel WLAN, Manjaro-Xfce-amd64
Let's go in the garden; you'll find something waiting.
Offline handy
  • Global Moderator
  • Kernel: OpenBSD
« Reply #24 on: 12. October 2013, 23:10:54 »
It hasn't been causing any problems for me thus far... I'm not doing your "nightly" thing though.
  —  Barbara Marciniak
Offline jonathon
  • Core Team
  • Branch: Unstable
  • Skill: Advanced
« Reply #25 on: 13. October 2013, 01:29:43 »
I'm an edge-case. ;)
Offline bloomode
  • Branch: testing
  • Desktop: varies
  • GPU Card: ATI
  • Skill: Advanced
« Reply #26 on: 13. October 2013, 01:44:45 »
 yeah sometimes firefox likes to stick around when youve closed it
  you can always run $htop  and see whats running and even kill things....relentlessly and slowly.......
Offline Tekx
  • Neuling
  • Is all we see or seem a dream within a dream
  • Branch: testing
  • Desktop: xfce
  • GPU Card: intel 4500hd
  • GPU driver: video-intel 2013.01.12
  • Kernel: 3.10.20
« Reply #27 on: 03. December 2013, 21:04:21 »
Thank you for the daemon. It's working perfectly in Manjaro. Much appreciated!
« Last Edit: 03. December 2013, 21:47:53 by Tekx »
Offline snek
  • Neuling
  • Branch: stable
  • Desktop: XFCE
  • GPU Card: nVidia 6600GT
  • GPU driver: non-free
  • Kernel: linux39-x64
« Reply #28 on: 25. February 2014, 15:39:51 »
Been using this for many months now. Greatly improved my browsing experience on one of my low-power machines!
Offline bokiscout
  • Jr. Mitglied
  • Branch: Stable + AUR
  • Desktop: KDE
  • GPU Card: nVidia GTX 560
  • Kernel: 3.18 LTS
  • Skill: Novice
« Reply #29 on: 30. June 2014, 13:45:24 »
Code: [Select]
# Define where the pid file for psd will reside
#   Arch Linux/Chakra, Debian 7+, Fedora, and Gentoo leave this commented out
#   Debian 6 and below/Mint/Ubuntu use a setting of "/var/run/psd"
#DAEMON_FILE="/run/psd"
I don't understand the last line should be(stay) commented or not?
edit: This daemon will sync only profile or both profile and cache?
« Last Edit: 30. June 2014, 13:51:07 by bokiscout »
Saying that Java is good because it works on every OS is like saying that anal sex is good because it works on every gender.
