Author Topic: Manjaro UEFI - Install Guide  (Read 63993 times)
Offline tint
  • Neuling
  • Branch: stable
  • Desktop: OpenBox
  • GPU Card: amd radeon hd8750m with intel hd4000 hybrid
  • GPU driver: free driver
  • Kernel: linux314-x64
  • Skill: Intermediate
Re: Manjaro UEFI - Install Guide
« Reply #120 on: 09. May 2016, 16:28:14 »
Hello,
when I try to install manjaro on usb, and when I choose default or non free, I have a message:
EFI stub: error: failed to read file
trying to load files to higher adress
Efi is on, secure boot is disabled, strang because I tried an installation with the same computer two years ago and everything was functional.
Any ideas? Thanks
Offline tint
  • Neuling
  • Branch: stable
  • Desktop: OpenBox
« Reply #121 on: 09. May 2016, 18:27:25 »
I've tested with iso of  manjaro-kde-15.12-x86_64 and manjaro-kde-16.06-pre3-x86_64 but I have the same message at the boot (fi stub error failed to load file)
Offline Citroen
  • Held Mitglied
  • Branch: Stable.
  • Desktop: Xfce, what else?
  • GPU Card: Intel Device 22b1
  • Kernel: 4.4LTS- x64
« Reply #122 on: 09. May 2016, 18:48:05 »
I wasn't able to install Xfce a few days ago and had to go legacy, didn't fancy an uefi install either.
Je kunt vrouwen in twee groepen verdelen… maar ik zou het niet doen.
Herman Finkers.
Offline gohlip
  • Held Mitglied
  • Desktop: OpenBox
  • GPU Card: nvidia
  • GPU driver: nonfree
  • Kernel: linux46 - x64
« Reply #123 on: 09. May 2016, 19:52:50 »
Hello,
Any ideas? Thanks
Most likely you mount $esp (that fat32 partition) as /boot.
You should mount it as /boot/efi.
(do not format this $esp if you have existing OS, especially windows)
And device must be gpt partitioned.
See more https://wiki.manjaro.org/index.php?title=UEFI_-_Install_Guide
There is no problem installing Manjaro in uefi.
Life is a sexually transmitted disease with a 100% mortality rate.
