Author Topic: Xfce Whisker Menu  (Read 26938 times)
Offline Ayceman
  • Core Team
  • Security Chief :P
  • Branch: stable, unstable
  • Desktop: Xfce
  • GPU Card: GTX780/HD3000/AMD8400
  • GPU driver: Nvidia/Intel/Catalyst
  • Kernel: latest stable+lts (64)
  • Skill: Advanced
Re: Xfce Whisker Menu
« Reply #15 on: 23. June 2013, 16:10:56 »
thanks for your reply.
what i have done:
-installed the git version from yaourt
-i went to settings --> keyboard --> (keyboard) shortcuts
-there, i added a new item with the command "/usr/bin/xfce4-popup-whiskermenu" and the keyboard shortcut <Alt>F2
the file /usr/bin/xfce4-popup-whiskermenu is really there. i have also tried adding a new item with the command "xfce4-popup-whiskermenu" and the keyboard shortcut <Alt>F2. when i press <Alt>F2, there is nothing happening!
there is also NO other application with the keyboard shortcut <Alt>F2.
what am i doing wrong?
Are you sure there isn't xfrun4 set to altF2? It is on my system.
I just set the menu to Super_L. Also I hope it's put in the menu bar or it might have some issues popping up at the cursor. Have a look at my screenshot.
Phil: can you put a more recent version from git, as it fixes a bug with not reverting to user name if a full name isn't specified and adds the popup in /usr/bin?
« Last Edit: 23. June 2013, 16:15:27 by Ayceman »
Offline excalibur1234
  • Global Moderator
  • Branch: unstable
  • Desktop: net-minimal + LXQt
  • GPU driver: video-nouveau
  • Kernel: 4.6
  • Skill: Intermediate
« Reply #16 on: 23. June 2013, 21:12:31 »
@Ayceman: thanks for your reply.
i have deleted and re-added the whisker menu to my panel after installing the git-version.
i also started a new session (which strangely is not done automatically on my manjaro).
i also deleted and re-added the entry in autostart.
now it works!
it does not feel as natural as synapse yet, but this might change in the future.
Need more information? Search here:   Manjaro Forum   |   Manjaro Wiki   |   Arch Wiki
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • GPU driver: non-free
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #18 on: 27. June 2013, 19:40:39 »
Our community is great. Thx to the close work we have already translated Whisker Menu to 8 different languages. More will come. With xfce4-whiskermenu-plugin-1.0.0.36.g173f099-1 those translations actually work now. Due my help Graeme found the issue why no translations got loaded. You will find it soon in our Testing-Branch with other nice updates.
Offline Ayceman
  • Core Team
  • Security Chief :P
  • Desktop: Xfce
  • Skill: Advanced
« Reply #19 on: 28. June 2013, 12:54:05 »
Nice - looking forward to seeing the latest iteration in the stable repos.
Offline Lukimya
  • Held Mitglied
  • Branch: Unstable
  • Desktop: Gnome 3.20x
  • GPU Card: Intel HD4400
  • GPU driver: free
  • Kernel: 4.4.5-1-ARCH
« Reply #20 on: 01. July 2013, 16:57:32 »
Is this going to replace plank on 0.8.7?
Offline tsw
  • Vollwertiges Mitglied
  • Branch: Stable
  • Desktop: Openbox
  • GPU Card: ATI
  • Kernel: 3.10.7-1
« Reply #21 on: 01. July 2013, 21:36:35 »
Swedish translate - done.
$ pacman -Rds windows &&  pacman -S linux
Offline ringo
  • Held Mitglied
  • www.manjaro-nl.org
    • Manjaro Belgium + forum
  • Branch: unsourced
  • Desktop: xfce
  • GPU Card: Nvidia Geforce 8600 GT (acer 23inch)
  • GPU driver: Free*
  • Kernel: linux kernel
  • Skill: Novice
« Reply #22 on: 01. July 2013, 23:44:11 »
no te preview is just a miniùmalistic iso i think :),  i dont think it replace plank? i dont know :)
Dutch go the dutch site :)
Offline pirateserb
  • Neuling
  • Desktop: KDE
  • GPU Card: AMD Radeon HD 6670
  • Kernel: 3.15.5-1-ARCH
« Reply #23 on: 02. July 2013, 18:15:20 »
Is there a way to make this menu transparent?
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #24 on: 07. July 2013, 00:48:10 »
Ask for it at the development page: http://gottcode.org/xfce4-whiskermenu-plugin/
Offline mkennedy150
  • Sr. Mitglied
  • Branch: Stable
  • Desktop: KDE
  • GPU Card: Intel 4000 HD
  • GPU driver: free
  • Kernel: linux39-x64
« Reply #25 on: 07. July 2013, 01:20:18 »
plank is a dock and whisker is a menu.
Offline ringo
  • Held Mitglied
  • Branch: unsourced
  • Desktop: xfce
  • GPU driver: Free*
  • Skill: Novice
« Reply #26 on: 07. July 2013, 03:49:53 »
sorry i was bit of fuzzy :p
Offline Arch Enemy
  • Neuling
  • Branch: Stable
  • Desktop: Xfce
  • GPU Card: ATI
  • GPU driver: Free
  • Kernel: 3.9 x86
« Reply #27 on: 08. July 2013, 14:43:12 »
Installed today through pacman. A fantastic addition. Thanks!
It would be great to see options for zeitgeist integration and file manager bookmarks in the future. Otherwise, this is perfect.
Offline voger
  • Jr. Mitglied
  • Branch: stable
  • Desktop: KDE
  • Kernel: linux38-x64
« Reply #28 on: 25. August 2013, 13:56:16 »
Is it possible to add custom application launchers to favorites? I have a Windows app that I just dragged and dropped in my wine folder so no automatic icons in the menu. I made a shortcut for it in the Xfce Desktop but I don't like it there. I want it in the menu to keep my desktop tidy.
Nothing to see here...
Offline mips
  • Held Mitglied
  • Valkyrja
  • Branch: Testing
  • Desktop: XFCE
  • GPU Card: GTX 960
  • GPU driver: video-nvidia
  • Kernel: 3.16
« Reply #29 on: 25. August 2013, 14:05:28 »
Create a .desktop file for the app with the correct details and it should work. I've never used whisker but it should work.
http://linuxcritic.wordpress.com/2010/04/07/anatomy-of-a-desktop-file/
http://wiki.xfce.org/howto/customize-menu
http://askubuntu.com/questions/76042/how-can-i-add-items-to-xfce-root-menu
« Last Edit: 25. August 2013, 14:08:02 by mips »
