Author Topic: Xfce Whisker Menu  (Read 27132 times)
Offline cumali
  • Support Team
    • http://www.manjaro-tr.org/
  • Branch: stable
  • Desktop: Manjarobox, Xfce
  • GPU Card: İntel
  • GPU driver: free
  • Kernel: Linux38-x86
  • Skill: Novice
Xfce Whisker Menu
« on: 21. June 2013, 10:06:50 »
Alternate Xfce menu
Whisker Menu is an alternate application launcher for Xfce. When you open it you are shown a list of applications you have marked as favorites. You can browse through all of your installed applications by clicking on the category buttons on the side. Top level catagories make browsing fast, and simple to switch between. Additionally, Whisker Menu keeps a list of the last ten applications that you’ve launched from it. More: http://gottcode.org/xfce4-whiskermenu-plugin/#screenshots
And http://manjaro-tr.org/forum/viewtopic.php?f=39&t=497#p3008
To install the : https://aur.archlinux.org/packages/xfce4-whiskermenu-plugin/
Code: [Select]
$ yaourt -S xfce4-whiskermenu-plugin
Screenshots
Offline ringo
  • Held Mitglied
  • www.manjaro-nl.org
    • Manjaro Belgium + forum
  • Branch: unsourced
  • Desktop: xfce
  • GPU Card: Nvidia Geforce 8600 GT (acer 23inch)
  • GPU driver: Free*
  • Kernel: linux kernel
  • Skill: Novice
Re: Xfce Whisker Menu
« Reply #1 on: 21. June 2013, 10:28:27 »
Thanks for Sharing i hope this will come in Manjaro too :)
Dutch go the dutch site :)
Linuxkartoffel
  • Guest
« Reply #2 on: 21. June 2013, 12:13:22 »
A huge Thank you :P i  think xfce should include this by default as a plugin :P
Like Ringo said Manjaro should include this in the next release, too :P
Offline thung123
  • Neuling
  • Branch: Stable
  • Desktop: Xfce
  • GPU Card: Intel HD Graphics 3000
  • GPU driver: Free
  • Kernel: linux38-x64
  • Skill: Intermediate
« Reply #3 on: 21. June 2013, 14:57:27 »
Thank you for sharing! Finally a menu comes with search option in xfce. Please make this menu as default for the next manjaro release.
Offline excalibur1234
  • Global Moderator
  • Branch: unstable
  • Desktop: net-minimal + LXQt
  • GPU driver: video-nouveau
  • Kernel: 4.6
« Reply #4 on: 21. June 2013, 18:31:21 »
thanks for this information.
i have always looked for a start menu in xfce with proper search function! i will test this!
the standard xfce appfinder did not work for me, because i cannot go to settings without using the mouse or the arrow keys. the window size is alway screwed up as well.
therefore, i have synapse installed right now. it does the job, but i have synapse and the standard xfce start menu installed. i do not need both!
my only concern is, how i can assign the windows key on my keyboard (Super_L) to whisker menu. any ideas?
when you want this to become default in xfce, then go to the xfce forum and write about it. when you do not do this, the xfce people will not know about it!
Need more information? Search here:   Manjaro Forum   |   Manjaro Wiki   |   Arch Wiki
  • Global Moderator
  • Branch: unstable
  • Kernel: 4.6
« Reply #5 on: 21. June 2013, 19:34:14 »
i will switch back to synapse, but i will return to whisker menu from time to time to see whether a couple of changes/additions have been made:
1. easy to setup keyboard shortcut (the Super_L key) or at least some short how-to (i know how to add a custom keyboard shortcut, i just do not know what command and/or directory i have to use to do that)
2. a memory function: currently when you start to enter a couple of letters in the search function, it gives you the search results always in the SAME ORDER. this is not what i want. i want the search results also sorted for how often i klick one search result.
3. when the search results get displayed, i cannot use the arrow keys to select another search result.
when you have figured out how to solve problem 1 or 2, please tell me!
until then, i will continue to use synapse.
« Last Edit: 21. June 2013, 19:36:11 by excalibur1234 »
Offline Ayceman
  • Core Team
  • Security Chief :P
  • Branch: stable, unstable
  • Desktop: Xfce
  • GPU Card: GTX780/HD3000/AMD8400
  • GPU driver: Nvidia/Intel/Catalyst
  • Kernel: latest stable+lts (64)
  • Skill: Advanced
« Reply #6 on: 21. June 2013, 23:18:32 »
Using Xfce's Keyboard settings you can assign any key (ex Super_L) or combo (ex Super_L+Ctrl_L) to any application - the appfinder is xfce4-appfinder
Offline MadmanRB
  • Sr. Mitglied
  • Always thinking, always crazy
  • Branch: Stable
  • Desktop: Cinnamon 2.8.5
  • GPU Card: Intel HD Graphics 4600
  • GPU driver: Free and proprietary, depending on need
  • Kernel: 4.1.13
« Reply #7 on: 21. June 2013, 23:45:52 »
Its nice to see xfce has a menu like this now, as its other menu has sadly become quite antiquated.
Searchbars are a good thing I have to say, especially for new users who dont know much about the OS.
Insanity is only a state of mind
Offline YFDogan
  • Support Team
  • Branch: Stable
  • Desktop: KDE
  • GPU Card: Optimus (GeForce GT 540M)
  • GPU driver: Non-free
  • Kernel: Linux manjaro 3.14.4-1-MANJARO #1 SMP PREEMPT Mon May 19 15:45:30 EST 2014 x86_64 GNU/Linux
  • Skill: Novice
« Reply #8 on: 21. June 2013, 23:50:07 »
Translated to Turkish.
If you want this app in your native language :
https://www.transifex.com/projects/p/xfce4-whiskermenu-plugin/
Manjaro Linux with DELL Insipiron N5110 i7 8GB Ram, Nvidia-Optimus
http://manjaro-tr.org/forum/index.php
Offline Buddha
  • Vollwertiges Mitglied
  • By amending our mistakes, we get wisdom...
  • Branch: stable
  • Desktop: KDE
  • GPU Card: nvidia
  • GPU driver: non-free
  • Kernel: 3.15.6-1-MANJARO #1 SMP
« Reply #9 on: 22. June 2013, 09:56:24 »
I don't currently use XFCE, but if I were, I think I would use this over the default menu for sure.
Buddha
Quote
All philosophies are mental fabrications.
There has never been a single doctrine by which one could enter the true essence of things.
- Nagarjuna
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • GPU driver: nonfree
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #10 on: 22. June 2013, 11:15:38 »
Very good, thank you. I miss open automatically (without clicking) submenus, but it is already very good.
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
  • Global Moderator
  • Branch: unstable
  • Kernel: 4.6
« Reply #11 on: 22. June 2013, 18:51:48 »
when you open the whisker menu it shows you your last used apps or your most frequently used apps. i have not figured this out yet.
when you are looking for something else you can either click the categories and search it there, or you can start typing and the results show up.
i know how i assign a keyboard shortcut to xfce.
what i do NOT know is the command, that has to be executed, when i press the shortcut button in order to open the whisker menu!
so again: i want to assign a keyboard shortcut to the whisker menu. what command do i have to execute to open whisker menu???
Offline Ayceman
  • Core Team
  • Security Chief :P
  • Desktop: Xfce
  • Skill: Advanced
« Reply #12 on: 22. June 2013, 22:18:33 »
Install the git version (xfce4-whiskermenu-plugin-git) and it will be xfce4-popup-whiskermenu in /usr/bin
  • Global Moderator
  • Branch: unstable
  • Kernel: 4.6
« Reply #13 on: 23. June 2013, 03:50:12 »
thanks for your reply.
what i have done:
-installed the git version from yaourt
-i went to settings --> keyboard --> (keyboard) shortcuts
-there, i added a new item with the command "/usr/bin/xfce4-popup-whiskermenu" and the keyboard shortcut <Alt>F2
the file /usr/bin/xfce4-popup-whiskermenu is really there. i have also tried adding a new item with the command "xfce4-popup-whiskermenu" and the keyboard shortcut <Alt>F2. when i press <Alt>F2, there is nothing happening!
there is also NO other application with the keyboard shortcut <Alt>F2.
what am i doing wrong?
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
« Reply #14 on: 23. June 2013, 08:58:46 »
