Author Topic: [How-To] sharing profiles for ManjaroISO  (Read 8498 times)
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • GPU driver: non-free
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
« on: 20. May 2013, 01:55:19 »
If you made a great profile for ManjaroISO and you want to share it with us, it would be best if you tar it up.
Best would be to create a tarball which preserve the symbolic links. To achieve that, call followed cmd:
Code: [Select]
tar -cpvzf profile.tar.gz profile
Replace profile with your profile folder-name.
I will upload my experimental profiles with my images so you guys can rebuild them if needed.
This way the community might give us some great profiles we may adopt to ManjaroISO.
Offline ringo
  • Held Mitglied
  • www.manjaro-nl.org
    • Manjaro Belgium + forum
  • Branch: unsourced
  • Desktop: xfce
  • GPU Card: Nvidia Geforce 8600 GT (acer 23inch)
  • GPU driver: Free*
  • Kernel: linux kernel
  • Skill: Novice
Re: [How-To] sharing profiles for ManjaroISO
« Reply #1 on: 20. May 2013, 01:57:58 »
this is great :D but still need some ending of my own project :)
Dutch go the dutch site :)
Offline eskaini
  • Security Team
  • I eat deleted accounts
  • Skill: Novice
« Reply #2 on: 20. May 2013, 02:07:39 »
Wouldn't it be easier to just upload the key files; packages and packages-kde for example? The rest would be generic configs  surely if released as a 'Manjaro spin'...
Also, thank you very much for being so kind as to share your own tools in this manner. Many devs wouldn't dream of being so gratious.
Offline YFDogan
  • Support Team
    • http://www.manjaro-tr.org/
  • Branch: Stable
  • Desktop: KDE
  • GPU Card: Optimus (GeForce GT 540M)
  • GPU driver: Non-free
  • Kernel: Linux manjaro 3.14.4-1-MANJARO #1 SMP PREEMPT Mon May 19 15:45:30 EST 2014 x86_64 GNU/Linux
  • Skill: Novice
« Reply #3 on: 20. May 2013, 10:51:53 »
I sent you tulliana's kdm and ksplash themes. Can you add them in repos please? ;)
Manjaro Linux with DELL Insipiron N5110 i7 8GB Ram, Nvidia-Optimus
http://manjaro-tr.org/forum/index.php
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #4 on: 20. May 2013, 11:03:36 »
Sure. I'm just looking for the best way to pack them up and even store our sources ...
Offline eskaini
  • Security Team
  • Skill: Novice
« Reply #5 on: 21. May 2013, 00:50:54 »
Ok. What about specific builds, i.e;
x86_64, Intel, no virtualbox modules, no uefi support?
I have in mind an absolute bare-bones spin:
1. As above
2. 0 App's
3. No wallpapers
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #6 on: 21. May 2013, 19:00:44 »
I've to make efi-support on x86_64 optional to archive that. You can remove the pkgs-image which includes the local driver repository as we have done it in our Openbox profile. Also you can checkout my latest profile I did with XFCE to fit on one CD again. This one comes without efi-support and mostly without apps. Everything is possible if you know how to do it.
Offline eskaini
  • Security Team
  • Skill: Novice
« Reply #7 on: 21. May 2013, 22:30:31 »
I do this already...
Method:
Code: [Select]
## efi support
#efilinux-efi
#grub-efi-i386
#grub-efi-x86_64
#gummiboot-efi
#refind-efi
and edit /usr/sbin/buildiso (lines 364 & 365)
Mine has a Dolphin to keep Konsole company only ;)
I was only asking whether you wanted the profile uploaded or is the target audience to narrow?
Thanks
Offline eskaini
  • Security Team
  • Skill: Novice
« Reply #8 on: 22. May 2013, 03:03:42 »
Building 'kde_barebones' here without efi or unnecessary drivers shaves 300Mb from the iso = now 701Mb  8)
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #9 on: 23. May 2013, 17:37:04 »
@stupely: please mail me your changes or link me your zipped archive of your profile. Then I can take a look at it. Sounds interesting.
Offline eskaini
  • Security Team
  • Skill: Novice
« Reply #10 on: 23. May 2013, 22:01:51 »
kde_barebones attached (689Mb build).
Remember that I build with an edited /usr/sbin/buildiso (lines 364 & 365) without efi support.
I look forward to your feedback  :o
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #11 on: 23. May 2013, 22:10:57 »
@stupely: You only modified Packages-KDE and removed efi-support by dashing some lines in manjaroiso scripts. If you download my XFCE-CD Profile you might see, that I also modified the Packages file to get even more free space.
Offline eskaini
  • Security Team
  • Skill: Novice
« Reply #12 on: 23. May 2013, 22:16:30 »
Thanks for the tip. Yesterday I received updates for manjaroiso and a quick look and I didn't see much that changed.
Ah the perils of an untrained eye...
Will recreate a new work dir and reload my existing lists. A good exercise regardless as this will show exactly the space saving.
I was going to quiz you on this next BTW  8)
For now I trust what you have shows you what I'm doing here?
Offline eskaini
  • Security Team
  • Skill: Novice
« Reply #13 on: 23. May 2013, 22:30:31 »
Wow... you managed to cut 43 pkg's? Awesome!
Offline eskaini
  • Security Team
  • Skill: Novice
« Reply #14 on: 23. May 2013, 22:52:30 »
So a fresh build here now is 674Mb... a saving of a further 15Mb. All I did was substitute the xfce package list into my existing dir for this exercise.
Is this all the gains that are to be had at this stage?
