Author Topic: isousb : a graphical tool to copy a Manjaro ISO on an USB key  (Read 21203 times)
Offline eskaini
  • Security Team
  • I eat deleted accounts
  • Skill: Novice
Re: isousb : a graphical tool to copy a Manjaro ISO on an USB key
« Reply #30 on: 23. May 2013, 13:47:34 »
Well, you could send me a pm with information of what you want to change. ;)
Offline handy
  • Global Moderator
  • Desktop: Openbox 3.6.1-3 & Worker :)
  • GPU Card: intel...
  • GPU driver: open-source
  • Kernel: OpenBSD
  • Skill: Intermediate
« Reply #31 on: 23. May 2013, 13:50:38 »
@Esclapion: I may have already fixed that bad link earlier this evening, check it & see?
The ultimate tyranny in a society is not control
by martial law. It is control by the psychological
manipulation of consciousness, through which reality
is defined so that those who exist within do not even
realize that they are in prison.
  —  Barbara Marciniak
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • GPU driver: nonfree
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #32 on: 23. May 2013, 14:05:19 »
Hi,
Thank you both  ;), but my system is not good (I'm not used to uploads).  :(
I would have put a folder containing the two files at the disposal of users, and I can change the content of this folder.
Google Drive, it does not seem possible. I'll try to do with e-nautia.
The links in the first post are not good, but I will not bother Parmaster every time.
Thinking...  ::)
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #33 on: 23. May 2013, 14:20:03 »
OK. The link to the folder containing the two should be THIS.
If you could replace the link in my first message, then it should work.
Thanks by advance.
Offline Linu74
  • Support Team
  • Branch: testing
  • Desktop: i3/XFCE
  • GPU Card: Intel
  • GPU driver: Intel
  • Kernel: linux44-x64
« Reply #34 on: 23. May 2013, 14:26:37 »
Thanks by advance.
For me it works. I'm on G+.
The 2 file's Datet 24. April.
Linu74
Deutscher Manjaro IRC Channel auf Freenode #manjaro-de
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #35 on: 23. May 2013, 14:29:42 »
Thank you for confirmation.  :D
Offline eskaini
  • Security Team
  • Skill: Novice
« Reply #36 on: 23. May 2013, 14:58:50 »
Done. ;)
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #37 on: 23. May 2013, 15:04:33 »
Thanks a lot  :D
Offline dante
  • Vollwertiges Mitglied
  • Branch: testing
  • Desktop: KDE
  • GPU Card: GeForce GTX 275
  • GPU driver: non-free
  • Kernel: Kernel39 SMP x64
« Reply #38 on: 23. May 2013, 16:34:59 »
Do you need hybrid iso's for this tool? I have tried different linux iso but some of them not work - kernel panic during boot. As I see the script using the dd command to write on usb stick. Some distros working other like suse results in kernel panic or grub cannot find the root directory. I've checked the Stick but no errors found. The same problem I have if I write iso's from windows with imagewriter or rufus. Some work other not. Any Idea what exactly the problem is because I've got no errors.
Offline handy
  • Global Moderator
  • Kernel: OpenBSD
« Reply #39 on: 23. May 2013, 16:40:53 »
@Esclapion: I don't use Google, is there another way that I can download your files?
  —  Barbara Marciniak
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #40 on: 23. May 2013, 17:11:11 »
I did not know you must have a Google account for it.  ???
Do you have access here? If so, isous must be renamed isousb apfter download.
« Last Edit: 23. May 2013, 17:13:15 by Esclapion »
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #41 on: 23. May 2013, 17:19:20 »
Quote
Yes, it's made for hybrid ISO. As those of Manjaro, Mint, Suse and (I think) Debian. A lot others also. Not for old Windows Isos.
This tool works also on Wheezy and the distros based upon.
It's a raw copy, without any change in the ISO, and where the USB Key is handled as a raw device.
« Last Edit: 23. May 2013, 17:21:18 by Esclapion »
Offline xcbiker
  • Jr. Mitglied
  • Think Pink!
  • Branch: unstable
  • Desktop: Gnome, Cinnamon
  • GPU Card: Intel
  • GPU driver: free
  • Kernel: 4.1.6-1
  • Skill: Advanced
« Reply #42 on: 23. May 2013, 17:42:38 »
translated in italian. Thanks
Code: [Select]
  it)
M=(
[0]="Selezionare il file ISO da copiare"       # Select the ISO to be copied
[1]="Chiudi isousb"                    # Exit isousb
[2]="Nr"                                # Nr
[3]="Nome"                               # Name
[4]="Dimensioni in GB"                      # Size in Go
[5]="Selezionare il drive USB"        # Select your USB drive
[6]="Verificare che il file non si troppo grande"   # Beware if size is too large
[7]="ATTENZIONE!!!"                   # WARNING ! ! !
[8]="Potrebbe essere un harddisk esterno. \nContinuare ?" # It could be an external hard drive.\nContinue ?
[9]="Problemi con il software, contattare l'autore." # Problem in the tool, contact the author.
[10]="Percentuale eseguito"                 # Percentage done
[11]="Copia di"                         # Copy of
[12]="Si può rimuovere la chiavetta USB" # You can remove the key if you want.
[13]="Copia completata"                  # End of copy
Offline Ayceman
  • Core Team
  • Security Chief :P
  • Branch: stable, unstable
  • Desktop: Xfce
  • GPU Card: GTX780/HD3000/AMD8400
  • GPU driver: Nvidia/Intel/Catalyst
  • Kernel: latest stable+lts (64)
  • Skill: Advanced
« Reply #43 on: 13. November 2013, 03:30:53 »
Don't know if you're still maintaining this tool, but here's a Romanian (ro) translation:
Code: [Select]
M=(
[0]="Alegeți imaginea ISO de copiat"       # Select the ISO to be copied
[1]="Ieșire isousb"                    # Exit isousb
[2]="Nr."                                # Nr
[3]="Nume"                               # Name
[4]="Mărime în GB"                      # Size in Go
[5]="Alegeți stickul"        # Select your USB drive
[6]="Aveți grijă la mărimea stickului"   # Beware if size is too large
[7]="ATENȚIE!!!"                   # WARNING ! ! !
[8]="Ar putea fi un hard extern.\nContinuați?" # It could be an external hard drive.\nContinue ?
[9]="Probleme cu unealta; contactați autorul." # Problem in the tool, contact the author.
[10]="Procent terminat"                 # Percentage done
[11]="Se copiază"                         # Copy of
[12]="Se poate scoate stickul din port" # You can remove the key if you want.
[13]="Copiere terminată"                  # End of copy
And an adjustment of the English (en_US) - remember, the best translation doesn't necessarily have the same structure:
Code: [Select]
M=(
[0]="Select the ISO to be copied"       # Select the ISO to be copied
[1]="Exit isousb"                    # Exit isousb
[2]="No."                                # Nr
[3]="Name"                               # Name
[4]="Size in GB"                      # Size in Go
[5]="Select your USB drive"        # Select your USB drive
[6]="Verify your drive's size"   # Beware if size is too large
[7]="WARNING!!!"                   # WARNING ! ! !
[8]="It could be an external hard drive.\nContinue?" # It could be an external hard drive.\nContinue ?
[9]="Problem with the tool, contact the author." # Problem in the tool, contact the author.
[10]="Percentage done"                 # Percentage done
[11]="Copying"                         # Copy of
[12]="The key is safe to remove." # You can remove the key if you want.
[13]="Finished copying"                  # End of copy
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #44 on: 13. November 2013, 11:35:59 »
Hi Ayceman,
Thanks. I will see if I reopen the maintenance of this tool. For the moment, it works well, with manjaro, Wheezy, usw
« Last Edit: 13. November 2013, 11:44:59 by Esclapion »
