Author Topic: Xrandr cannot recognize proper resolution and refresh rate  (Read 2389 times)
Offline GrandGamer
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
« on: 10. October 2018, 01:47:09 »
I have a 2k 144Hz Samsung FreeSync monitor. When I was using HDMI, I had proper resolution but the Refresh Rate was only 60 Hz. When I switched to DisplayPort (monitor's included cable), xrandr only recognizes up to 1080p60hz.
I use 2 monitors, the second one is a 1080p 60hz monitor. I am on an i7 3930k with AMD RX 460 gpu with AMDGPU driver. Keep in mind that the proper resolution is reported in Xorg logs from the monitor EDID.
Also note that Xubuntu on a live USB sets the proper resolution and refresh rate.
Xorg.0.log https://privatebin.net/?04f5e881e6f86cc9#yy+LjCOy7Y7DSrjHw9/+pxJZXNm/I8cjr6abJRL4Q5I=
xrandr DP output https://privatebin.net/?5d0a495507874cb1#wkxcBXTlsEsQgB6wGlDO3qwpHHkdyvoIrL45X8fob0A=
EDIT: I should also add that in HDMI mode, Manjaro not only doesn't recognize 144Hz but it also recognizes 4k resolution which isn't supported by the monitor.
xrandr HDMI output https://privatebin.net/?267f2760e58824ab#F6DZBCm/CNPoqrCrSx2QTlYjKo88upJ/nCoBtKeSv6I=
« Last Edit: 11. October 2018, 00:39:21 by GrandGamer »
