Author Topic: external Harddrive eSATA doe not spin up  (Read 3743 times)
0 Members and 2 Guests are viewing this topic.
Offline Bienenmann
  • Neuling
  • Skill: Intermediate
« on: 01. April 2018, 12:41:31 »
Hello,
I encounter the following problem:
I attached an eSata harddrive to my PC. The eSATA connector is just a slot braket with eSATA-connectors, no additional controller. Internally, the cables are connected to the normal Sata board connectors.
If I turn the external drive on and start the PC, the disc spins up and is recognized by Manjaro.
If I start the PC and manjaro and THEN swith the drive on, it won't even spin up. If I disconnect the SATA-cable from the disc, it spins up.
Several months ago (about 12-18 Months ;) ) it worked fine. Then I made a complete reinstall of manjaro (changed from HDD to an SSD) and now I cant't get it working again. I did not change any Hardware and I tested several board SATA-connectors.
SATA is set to AHCI in the bios.
Does anyone have an idea?
OS: Linux bienenmann-pc 4.15.13-1-MANJARO #1 SMP PREEMPT Sun Mar 25 19:51:07 UTC 2018 x86_64 GNU/Linux
        [bienenmann@bienenmann-pc ~]$ cat /etc/lsb-release
        DISTRIB_ID=ManjaroLinux
        DISTRIB_RELEASE=17.1.7
        DISTRIB_CODENAME=Hakoila
        DISTRIB_DESCRIPTION="Manjaro Linux"
Window manager Cinnamon
Mainboard: ga-ep43-ds3l
FStab:
# <file system>                            <mount point>                    <type>  <options>               <dump>  <pass>
UUID=fc87e95b-8706-4c6f-82b4-91522abe6ead swap                              swap    defaults,noatime            0       0
UUID=e0d717f2-544d-478d-92d0-3e7f5355ae9c /                                 ext4    defaults,noatime,discard    0       1
UUID=d7a74844-30c0-4802-b174-f678af043a66 /home                             ext4    defaults,noatime            0       2
tmpfs                                     /tmp                              tmpfs   defaults,noatime,mode=1777  0       0
UUID=069AF3471CAC69DB                     /run/media/bienenmann/Musiklager  ntfs-3g rw,noauto,users,exec,nls=utf8,umask=000,gid=bienenmann       0      0
UUID=72e294d1-6ba1-43a0-8c7e-1c46d8ad6b2e /run/media/bienenmann/BackupDrive ext4    defaults,noauto,users   0   0
Regards,
Master of the Bees
Offline throwaway675
  • Neuling
  • Branch: Testing
  • Desktop: Xfce, Mate,
  • Skill: Novice
Re: external Harddrive eSATA doe not spin up
« Reply #1 on: 13. May 2018, 04:27:12 »
Hi,
did you figure it out eventually? I have a very similar problem with my external (esata/usb) enclosure that has worked fine before. When esata is connected the drive wont spin up. USB works fine. I have tested several HDDs, two different cables and two different hosts. I am using Ubuntu but two very different kernels so it shouldn't matter that much anyway.
KR
  • Neuling
  • Branch: Testing
  • Skill: Novice
« Reply #2 on: 13. May 2018, 13:43:55 »
My setup started to work again after getting some sleep... without any evident changes made. And I tried a lot... no idea what happened. I'd guess some loose connection or so? :/
