Author Topic: Manjaro stuck on loading screen  (Read 1273 times)
Offline Superbrainbug
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
« on: 10. April 2017, 23:07:26 »
After major update 02.02. or something like that I couldn't access to manjaro anymore. Today I tried to see where is the problem again and I can't solved it.
So lets start. After I try to boot manjaro he is stucking on loading screen and isn't going anywhere else.
If I try to remove in GRUB last two commands in linux row, adding '3' and rebooting this is kind of error I'm getting:
ERROR: resume hibernation device 'UUID=f5bb-xxxx-xx...' not found
ERROR: device 'UUID=f7dda-xxx-xxxx' not found. Skipping fsck.
ERROR: Unable to find root device 'UUID =f7dda-xxx-...' ,
You are being dropped to a recovery shell
type exit to try and continue booting
sh: can't access tty; job control turned off
[rootfs]#
Also, notice, I can't type anything at all.
