Author Topic: [Help?] Steam libGL errors  (Read 5114 times)
Offline Hafler
  • Neuling
  • I'm new. Be nice!
  • Skill: Intermediate
« on: 31. August 2016, 01:37:59 »
I know what you are thinking: "Not another one of these posts!!" However, please hear me out, I think I simply need some direction.
I have a Dell E6540 running the following (note the hybrid card):
$ uname -a
Linux manjaro 4.7.2-1-MANJARO #1 SMP PREEMPT Sun Aug 21 15:04:37 UTC 2016 x86_64 GNU/Linux
$ inxi -G
Graphics:  Card-1: Intel 4th Gen Core Processor Integrated Graphics Controller
           Card-2: Advanced Micro Devices [AMD/ATI] Mars XTX [Radeon HD 8790M]
           Display Server: X.Org 1.17.4 driver: N/A
           Resolution: 1920x1080@60.05hz, 1920x1080@60.00hz
           GLX Renderer: Mesa DRI Intel Haswell Mobile
           GLX Version: 3.0 Mesa 12.0.1
$ mhwd -li
Installed PCI configs:
                  NAME               VERSION          FREEDRIVER           TYPE
           video-intel            2016.08.22                true            PCI
$ mhwd-gpu --status
Using default
Default lib32 support: true
:: status
  lib32-libGl: '/usr/lib32/mesa/libGL.so.1.2.0'
  lib32-libGLESv1: '/usr/lib32/mesa/libGLESv1_CM.so.1.1.0'
  lib32-libGLESv2: '/usr/lib32/mesa/libGLESv2.so.2.0.0'
  lib32-libEGL: '/usr/lib32/mesa/libEGL.so.1.0.0'
  libGl: '/usr/lib/mesa/libGL.so.1.2.0'
  libGLESv1: '/usr/lib/mesa/libGLESv1_CM.so.1.1.0'
  libGLESv2: '/usr/lib/mesa/libGLESv2.so.2.0.0'
  libEGL: '/usr/lib/mesa/libEGL.so.1.0.0'
  libglx: '/usr/lib/xorg/modules/extensions/libglx.xorg'
  xorg configuration file: '/etc/X11/mhwd.d/intel.conf'
When I attempt to run steam, I get the following:
$ LIBGL_DEBUG=verbose steam
Running Steam on manjarolinux 16.08 64-bit
STEAM_RUNTIME is enabled automatically
Installing breakpad exception handler for appid(steam)/version(1471977975)
libGL: pci id for fd 7: 8086:0416, driver i965
libGL: OpenDriver: trying /usr/lib/xorg/modules/dri//tls/i965_dri.so
libGL: OpenDriver: trying /usr/lib/xorg/modules/dri//i965_dri.so
libGL: dlopen /usr/lib/xorg/modules/dri//i965_dri.so failed (/usr/lib/xorg/modules/dri//i965_dri.so: wrong ELF class: ELFCLASS64)
libGL error: unable to load driver: i965_dri.so
libGL error: driver pointer missing
libGL error: failed to load driver: i965
libGL: OpenDriver: trying /usr/lib/xorg/modules/dri//tls/swrast_dri.so
libGL: OpenDriver: trying /usr/lib/xorg/modules/dri//swrast_dri.so
libGL: dlopen /usr/lib/xorg/modules/dri//swrast_dri.so failed (/usr/lib/xorg/modules/dri//swrast_dri.so: wrong ELF class: ELFCLASS64)
libGL error: unable to load driver: swrast_dri.so
libGL error: failed to load driver: swrast
$ file * | grep ELF | cut -d: -f1 | LD_LIBRARY_PATH=. xargs ldd | grep 'not found' | sort | uniq
    libusb-1.0.so.0 => not found
I did some research via reddit posts and the arch wiki and found that my problem is likely with libgcrypt. I tried a few items I have tried:
    downgrading libgcrypt/lib32-libgcrypt 1.7.1->1.6.5
    $ find ~/.steam/root/ ( -name "libgcc_s.so" -o -name "libstdc++.so" -o -name "libxcb.so" -o -name "libgpg-error.so" ) -print -delete
    LD_PRELOAD='/usr/$LIB/libstdc++.so.6 /usr/$LIB/libgcc_s.so.1 /usr/$LIB/libxcb.so.1 /usr/$LIB/libgpg-error.so' /usr/bin/steam
    $ STEAM_RUNTIME=0 steam
    Adjusting drivers. video-ati/video-catalyst would not let me load into GDM. bumblebee drivers would allow me to get in, but I receive the same error
    installing / reinstalling 32-bit libs
I am not sure where to go from here I see the same issue with anything using 32-bit glx. It seems to be stopping me from starting steam and WINE games:
$ glxinfo32
name of display: :1
X Error of failed request:  GLXBadContext
  Major opcode of failed request:  155 (GLX)
  Minor opcode of failed request:  6 (X_GLXIsDirect)
  Serial number of failed request:  55
  Current serial number in output stream:  54
After some time, I installed attempted to use PRIME instead, but the issue is still occurring on the radeon side.:
I installed xf86-video-ati and xf86-video-intel, then rebooted
$ xrandr --listproviders
Providers: number : 2
Provider 0: id: 0x7e cap: 0xb, Source Output, Sink Output, Sink Offload crtcs: 4 outputs: 8 associated providers: 0 name:Intel
Provider 1: id: 0x52 cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 2 outputs: 1 associated providers: 0 name:OLAND @ pci:0000:01:00.0
$  glxinfo | grep "OpenGL renderer"
OpenGL renderer string: Mesa DRI Intel(R) Haswell Mobile
xrandr --setprovideroffloadsink "OLAND @ pci:0000:01:00.0" Intel
DRI_PRIME=1 glxinfo | grep "OpenGL renderer"
OpenGL renderer string: Gallium 0.4 on AMD OLAND (DRM 2.45.0 / 4.7.2-1-MANJARO, LLVM 3.8.1)
$ DRI_PRIME=1 steam
libGL error: unable to load driver: radeonsi_dri.so
libGL error: failed to load driver: radeonsi
$ DRI_PRIME=1 STEAM_RUNTIME=0 steam
STEAM_RUNTIME is disabled by the user
$ DRI_PRIME=1 STEAM_RUNTIME=0 LD_PRELOAD='/usr/$LIB/libstdc++.so.6 /usr/$LIB/libgcc_s.so.1 /usr/$LIB/libxcb.so.1 /usr/$LIB/libgpg-error.so' steam
It seems like all of the common fixes/workarounds aren't working for me. Could anyone point me in a direction?
Offline handy
  • Global Moderator
  • Desktop: Openbox 3.6.1-3 & Worker :)
  • GPU Card: intel...
  • GPU driver: open-source
  • Kernel: OpenBSD
Re: [Help?] Steam libGL errors
« Reply #1 on: 02. September 2016, 08:19:37 »
hi, you need to post in the official manjaro forum, this forum is considered to be archival (unfortunately) these days.
https://forum.manjaro.org/
The ultimate tyranny in a society is not control
by martial law. It is control by the psychological
manipulation of consciousness, through which reality
is defined so that those who exist within do not even
realize that they are in prison.
  —  Barbara Marciniak
