Author Topic: [SOLVED] no borders at buttons, etc  (Read 1016 times)
0 Members and 2 Guests are viewing this topic.
Offline NaCl
  • Neuling
  • I'm new. Be nice!
  • Desktop: i3
  • Skill: Intermediate
« on: 15. May 2016, 11:12:37 »
Hello Manjaro community,
I have a problem with my desktop PC after I installed manjaro again after an harddisk-crash.
When searching for the iso image of the i3 edition I found the 16-06-rc and downloaded it.
Everything was looking really nice after the installation. I’ve installed the updates and then shut down the PC.
Next time when I started the PC again everything was looking strange:
* there is no scroll-indicator for example when using Firefox.
* the buttons, text-areas etc. do not have borders .
  Even at the login-manager there has this behavior.
  (It’s really difficult to see what is a button and what is simply text ;))
* When I select text at Firefox I don’t see the selection.
  (but coping this text works. It only not visible when selecting)
* The volume selector is not visible.
* etc
I decided going back to the stable i3 edition. But after an update and a reboot I have the behavior with this version, too.
Because I’m not sure if this is maybe a graphic-driver problem or a i3 problem I downloaded lxde and checked if I have the same problems here, too.
But everything looks good with lxde. So it’s looks to me that it is not the graphic-driver.
Do anybody of you have an idea what I can check or do to solve this problem? I added some screenshots and also the output of lshw.
If you need further information I will add it after you described my what I have to execute.
Thanks
NaCl
i3: https://pl.vc/1bdpx
lxde: https://pl.vc/1ikp6
« Last Edit: 15. May 2016, 20:05:48 by NaCl »
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • Desktop: i3, Deepin, Cinnamon
  • GPU Card: Intel ValleyView Gen7
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
Re: no borders at buttons, etc
« Reply #1 on: 15. May 2016, 12:45:23 »
This is certainly a gtk-theme issue.
I see in the screenshot that you are not using the default theme, which was vertex-maia
You appear to have switched to a different one which is not (yet) gtk3.20 compatible.
manjaro is addictive ::)
* manjaro-i3  * manjaro-cinnamon  * manjaro-deepin
Offline NaCl
  • Neuling
  • I'm new. Be nice!
  • Desktop: i3
« Reply #2 on: 15. May 2016, 14:04:15 »
Thanks oberon for the reply.
That theme idea sounds logical to me and would explain a lot.
But I didn't change it. Honestly I don't know how to change it without a search.
So I'm sure I didn't change it (on purpose).
Is there a possibility to look what theme is used right now?
Greetings
NaCl
« Last Edit: 15. May 2016, 14:08:32 by NaCl »
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #3 on: 15. May 2016, 15:16:40 »
You open lxappearance and select vertex-maia-dark and press 'apply' :)
Is this a clean install or do you have some old config in an existing /home partition maybe?
Offline mrbrklyn
  • Vollwertiges Mitglied
  • NYLXS
    • mrbrklyn
  • Desktop: wmaker
  • Skill: Advanced
« Reply #4 on: 15. May 2016, 17:44:10 »
that theme is not in the distro to the repository
Offline NaCl
  • Neuling
  • I'm new. Be nice!
  • Desktop: i3
« Reply #5 on: 15. May 2016, 18:40:31 »
It's a complete new installation. No way that a old config file was used.
Everything was looking fine after the installation. After the update it was broken.
There was no vertex-maia-dark theme to select!
I installed it and as far as I seen it looks fine again.
Perhaps the theme didn't survived the update?
Offline NaCl
  • Neuling
  • I'm new. Be nice!
  • Desktop: i3
« Reply #6 on: 15. May 2016, 20:05:28 »
I've downloaded the dev version and it seems like everything is fine.
Thanks for the support!!
Offline mrbrklyn
  • NYLXS
    • mrbrklyn
  • Desktop: wmaker
  • Skill: Advanced
« Reply #7 on: 15. May 2016, 20:58:12 »
that didn't even work for them.  The GTK theme might have been OK but the
firefox default them, with the little green folder icons, was totally broken as well.
I finally pulled lavafox v2 down.  there aren't many firefox theme choices right
now and the default doesn't work either.
Offline LizziAS
  • Branch: Hyssop
  • Desktop: OB-OpenRC
  • GPU Card: 6520G
  • GPU driver: Catalyst
  • Kernel: Zen
Re: [SOLVED] no borders at buttons, etc
« Reply #8 on: 15. May 2016, 21:12:37 »
Seriously, it is because of stuff like this that i'm starting to dislike gtk a lot  gtk3 Version 3.20.5 breaks the themes that were compatible with gtk3 version 3.20.4 and so on with every point release.
downgrade is also an option but it is a lot easier to switch up the theme.
