Author Topic: 502 Bad Gateway  (Read 2024 times)
Offline lightbeam
  • Sr. Mitglied
  • Branch: Stable as in: "Whoa, Nelly!"
  • Desktop: Wide Openbox
  • GPU Card: AMD Radeon Xpress 200 Series - Methuselah Edition
  • GPU driver: Free as in Lunch
  • Kernel: Linux44, i686
  • Skill: Intermediate
Re: 502 Bad Gateway
« Reply #15 on: 15. May 2016, 08:58:45 »
libbluray-git does not depend on freetype2
therefore
yaourt -S libbluray-git
resolves your dependency for freetype2
thus your update should complete without a hitch afterwards
OK, I guess I made things a little unclear.  My issue has nothing to do with libbluray.  Sorry about that.  My issue is freetype2 conflicting with freetype2-ubuntu, both of which cannot be installed at the same time.  So that means to me that I will have to either use fontconfig and freetype2, or revert to fontconfig-ubuntu and freetype2-ubuntu. But doing either, what else might break?
I make you look good. 8)
Offline lightbeam
  • Sr. Mitglied
Re: 502 Bad Gateway
« Reply #16 on: 15. May 2016, 08:59:57 »
it's 3 am.  goodnight lightbeam
Yep, same here.  Thanks!
Offline LizziAS
  • Vollwertiges Mitglied
  • Branch: Hyssop
  • Desktop: OB-OpenRC
  • GPU Card: 6520G
  • GPU driver: Catalyst
  • Kernel: Zen
Re: 502 Bad Gateway
« Reply #17 on: 15. May 2016, 09:01:45 »
libbluray depends on freetype2 so if you install libbluray-git that doesn't depend on freetype2 the update will not try to install freetype2 nor will it try to uninstall fontconfig-ubuntu or freetyp2-ubuntu
then you can update
Offline LizziAS
  • Branch: Hyssop
  • GPU Card: 6520G
  • Kernel: Zen
Re: 502 Bad Gateway
« Reply #18 on: 15. May 2016, 09:02:33 »
just do it.
Offline LizziAS
  • Branch: Hyssop
  • GPU Card: 6520G
  • Kernel: Zen
Re: 502 Bad Gateway
« Reply #19 on: 15. May 2016, 09:03:57 »
you're welcome
Offline lightbeam
  • Sr. Mitglied
Re: 502 Bad Gateway
« Reply #20 on: 15. May 2016, 09:05:32 »
then you can update
OK, I'll try this...
Offline LizziAS
  • Branch: Hyssop
  • GPU Card: 6520G
  • Kernel: Zen
Re: 502 Bad Gateway
« Reply #21 on: 15. May 2016, 09:14:41 »
after it works for you you can go here:
https://bbs.archlinux.org/viewtopic.php?id=212398
and tell them what you did to solve the issue - and please just leave my involvement out of the equation on their board thanks.
Offline lightbeam
  • Sr. Mitglied
Re: 502 Bad Gateway
« Reply #22 on: 15. May 2016, 10:11:19 »
Mobile Suit Gundam, it worked!  Thank you.  :)  And I will do that.  ;)
Offline LizziAS
  • Branch: Hyssop
  • GPU Card: 6520G
  • Kernel: Zen
Re: 502 Bad Gateway
« Reply #23 on: 15. May 2016, 10:19:25 »
Awesome!  ;-)
