Author Topic: What & Why for Yellow Exclamation in Systemd KCM?  (Read 1332 times)
Offline Orbmiser
  • Sr. Mitglied
  • Photographer / Techy Ole' Fart
  • Branch: Stable
  • Desktop: Netrunner Plasma 5
  • GPU Card: Ati 4350 Dual Displays
  • GPU driver: Free Open Driver
  • Kernel: 4.1.16-1
  • Skill: Novice
« on: 10. May 2016, 18:44:54 »
In System Settings>Advance>Other
Just wondering if someone can clear up why the systemd kcm is showing a yellow exclamation point.
Totally useless unless it gives a reason why? Don't know if I should be concerned about it? Or just ignore?
Thanks!
« Last Edit: 10. May 2016, 18:46:25 by Orbmiser »
Offline conky57
  • Held Mitglied
  • Branch: testing
  • Desktop: KDE Plasma 5.8.4 (16.10 Fringilla) w/OpenRC
  • GPU Card: M92 Ati Mobility Radeon HD 4500 Series
  • GPU driver: free
  • Kernel: 3.18.32-1-MANJARO - x86_64
  • Skill: Novice
Re: What & Why for Yellow Exclamation in Systemd KCM?
« Reply #1 on: 10. May 2016, 20:46:42 »
Thanks!
Maybe it's a warning of impending doom......systemd!
Sorry I couldn't be of help.
Best regards.
Be kind to everyone, because everyone is fighting some sort of battle.
LinuxCounter registered user  #278931
Offline Orbmiser
  • Sr. Mitglied
  • Branch: Stable
  • Kernel: 4.1.16-1
  • Skill: Novice
« Reply #2 on: 10. May 2016, 20:56:16 »
Best regards.
Can't Be! I Refuse to accept the "End is Near"!  :o
Offline conky57
  • Held Mitglied
  • Branch: testing
  • GPU driver: free
  • Skill: Novice
« Reply #3 on: 11. May 2016, 01:31:03 »
"The future's uncertain and the end is always near." --Jim Morrison "Roadhouse Blues"
Best regards.
Edit: Roadhouse Blues.....https://www.youtube.com/watch?v=ldW8jtV2jG0
« Last Edit: 11. May 2016, 02:00:59 by conky57 »
Offline AJSlye
  • Maintainer
  • Netrunner Rolling Edition moderator / maintainer
  • Branch: Stable / Testing / Unstable
  • Desktop: Netrunner Rolling
  • GPU Card: Intel
  • GPU driver: Intel
  • Kernel: 4.4.1-1-MANJARO x86_64 (64 bit)
  • Skill: Guru
« Reply #4 on: 11. May 2016, 03:57:54 »
Not sure, looks like the kwallet and sddm kcm's are also effected by this bug. On my system it's a yellow bubble not an triangle, but that's probably related to the icon set used. I also checked the Netrunner specific changes to system settings and they are not causing the issue. I will look into why this is happening with only certain kcm's
« Last Edit: 11. May 2016, 04:11:06 by AJSlye »
