Author Topic: Search a good USB Wifi stick for Manjaro  (Read 758 times)
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • GPU driver: nonfree
  • Kernel: 4.4.6
  • Skill: Advanced
« on: 10. May 2016, 16:21:18 »
HI,
so, quite sensitive, do not use ndiswrapper. Price or size are not main factors.
Thanks for your ideas.  :)
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
Offline fdc1b
  • Vollwertiges Mitglied
  • I'm less new than yesterday...
  • Branch: Stable
  • Desktop: OpenRC/Plasma 5
  • GPU Card: ATi X1400 mobile
  • GPU driver: xf86 ati
  • Kernel: Usually the last stable
  • Skill: Intermediate
Re: Search a good USB Wifi stick for Manjaro
« Reply #1 on: 11. May 2016, 01:02:48 »
I'm using both RAlink tongle and Realtek dongle. RAlink (rt2800) work fine, no problem and its supported from the standard firmware.
I used also realtek 8192cu dongle, in my opinion it is able to assure better performance and it is more stable, but the standard firmware is buggy and unusable. I used the 8192cu-dkms firmware, from AUR, perfect but starting from the kernel 4.5.2.1 its no longer possible to use this firmware.
This is my cent :)
