Author Topic: Yakuake reset  (Read 2154 times)
Offline hashBits
  • Neuling
  • I'm new. Be nice!
  • Skill: Advanced
Yakuake reset
« on: 09. May 2016, 23:30:46 »
Hey everybody,
I'm a longtime Ubuntu user, but now totally in love with KDE/Manjaro.  I got Yakuake set up, but made the mistake of using the "tabs-only" theme.  Now the menu button is gone and I can't change any Yakuake settings.  Hopefully, I'm just missing something obvious.  Can anyone offer some help?
Many thanks
Offline scachemaille
  • Held Mitglied
  • I'm new. Be nice!
  • Branch: Unstable
  • Desktop: Plasma 5
  • GPU Card: nVidia GT 330M
  • GPU driver: Nouveau
  • Kernel: 4.8_x64
  • Skill: Intermediate
Re: Yakuake reset
« Reply #1 on: 10. May 2016, 01:41:35 »
you can try to edit the file
Code: [Select]
.config/yakuakercto change your theme the time to change the config you want.
I don't know about the theme you talk about. so I can't help you.
if you remove the [Appearance] category it will take the default theme
