Author Topic: Firefox and Desktop Theme  (Read 1621 times)
Offline mrbrklyn
  • Vollwertiges Mitglied
  • NYLXS
    • mrbrklyn
  • Desktop: wmaker
  • Skill: Advanced
« on: 09. May 2016, 22:49:01 »
How do I get the desktop theme that installed with the latest openrc distribution to go away.  The latest firefox upgrade removed firefox-gtk and now has firefox. All my drop downs are now black on black, and my scrollbar is grey on grey, or just invisible It is so frustrating and I can't get any work done.  I need the who configuration to go away.  It needs to go away in gdm, in the filemanagers... everywhere.
Offline jonathon
  • Core Team
  • Technologist - Teacher - Tea drinker
  • Branch: Unstable
  • Desktop: MATE 1.14
  • GPU Card: Nvidia GTX680M
  • GPU driver: Bumblebee nvidia+intel
  • Kernel: 4.6.0-*-MANJARO x86_64
  • Skill: Advanced
Re: Firefox and Desktop Theme
« Reply #1 on: 09. May 2016, 23:04:53 »
It's more likely that your current GTK theme isn't compatible with GTK 3.20. If that's the case you'll need to switch to a different theme until the current one you're using is updated.
MSI GT70: Core i7-3630QM, 16GB, Nvidia GTX680M, Intel 2230, Manjaro-MATE-amd64-EFI
Lenovo X230: Core i5-3320M, 4GB, Intel HD4000, Intel 6205, Manjaro-MATE-amd64
Dell Studio 1749: Core i5 540, 8GB, ATi HD5650, Intel WLAN, Manjaro-Xfce-amd64
Let's go in the garden; you'll find something waiting.
Offline mrbrklyn
  • NYLXS
    • mrbrklyn
  • Desktop: wmaker
  • Skill: Advanced
« Reply #2 on: 09. May 2016, 23:20:58 »
Jon, please give me details..
Offline jonathon
  • Core Team
  • Branch: Unstable
  • Skill: Advanced
« Reply #3 on: 09. May 2016, 23:24:15 »
You probably know WindowMaker better than I do. :)
Offline mrbrklyn
  • NYLXS
    • mrbrklyn
  • Desktop: wmaker
  • Skill: Advanced
« Reply #4 on: 09. May 2016, 23:43:18 »
windowmaker doesn't use gtk
not at all.  It uses WINGS
Offline mrbrklyn
  • NYLXS
    • mrbrklyn
  • Desktop: wmaker
  • Skill: Advanced
« Reply #5 on: 10. May 2016, 00:08:09 »
why would it not work, This is killing my whole days work over the stupid graphics.  How can this happen?
Offline kernelKurtz
  • Neuling
  • Branch: openRC
  • Desktop: Xfce 4.12.3
  • GPU Card: various
  • GPU driver: free
  • Kernel: 4.0.9-1-MANJARO x86_64
  • Skill: Intermediate
« Reply #6 on: 10. May 2016, 01:37:26 »
I feel your pain personally.
I solved it by going through the terminal and typing yaourt numix, yaourt menda, etc. until I had a pile of themes.
What I'm running right now is:
Settings > Appearance = StylishDark-wps
Settings > Window Manager = Numix-Manjaro
Not perfect, but not day-killing either. Hope it helps.
kK
Offline mrbrklyn
  • NYLXS
    • mrbrklyn
  • Desktop: wmaker
  • Skill: Advanced
« Reply #7 on: 10. May 2016, 01:40:19 »
I did that and nearly blew up my whole system like that installing windows mangers and gtk themes.  where did you put those settings?
Offline kernelKurtz
  • Neuling
  • Branch: openRC
  • GPU Card: various
  • GPU driver: free
« Reply #8 on: 10. May 2016, 01:44:31 »
Look for the Settings Manager.
Offline mrbrklyn
  • NYLXS
    • mrbrklyn
  • Desktop: wmaker
  • Skill: Advanced
Offline mrbrklyn
  • NYLXS
    • mrbrklyn
  • Desktop: wmaker
  • Skill: Advanced
« Reply #10 on: 10. May 2016, 01:47:01 »
In firefox?  a settings manager that is not about:config
Offline mrbrklyn
  • NYLXS
    • mrbrklyn
  • Desktop: wmaker
  • Skill: Advanced
« Reply #11 on: 10. May 2016, 02:00:08 »
Kernel?  What application is the settings manager in?
Offline jonathon
  • Core Team
  • Branch: Unstable
  • Skill: Advanced
« Reply #12 on: 10. May 2016, 09:44:24 »
Any application that uses the GTK toolkit will use a GTK theme. You will need to find out where this configuration is read from when you're using WindowManager as your DE - it's probably $HOME/.gtkrc (or similar).
Offline dbVU
  • Jr. Mitglied
  • Branch: stable
  • Desktop: XFCE openrc
  • GPU Card: Nvidia 7800GS
  • GPU driver: free
  • Kernel: 4.4.6-1-MANJARO i686
  • Skill: Novice
« Reply #13 on: 10. May 2016, 13:00:57 »
You can use FirefoxGTK2 from the AUR, that seems to work or try Palemoon which doesn't seem to get messed up when GTK3 gets updated.
db
Offline mrbrklyn
  • NYLXS
    • mrbrklyn
  • Desktop: wmaker
  • Skill: Advanced
« Reply #14 on: 10. May 2016, 21:41:50 »
That last part is wonderful!  thank you
