« Reply #3 on: 09. May 2016, 23:19:53 »
Hm. You might also need to chroot and do a `mkinitcpio -P` (or reinstall the kernel which will trigger the same).
("-P" means "do it for all kernels" so you don't have to worry about which ones are missing).
It's wise to keep a second kernel installed for this reason - or you should be able to do this via the 'fallback' image.
« Last Edit: 09. May 2016, 23:22:03 by jonathon »
Logged
MSI GT70: Core i7-3630QM, 16GB, Nvidia GTX680M, Intel 2230, Manjaro-MATE-amd64-EFI
Lenovo X230: Core i5-3320M, 4GB, Intel HD4000, Intel 6205, Manjaro-MATE-amd64
Dell Studio 1749: Core i5 540, 8GB, ATi HD5650, Intel WLAN, Manjaro-Xfce-amd64
Let's go in the garden; you'll find something waiting.
