Author Topic: Black screen after last Manjaro upgrade, Nvidia  (Read 1361 times)
Offline pher
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
« on: 09. May 2016, 20:29:59 »
Hi
After the last upgrade I get a black screen when I turn on my computer.
I need to set 'nomodeset' in the grub configuration to be able to start in console mode.
Then, if I try to start the gui mode using 'startx' I get this error in the /var/log/Xorg.0.log:
Loading /usr/lib/Xorg/modules/drivers/nvidia_drv.so: invalid ELF header
UnloadModule: "nvidia"
Unloading nvidia
Failed to load module "nvidia" (loader failed, 7)
No drivers available.
« Last Edit: 09. May 2016, 20:31:47 by pher »
Offline jonathon
  • Core Team
  • Technologist - Teacher - Tea drinker
  • Branch: Unstable
  • Desktop: MATE 1.14
  • GPU Card: Nvidia GTX680M
  • GPU driver: Bumblebee nvidia+intel
  • Kernel: 4.6.0-*-MANJARO x86_64
  • Skill: Advanced
Re: Black screen after last Manjaro upgrade, Nvidia
« Reply #1 on: 09. May 2016, 22:51:15 »
What version of the nvidia drivers did you install? Which kernel are you running? What is your hardware (`inxi -Fx`)? What's the output of `file /usr/lib/Xorg/modules/drivers/nvidia_drv.so` ?
I had a similar issue (LightDM failed to start) with an Acer laptop with a 9600M GT running 4.4 and nvidia-340xx - just reinstalling linux44-nvidia-340xx and nvidia340xx-utils (and rebooting) fixed things.
« Last Edit: 09. May 2016, 22:53:30 by jonathon »
MSI GT70: Core i7-3630QM, 16GB, Nvidia GTX680M, Intel 2230, Manjaro-MATE-amd64-EFI
Lenovo X230: Core i5-3320M, 4GB, Intel HD4000, Intel 6205, Manjaro-MATE-amd64
Dell Studio 1749: Core i5 540, 8GB, ATi HD5650, Intel WLAN, Manjaro-Xfce-amd64
Let's go in the garden; you'll find something waiting.
Offline pher
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
« Reply #2 on: 10. May 2016, 11:54:47 »
I installed nvidia and nvidia-utils.
My GPU is :
Code: [Select]
VGA compatible controller: NVIDIA Corporation GK208 [GeForce GT 730] (rev a1)
My kernel:
Code: [Select]
Currently running: 3.18.32-1-MANJARO (linux318)
   * linux310
   * linux318
I can't reinstall nvidia and nvidia-utils using pacman -S nvidia nvidia-utils, output throws so many lines with "file already exist in the filesystem".
I removed the file nvidia_drv.so
inxi -Fx output:
Code: [Select]
[1;34mSystem:   [0;37m [1;34mHost: [0;37m Pher [1;34mKernel: [0;37m 3.18.32-1-MANJARO x86_64 (64 bit [1;34mgcc: [0;37m 5.3.0) [0;37m
[1;34m          [0;37m [1;34mConsole: [0;37m tty 2 [1;34mDistro: [0;37m Manjaro Linux [0;37m
[1;34mMachine:  [0;37m [1;34mMobo: [0;37m ASRock [1;34mmodel: [0;37m Z77 Pro3 [0;37m
[1;34m          [0;37m [1;34mBios: [0;37m American Megatrends [1;34mv: [0;37m P1.40 [1;34mdate: [0;37m 07/05/2012 [0;37m
[1;34mCPU:      [0;37m [1;34mQuad core [0;37m Intel Core i5-3570K (-MCP-) [0;37m [1;34mcache: [0;37m 6144 KB [0;37m
[1;34m          [0;37m [1;34mflags: [0;37m (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) [1;34mbmips: [0;37m 27208 [0;37m
[1;34m          [0;37m [1;34mclock speeds: [0;37m [1;34mmax: [0;37m 3800 MHz [1;34m1: [0;37m 1614 MHz [1;34m2: [0;37m 1613 MHz [1;34m3: [0;37m 1651 MHz [0;37m
[1;34m          [0;37m [1;34m4: [0;37m 1704 MHz [0;37m
[1;34mGraphics: [0;37m [1;34mCard-1: [0;37m Intel Xeon E3-1200 v2/3rd Gen Core processor Graphics Controller [0;37m
[1;34m          [0;37m [1;34mbus-ID: [0;37m 00:02.0 [0;37m
[1;34m          [0;37m [1;34mCard-2: [0;37m NVIDIA GK208 [GeForce GT 730] [1;34mbus-ID: [0;37m 01:00.0 [0;37m
[1;34m          [0;37m [1;34mDisplay Server: [0;37m X.org 1.17.4 [1;34mdriver: [0;37m N/A [0;37m
[1;34m          [0;37m [1;34mtty size: [0;37m 80x30 [1;34mAdvanced Data: [0;37m N/A out of X [0;37m
[1;34mAudio:    [0;37m [1;34mCard-1 [0;37m Intel 7 Series/C210 Series Family High Definition Audio Controller [0;37m
[1;34m          [0;37m [1;34mdriver: [0;37m snd_hda_intel [1;34mbus-ID: [0;37m 00:1b.0 [0;37m
[1;34m          [0;37m [1;34mCard-2 [0;37m NVIDIA GK208 HDMI/DP Audio Controller [0;37m
[1;34m          [0;37m [1;34mdriver: [0;37m snd_hda_intel [1;34mbus-ID: [0;37m 01:00.1 [0;37m
[1;34m          [0;37m [1;34mSound: [0;37m Advanced Linux Sound Architecture [1;34mv: [0;37m k3.18.32-1-MANJARO [0;37m
[1;34mNetwork:  [0;37m [1;34mCard: [0;37m Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [0;37m
[1;34m          [0;37m [1;34mdriver: [0;37m r8169 [1;34mv: [0;37m 2.3LK-NAPI [1;34mport: [0;37m d000 [1;34mbus-ID: [0;37m 05:00.0 [0;37m
[1;34m          [0;37m [1;34mIF: [0;37m enp5s0 [1;34mstate: [0;37m up [1;34mspeed: [0;37m 1000 Mbps [1;34mduplex: [0;37m full [0;37m
[1;34m          [0;37m [1;34mmac: [0;37m bc:5f:f4:50:94:5d [0;37m
[1;34mDrives:   [0;37m [1;34mHDD Total Size: [0;37m 628.1GB (9.9% used) [0;37m
[1;34m          [0;37m [1;34mID-1: [0;37m /dev/sdb [1;34mmodel: [0;37m WDC_WD5000AAKX [1;34msize: [0;37m 500.1GB [0;37m
[1;34m          [0;37m [1;34mID-2: [0;37m /dev/sda [1;34mmodel: [0;37m M4 [1;34msize: [0;37m 128.0GB [0;37m
[1;34mPartition: [0;37m [1;34mID-1: [0;37m / [1;34msize: [0;37m 19G [1;34mused: [0;37m 19G (99%) [1;34mfs: [0;37m ext4 [1;34mdev: [0;37m /dev/sda2 [0;37m
[1;34m          [0;37m [1;34mID-2: [0;37m /home [1;34msize: [0;37m 91G [1;34mused: [0;37m 33G (36%) [1;34mfs: [0;37m ext4 [1;34mdev: [0;37m /dev/sda3 [0;37m
[1;34m          [0;37m [1;34mID-3: [0;37m swap-1 [1;34msize: [0;37m 8.19GB [1;34mused: [0;37m 0.00GB (0%) [1;34mfs: [0;37m swap [1;34mdev: [0;37m /dev/sda1 [0;37m
[1;34mSensors:  [0;37m [1;34mSystem Temperatures: cpu: [0;37m 37.0C [1;34mmobo: [0;37m N/A [1;34mgpu: [0;37m 0.0: [0;37m
[1;34m          [0;37m [1;34mFan Speeds (in rpm): cpu: [0;37m N/A [0;37m
[1;34mInfo:     [0;37m [1;34mProcesses: [0;37m 97 [1;34mUptime: [0;37m 18 min [1;34mMemory: [0;37m 192.6/7884.5MB [0;37m
[1;34m          [0;37m [1;34mInit: [0;37m systemd [1;34mGcc sys: [0;37m 6.1.1 [1;34mClient: [0;37m Shell (zsh 5.2) [1;34minxi: [0;37m 2.3.0 [0;37m [0;37m
Offline jonathon
  • Core Team
  • Branch: Unstable
  • Skill: Advanced
« Reply #3 on: 10. May 2016, 12:39:39 »
This sounds like an issue. Output please.
Offline pher
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
« Reply #4 on: 10. May 2016, 19:38:25 »
This is the result of execute sudo pacman -S nvidia nvidia-utils
Code: [Select]
error: no se pudo analizar el archivo de descripción del paquete «zn_poly-0.9-3/desc» de la base de datos «community»
advertencia: linux318-nvidia-1:364.19-1 está actualizado -- reinstalándolo
resolviendo dependencias…
buscando conflictos entre paquetes…
Paquetes (2) linux318-nvidia-1:364.19-1  nvidia-utils-1:364.19-1
Tamaño total de la instalación:  116,64 MiB
Tamaño neto tras actualizar:    110,79 MiB
:: ¿Continuar con la instalación? [S/n] comprobando el depósito de claves…
verificando la integridad de los paquetes…
cargando los archivos de los paquetes…
comprobando conflictos entre archivos…
error: no se pudo realizar la operación (archivos en conflicto)
nvidia-utils: /usr/bin/nvidia-bug-report.sh existe en el sistema de archivos
nvidia-utils: /usr/bin/nvidia-cuda-mps-control existe en el sistema de archivos
nvidia-utils: /usr/bin/nvidia-cuda-mps-server existe en el sistema de archivos
nvidia-utils: /usr/bin/nvidia-debugdump existe en el sistema de archivos
nvidia-utils: /usr/bin/nvidia-modprobe existe en el sistema de archivos
nvidia-utils: /usr/bin/nvidia-persistenced existe en el sistema de archivos
nvidia-utils: /usr/bin/nvidia-settings existe en el sistema de archivos
nvidia-utils: /usr/bin/nvidia-smi existe en el sistema de archivos
nvidia-utils: /usr/bin/nvidia-xconfig existe en el sistema de archivos
nvidia-utils: /usr/lib/libEGL_nvidia.so existe en el sistema de archivos
nvidia-utils: /usr/lib/libEGL_nvidia.so.0 existe en el sistema de archivos
nvidia-utils: /usr/lib/libEGL_nvidia.so.364.19 existe en el sistema de archivos
nvidia-utils: /usr/lib/libGLESv1_CM_nvidia.so existe en el sistema de archivos
nvidia-utils: /usr/lib/libGLESv1_CM_nvidia.so.1 existe en el sistema de archivos
nvidia-utils: /usr/lib/libGLESv1_CM_nvidia.so.364.19 existe en el sistema de archivos
nvidia-utils: /usr/lib/libGLESv2_nvidia.so existe en el sistema de archivos
nvidia-utils: /usr/lib/libGLESv2_nvidia.so.2 existe en el sistema de archivos
nvidia-utils: /usr/lib/libGLESv2_nvidia.so.364.19 existe en el sistema de archivos
nvidia-utils: /usr/lib/libGLX_indirect.so.0 existe en el sistema de archivos
nvidia-utils: /usr/lib/libGLX_nvidia.so existe en el sistema de archivos
nvidia-utils: /usr/lib/libGLX_nvidia.so.0 existe en el sistema de archivos
nvidia-utils: /usr/lib/libGLX_nvidia.so.364.19 existe en el sistema de archivos
nvidia-utils: /usr/lib/libcuda.so existe en el sistema de archivos
nvidia-utils: /usr/lib/libcuda.so.1 existe en el sistema de archivos
nvidia-utils: /usr/lib/libcuda.so.364.19 existe en el sistema de archivos
nvidia-utils: /usr/lib/libnvcuvid.so existe en el sistema de archivos
nvidia-utils: /usr/lib/libnvcuvid.so.1 existe en el sistema de archivos
nvidia-utils: /usr/lib/libnvcuvid.so.364.19 existe en el sistema de archivos
nvidia-utils: /usr/lib/libnvidia-cfg.so existe en el sistema de archivos
nvidia-utils: /usr/lib/libnvidia-cfg.so.1 existe en el sistema de archivos
nvidia-utils: /usr/lib/libnvidia-cfg.so.364.19 existe en el sistema de archivos
nvidia-utils: /usr/lib/libnvidia-eglcore.so existe en el sistema de archivos
nvidia-utils: /usr/lib/libnvidia-eglcore.so.364.19 existe en el sistema de archivos
nvidia-utils: /usr/lib/libnvidia-encode.so existe en el sistema de archivos
nvidia-utils: /usr/lib/libnvidia-encode.so.1 existe en el sistema de archivos
nvidia-utils: /usr/lib/libnvidia-encode.so.364.19 existe en el sistema de archivos
nvidia-utils: /usr/lib/libnvidia-fatbinaryloader.so existe en el sistema de archivos
nvidia-utils: /usr/lib/libnvidia-fatbinaryloader.so.364.19 existe en el sistema de archivos
nvidia-utils: /usr/lib/libnvidia-fbc.so existe en el sistema de archivos
nvidia-utils: /usr/lib/libnvidia-fbc.so.1 existe en el sistema de archivos
nvidia-utils: /usr/lib/libnvidia-fbc.so.364.19 existe en el sistema de archivos
nvidia-utils: /usr/lib/libnvidia-glcore.so existe en el sistema de archivos
nvidia-utils: /usr/lib/libnvidia-glcore.so.364.19 existe en el sistema de archivos
nvidia-utils: /usr/lib/libnvidia-glsi.so existe en el sistema de archivos
nvidia-utils: /usr/lib/libnvidia-glsi.so.364.19 existe en el sistema de archivos
nvidia-utils: /usr/lib/libnvidia-gtk2.so existe en el sistema de archivos
nvidia-utils: /usr/lib/libnvidia-gtk2.so.364.19 existe en el sistema de archivos
nvidia-utils: /usr/lib/libnvidia-gtk3.so existe en el sistema de archivos
nvidia-utils: /usr/lib/libnvidia-gtk3.so.364.19 existe en el sistema de archivos
nvidia-utils: /usr/lib/libnvidia-ifr.so existe en el sistema de archivos
nvidia-utils: /usr/lib/libnvidia-ifr.so.1 existe en el sistema de archivos
nvidia-utils: /usr/lib/libnvidia-ifr.so.364.19 existe en el sistema de archivos
nvidia-utils: /usr/lib/libnvidia-ml.so existe en el sistema de archivos
nvidia-utils: /usr/lib/libnvidia-ml.so.1 existe en el sistema de archivos
nvidia-utils: /usr/lib/libnvidia-ml.so.364.19 existe en el sistema de archivos
nvidia-utils: /usr/lib/libnvidia-ptxjitcompiler.so existe en el sistema de archivos
nvidia-utils: /usr/lib/libnvidia-ptxjitcompiler.so.364.19 existe en el sistema de archivos
nvidia-utils: /usr/lib/libnvidia-tls.so existe en el sistema de archivos
nvidia-utils: /usr/lib/libnvidia-tls.so.364.19 existe en el sistema de archivos
nvidia-utils: /usr/lib/nvidia/libEGL.so existe en el sistema de archivos
nvidia-utils: /usr/lib/nvidia/libEGL.so.1 existe en el sistema de archivos
nvidia-utils: /usr/lib/nvidia/libEGL.so.364.19 existe en el sistema de archivos
nvidia-utils: /usr/lib/nvidia/xorg/modules/extensions/libglx.so existe en el sistema de archivos
nvidia-utils: /usr/lib/nvidia/xorg/modules/extensions/libglx.so.364.19 existe en el sistema de archivos
nvidia-utils: /usr/lib/systemd/system/nvidia-persistenced.service existe en el sistema de archivos
nvidia-utils: /usr/lib/vdpau/libvdpau_nvidia.so existe en el sistema de archivos
nvidia-utils: /usr/lib/vdpau/libvdpau_nvidia.so.1 existe en el sistema de archivos
nvidia-utils: /usr/lib/vdpau/libvdpau_nvidia.so.364.19 existe en el sistema de archivos
nvidia-utils: /usr/share/applications/nvidia-settings.desktop existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia-utils existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/NVIDIA_Changelog existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/README existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/acknowledgements.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/addressingcapabilities.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/addtlresources.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/appendices.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/audiosupport.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/commonproblems.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/configlaptop.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/configmultxscreens.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/configtwinview.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/depth30.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/displaydevicenames.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/dma_issues.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/dpi.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/editxconfig.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/faq.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/flippingubb.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/framelock.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/glxsupport.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/gpunames.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/i2c.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/index.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/installationandconfiguration.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/installdriver.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/installedcomponents.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/introduction.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/kms.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/knownissues.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/minimumrequirements.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/newusertips.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/nvidia-debugdump.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/nvidia-ml.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/nvidia-persistenced.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/nvidia-smi.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/nvidiasettings.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/openglenvvariables.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/optimus.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/powermanagement.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/procinterface.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/profiles.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/programmingmodes.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/randr14.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/sdi.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/selectdriver.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/sli.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/supportedchips.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/vdpausupport.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/xcompositeextension.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/xconfigoptions.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/xineramaglx.html existe en el sistema de archivos
nvidia-utils: /usr/share/doc/nvidia/html/xrandrextension.html existe en el sistema de archivos
nvidia-utils: /usr/share/licenses/nvidia-utils existe en el sistema de archivos
nvidia-utils: /usr/share/licenses/nvidia/LICENSE existe en el sistema de archivos
nvidia-utils: /usr/share/man/man1/nvidia-cuda-mps-control.1.gz existe en el sistema de archivos
nvidia-utils: /usr/share/man/man1/nvidia-modprobe.1.gz existe en el sistema de archivos
nvidia-utils: /usr/share/man/man1/nvidia-persistenced.1.gz existe en el sistema de archivos
nvidia-utils: /usr/share/man/man1/nvidia-settings.1.gz existe en el sistema de archivos
nvidia-utils: /usr/share/man/man1/nvidia-smi.1.gz existe en el sistema de archivos
nvidia-utils: /usr/share/man/man1/nvidia-xconfig.1.gz existe en el sistema de archivos
nvidia-utils: /usr/share/nvidia/nvidia-application-profiles-364.19-key-documentation existe en el sistema de archivos
nvidia-utils: /usr/share/nvidia/nvidia-application-profiles-364.19-rc existe en el sistema de archivos
nvidia-utils: /usr/share/pixmaps/nvidia-settings.png existe en el sistema de archivos
nvidia-utils: /usr/share/vulkan/icd.d/nvidia_icd.json existe en el sistema de archivos
Ocurrieron errores, por lo que no se actualizaron los paquetes
Offline jonathon
  • Core Team
  • Branch: Unstable
  • Skill: Advanced
« Reply #5 on: 10. May 2016, 21:28:31 »
And output of `pacman -Qo /usr/bin/nvidia-bug-report.sh`
Offline pher
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
« Reply #6 on: 10. May 2016, 21:47:29 »
I get:
Error: no package owns /usr/bin/nvidia-bug-report.sh
Offline pher
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
« Reply #7 on: 10. May 2016, 21:58:18 »
I forced the install:
Sudo pacman -S --force nvidia
Now it works, issue solved
Thanks jonathon
Offline jonathon
  • Core Team
  • Branch: Unstable
  • Skill: Advanced
« Reply #8 on: 10. May 2016, 22:15:41 »
I get:
That means you probably installed the drivers direct from the Nvidia website. Remember that manually installing files means the system's package manager does not know where they come from.
Thanks jonathon
Yup.
