Author Topic: laptop-mode-tools fails with openrc script  (Read 699 times)
Offline emninger
  • Vollwertiges Mitglied
  • I'm new. Be nice!
  • Branch: 16.04 open-rc
  • Desktop: JWM
  • GPU Card: nvidia
  • GPU driver: no
  • Kernel: linux 4.4.8-1-Manjaro x86_64
  • Skill: Novice
« on: 09. May 2016, 00:21:51 »
I installed laptop-mode-tools and the respective script.After installation pacli told me to do
Code: [Select]
sudo rc-update add saned defaultwhich fails with the following statement:
Code: [Select]
* rc-update: service `saned' does not exist
Any ideas what happened here?
Thanks a lot in advance.
Offline glock172
  • Branch: openrc, unstable
  • Desktop: MATE,Xfce
  • GPU Card: GT 210
  • GPU driver: free
  • Kernel: 4.4
  • Skill: Novice
Re: laptop-mode-tools fails with openrc script
« Reply #1 on: 09. May 2016, 00:43:02 »
Do you really need it? If you don't think to use sane it'll be better to not add this service.
https://wiki.archlinux.org/index.php/SANE
http://linux.die.net/man/8/saned
I think that you should install sane-openrc(the actual script) first,or something like that(I'm not using Manjaro now) and then try this:
Code: [Select]
sudo rc-update add sane default
if this does not work:
Code: [Select]
sudo rc-update add saned defaultWithout the "d" in saned, cause this message can be wrong(for older version of the openrc script maybe)
« Last Edit: 09. May 2016, 00:54:23 by glock172 »
If it ain't broke, don't fix it
Offline emninger
  • I'm new. Be nice!
  • Desktop: JWM
  • GPU Card: nvidia
  • GPU driver: no
  • Skill: Novice
« Reply #2 on: 09. May 2016, 01:46:17 »
Thanks for answering, but i'm confused. I wanted to install laptop-mode-tools to tweak a bit the powermanagement -nd it was at the end of the installation of laptop-mode-tools-openrc that i was asked ot add saned to default a. Cfr. https://wiki.archlinux.org/index.php/Laptop-mode-tools
It has nothing to do with the installation of a scanner ... ????
