Author Topic: [partially-SOLVED] : Kernel panic : Manjaro-16.06 NOT booting after CLIInstall  (Read 2206 times)
Offline archiebunker
  • Vollwertiges Mitglied
  • Branch: Stable
  • Desktop: OB, FB, Mate
  • GPU Card: A10/APU/GPU/7670M
  • GPU driver: AMD/ATI OpenSource Graphics
  • Kernel: manjaro-*.*-x86_64
  • Skill: Intermediate
[Minor UPDATE_02]:
 ok, no more spoiled brat phoney/virtualbox installations for me.
I will, from now on, judge Linux distro's by how well they can "Bare-Metal" Install. !, and so should you.
 That should light a fire under their  <3
  C:-)
« Last Edit: 09. May 2016, 16:09:56 by archiebunker »
Offline gohlip
  • Held Mitglied
  • Desktop: OpenBox
  • GPU Card: nvidia
  • GPU driver: nonfree
  • Kernel: linux46 - x64
Quote
I noticed that it had switched my sda with sdb, within my system.
Just a small point. That is caused by the bios which will assign the device mapping, nothing to do with installer, either calamares or cli.
And that may change too with every boot, especially with more than 2 drives.
Normally, when you boot off a drive - not the one normally 'you' (not bios) call 'sda', that drive will be 'sda' to the bios.
Try booting off an external - most people won't call externals 'sda' - (with a bootloader in it), that external will become 'sda' (check with 'lsblk -f' or others).
The point is, what 'you' call sda doesn't matter. It's what the 'bios' call and that is what the system uses.
And not to worry too much either, grub2 by using uuid, makes sure you boot the correct partition regardless of sda/sdb/sdc confusion
(won't be the case with grub-legacy).
Life is a sexually transmitted disease with a 100% mortality rate.
Offline c00ter
  • Held Mitglied
  • Towelie's cupcake
  • Branch: ☮Olive☮
  • Desktop: Depends©
  • GPU Card: Intel HD4400M CPU: Core i7-4510U
  • GPU driver: Intel/Free
  • Kernel: 4.4-lts & 4.5
  • Skill: Novice
It's why I like UUID.
“What, me worry?” ― Alfred E. Newman
Manjaro Wiki: https://wiki.manjaro.org/
Arch Wiki: https://wiki.archlinux.org/
Pacman Rosetta: https://wiki.archlinux.org/index.php/Pacman/Rosetta
