Hi,
I installed Manjaro gnome on my laptop with hybrid graphic cards (HD Graphics 5500 (Broadwell GT2) and ATI Radeon R7 M265). i experienced 2 problems that may be linked, that's why I created one topic for both.
1. My system regularly fails to start (probably x system fails) with such a screen :
http://i.imgur.com/7RMdlZe.jpg2. I can't get my discrete card to work. My driver is video-hybrid-intel-ati-bumblebee, but bumblebee fails to detect my graphic card :
-- Subject: L'unité (unit) bumblebeed.service a terminé son démarrage
-- L'unité (unit) bumblebeed.service a terminé son démarrage, avec le résultat done.
mai 08 15:32:37 manjaro bumblebeed[2671]: [ 2126.768583] [ERROR]No discrete video card found, quitting
mai 08 15:32:36 manjaro systemd[1]: bumblebeed.service: Main process exited, code=exited, status=1/FAILURE
mai 08 15:32:36 manjaro systemd[1]: bumblebeed.service: Unit entered failed state.
mai 08 15:32:36 manjaro systemd[1]: bumblebeed.service: Failed with result 'exit-code'.
I tried kernel 4.4 and 4.5 and Manjaro 15.12 and 16.06 but nothing solves my problems.
Here is the complete journalctl of my current boot :
http://pastebin.com/Xrmq3BSn# lspci
00:00.0 Host bridge: Intel Corporation Broadwell-U Host Bridge -OPI (rev 09)
00:02.0 VGA compatible controller: Intel Corporation Broadwell-U Integrated Graphics (rev 09)
00:03.0 Audio device: Intel Corporation Broadwell-U Audio Controller (rev 09)
00:14.0 USB controller: Intel Corporation Wildcat Point-LP USB xHCI Controller (rev 03)
00:16.0 Communication controller: Intel Corporation Wildcat Point-LP MEI Controller #1 (rev 03)
00:1b.0 Audio device: Intel Corporation Wildcat Point-LP High Definition Audio Controller (rev 03)
00:1c.0 PCI bridge: Intel Corporation Wildcat Point-LP PCI Express Root Port #1 (rev e3)
00:1c.3 PCI bridge: Intel Corporation Wildcat Point-LP PCI Express Root Port #4 (rev e3)
00:1c.4 PCI bridge: Intel Corporation Wildcat Point-LP PCI Express Root Port #5 (rev e3)
00:1d.0 USB controller: Intel Corporation Wildcat Point-LP USB EHCI Controller (rev 03)
00:1f.0 ISA bridge: Intel Corporation Wildcat Point-LP LPC Controller (rev 03)
00:1f.2 SATA controller: Intel Corporation Wildcat Point-LP SATA Controller [AHCI Mode] (rev 03)
00:1f.3 SMBus: Intel Corporation Wildcat Point-LP SMBus Controller (rev 03)
07:00.0 Network controller: Intel Corporation Wireless 3160 (rev 83)
08:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Opal XT [Radeon R7 M265]
# sudo cat /sys/kernel/debug/vgaswitcheroo/switch
[sudo] Mot de passe de vicd :
0:IGD:+:Pwr:0000:00:02.0
1:DIS: :Pwr:0000:08:00.0
# xrandr --listproviders
Providers: number : 1
Provider 0: id: 0x46 cap: 0xb, Source Output, Sink Output, Sink Offload crtcs: 4 outputs: 3 associated providers: 0 name:Intel
# mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-ati-bumblebee 2016.01.28 true PCI
My 90-mhwd.conf in xorg.conf.d folder :
## Generated by mhwd - Manjaro Hardware Detection
Section "Device"
Identifier "Device0"
Driver "intel"
BusID "PCI:0:2:0"
Option "AccelMethod" "sna"
Option "DRI" "true"
Option "DRI" "3"
Option "Tearfree" "true"
EndSection
Section "DRI"
Group "video"
Mode 0666
EndSection
Section "Extensions"
Option "Composite" "Enable"
Option "RENDER" "Enable"
EndSection
Section "InputClass"
Identifier "Keyboard Defaults"
MatchIsKeyboard "yes"
Option "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
My bumblebee.conf :
# Configuration file for Bumblebee. Values should **not** be put between quotes
## Server options. Any change made in this section will need a server restart
# to take effect.
[bumblebeed]
# The secondary Xorg server DISPLAY number
VirtualDisplay=:8
# Should the unused Xorg server be kept running? Set this to true if waiting
# for X to be ready is too long and don't need power management at all.
KeepUnusedXServer=false
# The name of the Bumbleblee server group name (GID name)
ServerGroup=bumblebee
# Card power state at exit. Set to false if the card shoud be ON when Bumblebee
# server exits.
TurnCardOffAtExit=false
# The default behavior of '-f' option on optirun. If set to "true", '-f' will
# be ignored.
NoEcoModeOverride=false
# The Driver used by Bumblebee server. If this value is not set (or empty),
# auto-detection is performed. The available drivers are nvidia and nouveau
# (See also the driver-specific sections below)
Driver=radeon
# Directory with a dummy config file to pass as a -configdir to secondary X
XorgConfDir=/etc/bumblebee/xorg.conf.d
## Client options. Will take effect on the next optirun executed.
[optirun]
# Acceleration/ rendering bridge, possible values are auto, virtualgl and
# primus.
Bridge=auto
# The method used for VirtualGL to transport frames between X servers.
# Possible values are proxy, jpeg, rgb, xv and yuv.
VGLTransport=proxy
# List of paths which are searched for the primus libGL.so.1 when using
# the primus bridge
PrimusLibraryPath=/usr/lib/primus:/usr/lib32/primus
# Should the program run under optirun even if Bumblebee server or nvidia card
# is not available?
AllowFallbackToIGC=false
# Driver-specific settings are grouped under [driver-NAME]. The sections are
# parsed if the Driver setting in [bumblebeed] is set to NAME (or if auto-
# detection resolves to NAME).
# PMMethod: method to use for saving power by disabling the nvidia card, valid
# values are: auto - automatically detect which PM method to use
# bbswitch - new in BB 3, recommended if available
# switcheroo - vga_switcheroo method, use at your own risk
# none - disable PM completely
# https://github.com/Bumblebee-Project/Bumblebee/wiki/Comparison-of-PM-methods
## Section with nvidia driver specific options, only parsed if Driver=nvidia
[driver-nvidia]
# Module name to load, defaults to Driver if empty or unset
KernelDriver=nvidia
PMMethod=auto
# colon-separated path to the nvidia libraries
LibraryPath=/usr/lib/nvidia:/usr/lib32/nvidia
# comma-separated path of the directory containing nvidia_drv.so and the
# default Xorg modules path
XorgModulePath=/usr/lib/nvidia/xorg/,/usr/lib/xorg/modules
XorgConfFile=/etc/bumblebee/xorg.conf.nvidia
## Section with nouveau driver specific options, only parsed if Driver=nouveau
[driver-nouveau]
KernelDriver=nouveau
PMMethod=auto
XorgConfFile=/etc/bumblebee/xorg.conf.nouveau
Xorg.conf.ati in the bumblebee folder :
Section "ServerLayout"
Identifier "Layout0"
Screen "Screen0"
Option "AutoAddDevices" "false"
EndSection
Section "Device"
Identifier "Device1"
Driver "radeon"
BusID "PCI:8:0:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
EndSection
Can anyone help me to solve my problems ?
Thanks.
