Hello,
I am confused by this post, excuse my ignorance for asking but when I start up, Bumbleebee C Daemon is enabled which I thought enabled the Nvidia card without any further action. Is this not so or do I have to run the scripts as advised in this post?
Any clear advice much appreciated.
For clear advice, you should post clear question, no
Which scripts are you talking about?
If bumblebee daemon is enabled on startup
sudo systemctl enable bumblebeed.service
and
mhwd -li
lists your card, then you dont need to do anything else unless you are having problems.
If you are having some problem ,make a seperate thread for it.
