Author Topic: Installation stuck  (Read 1873 times)
Offline gurgahurga
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
Installation stuck
« on: 08. May 2016, 10:52:56 »
I'm new to manjaro.  I tried installing 16.06 KDE version and then for the heck of it, 16.02 cinnamon version both from flash drives on top of an existing ubuntu installation.  For the KDE version I get stuck at "Starting Terminate Plymouth Boot Screen"
For cinnamon I get stuck at "Started Accounts Service"
If I pick non-free for either of them it hangs at "A start job is running for LiveMedia MHWD Script"
I am back on ubuntu for now.. :\
Offline eugen-b
  • Support Team
  • Branch: testing
  • Desktop: LXDE, Fluxbox, JWM, LXQt, bspwm
  • GPU Card: Intel 82945G/GZ
  • GPU driver: free
  • Kernel: 4.5, 4.6
  • Skill: Intermediate
Re: Installation stuck
« Reply #1 on: 08. May 2016, 11:13:32 »
A hardware issue, nothing unusual. If you post inxi -F (need to install inxi) output or s.th. similar from your Ubuntu install, then we here might be able to help you.
MSI Wind Nettop, Intel Atom 230 1.6GHz (64bit), 2GB RAM
DEs: NET-minimal + (LXDE / Fluxbox / JWM); LXQt OpenRC
how to install on btrfs subvolumes
http://manjaro.github.io/donate/
Offline gurgahurga
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
« Reply #2 on: 08. May 2016, 11:17:00 »
I forgot to mention something that's probably relevant.  I have an AMD Kaveri A8-7600 APU...
Offline badbodh
  • Held Mitglied
  • Windows assumes I'm stupid, Linux proves it.
  • Branch: Testing
  • Desktop: Xfce, i3
  • GPU Card: Intel Mobile 4 Series
  • Kernel: linux41 64-bit
« Reply #3 on: 08. May 2016, 12:11:14 »
Boot to live session, run "inxi -Fx" in terminal and paste output here. Use the # button before you paste. This magic command takes care of anything you may forget to mention :)
You can't feel the love till it hurts a little. Go rolling, go bleeding-edge !
Offline gurgahurga
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
« Reply #4 on: 09. May 2016, 11:37:52 »
 ;D Here are all the other things I didn't mention:
Machine:   System: Gigabyte product: N/A
           Mobo: Gigabyte model: F2A88XN-WIFI v: x.x Bios: American Megatrends v: F4 date: 05/28/2014
CPU:       Quad core AMD A8-7600 Radeon R7 10 Compute Cores 4C+6G (-MCP-) cache: 8192 KB
           clock speeds: max: 3100 MHz 1: 1900 MHz 2: 1400 MHz 3: 1900 MHz 4: 2400 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Kaveri [Radeon R7 Graphics]
           Display Server: X.Org 1.18.3 drivers: ati,radeon (unloaded: fbdev,vesa) Resolution: 1920x1080@60.00hz
           GLX Renderer: Gallium 0.4 on AMD KAVERI (DRM 2.43.0, LLVM 3.8.0) GLX Version: 3.0 Mesa 11.2.0
Audio:     Card-1 Advanced Micro Devices [AMD] FCH Azalia Controller driver: snd_hda_intel
           Card-2 Advanced Micro Devices [AMD/ATI] Kaveri HDMI/DP Audio Controller driver: snd_hda_intel
           Sound: Advanced Linux Sound Architecture v: k4.4.0-22-generic
Network:   Card-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller driver: r8169
           IF: enp1s0 state: down mac: 74:d4:35:ef:75:ed
           Card-2: Intel Wireless 7260 driver: iwlwifi
           IF: wlp3s0 state: up mac: 80:86:f2:1e:50:37
Drives:    HDD Total Size: 128.0GB (13.6% used) ID-1: /dev/sda model: Crucial_CT128M55 size: 128.0GB
Partition: ID-1: / size: 110G used: 9.6G (10%) fs: ext4 dev: /dev/sda2
           ID-2: swap-1 size: 7.45GB used: 0.00GB (0%) fs: swap dev: /dev/sda3
RAID:      No RAID devices: /proc/mdstat, md_mod kernel module present
Sensors:   System Temperatures: cpu: 0.0C mobo: N/A gpu: -3.0
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 247 Uptime: 1 min Memory: 1284.9/6976.4MB Client: Shell (bash) inxi: 2.2.35
Offline archiebunker
  • Vollwertiges Mitglied
  • Branch: Stable
  • Desktop: OB, FB, Mate
  • GPU Card: A10/APU/GPU/7670M
  • GPU driver: AMD/ATI OpenSource Graphics
  • Kernel: manjaro-*.*-x86_64
« Reply #5 on: 09. May 2016, 13:44:11 »
 I just recently installed Manjaro-KDE-16.06 on my AMD APU Laptop, (but on a separate drive) using the Calamares-GUI-Installer, rebooted, then updated the system with "pacman -Syyu", rebooted again, and yes,
 I also got that "stop job running....", but it will reboot/shutdown after a minute or so, and it's not really plymouth,...,  it's possibly due more to "systemd" not shutting things down in a timely and quick manner.
 ... somewhat related: https://bbs.archlinux.org/viewtopic.php?id=209434
And, if you're dual-booting with Ubuntu and Manjaro ?, check this out:
 https://forum.manjaro.org/index.php?topic=33429.msg273538#msg273538
Also, I wouldn't bother with the initial Live/boot NON-FREE driver install, you're just adding more variables that may go wrong, besides, it's quick and easy to install the NON-FREE gpu drivers later, after you've successfully installed/updated your system completely.
 hope this helps.
« Last Edit: 09. May 2016, 14:09:29 by archiebunker »
