Author Topic: Black screen when trying to install Manjaro Deepin  (Read 2138 times)
0 Members and 2 Guests are viewing this topic.
Offline peynir
  • Neuling
  • Skill: Novice
« on: 07. May 2016, 22:50:54 »
As i stated in topic, i can not access anything. I was tryin to install 16.03 version. Checked md5. Also i can hear some sounds like opening etc. But i can not reach ctrl+alt+f2 or anything else.
Any ideas?
Offline eugen-b
  • Support Team
  • Branch: testing
  • Desktop: LXDE, Fluxbox, JWM, LXQt, bspwm
  • GPU Card: Intel 82945G/GZ
  • GPU driver: free
  • Kernel: 4.5, 4.6
  • Skill: Intermediate
Re: Black screen when trying to install Manjaro Deepin
« Reply #1 on: 07. May 2016, 22:55:27 »
Nothing unusual, you need to know how to boot Linux with your hardware. Can you post some hardware details, for example with the command inxi -F ?
MSI Wind Nettop, Intel Atom 230 1.6GHz (64bit), 2GB RAM
DEs: NET-minimal + (LXDE / Fluxbox / JWM); LXQt OpenRC
how to install on btrfs subvolumes
http://manjaro.github.io/donate/
Offline peynir
  • Neuling
  • Skill: Novice
« Reply #2 on: 07. May 2016, 23:21:15 »
I tried over 20+ distros. I like hooping and usually i can solve most of my problems. But in this one, i dont have any clue about this. Like you said i can not get some infos because i can not access to TTY or anything else. Just black screen.
Offline Heart Of A Lion
  • Sr. Mitglied
  • I'm new. Be nice!
  • Branch: Stable
  • Desktop: Xfce, Enlightenment
  • GPU Card: ATi 7770 . . . . . . . CPU: AMD octacore 4GHz
  • GPU driver: Free (video-ATI)
  • Kernel: 4.6 (x64)
« Reply #3 on: 07. May 2016, 23:36:42 »
Not sure if you see the black screen when you boot the live cd or after you've installed Manjaro, however the reason you're not seeing anything could be due to the video/graphics drivers with which you boot the Manjaro live cd or your Manjaro installation. Try booting with different video/graphics drivers if possible.
Offline peynir
  • Neuling
  • Skill: Novice
« Reply #4 on: 08. May 2016, 00:30:23 »
Actually i dont know how to switch between drivers like you said. But i tried nonfree and the other one, i cant remember it now.  Is there anything else i can do?
Btw, i tried to install same iso on Virtualbox and it works like a charm. So as you suggested, its probably some kind of video driver problem.
  • Sr. Mitglied
  • I'm new. Be nice!
  • Branch: Stable
  • Kernel: 4.6 (x64)
« Reply #5 on: 08. May 2016, 00:54:39 »
You can try to download and install the preview version of Manjaro 16.6, because it probably has a newer kernel and newer video/graphics drivers, so it might help.
Here's the link: http://manjaro.github.io/download/
If that doesn't work you can also try an older version like 15.12, but try the newer preview version first.
Let us know if it worked.
Offline eugen-b
  • Support Team
  • Branch: testing
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #6 on: 08. May 2016, 00:59:14 »
Well, you should be able to post the output from another distro or virtual box. But as my fellow user suggested, try a newer ISO.
Offline peynir
  • Neuling
  • Skill: Novice
« Reply #7 on: 08. May 2016, 01:20:44 »
Here is the inxi result.
Code: [Select]
~ inxi -F
System:    Host: Peyloride-Manjaro Kernel: 4.4.8-1-MANJARO x86_64 (64 bit) Desktop: KDE Plasma 5.6.3
           Distro: Manjaro Linux
Machine:   System: Acer (portable) product: Aspire ES1-331 v: V1.11
           Mobo: Acer model: Aspire ES1-331 v: V1.11 Bios: Insyde v: V1.11 date: 08/12/2015
CPU:       Quad core Intel Celeron N3150 (-MCP-) cache: 1024 KB
           clock speeds: max: 2080 MHz 1: 1019 MHz 2: 513 MHz 3: 1029 MHz 4: 1331 MHz
Graphics:  Card: Intel Device 22b1
           Display Server: X.Org 1.17.4 driver: intel Resolution: 1366x768@60.01hz
           GLX Renderer: Mesa DRI Intel HD Graphics (Cherryview) GLX Version: 3.0 Mesa 11.2.1
Audio:     Card Intel Device 2284 driver: snd_hda_intel Sound: ALSA v: k4.4.8-1-MANJARO
Network:   Card-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller driver: r8168
           IF: enp1s0f1 state: down mac: 30:65:ec:94:c2:fc
           Card-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter driver: ath9k
           IF: wlp2s0 state: up mac: 30:52:cb:37:16:a5
Drives:    HDD Total Size: NA (-) ID-1: /dev/mmcblk0 model: N/A size: 31.3GB
Partition: ID-1: / size: 25G used: 14G (59%) fs: ext4 dev: /dev/mmcblk0p2
           ID-2: swap-1 size: 4.11GB used: 0.00GB (0%) fs: swap dev: /dev/mmcblk0p3
Sensors:   System Temperatures: cpu: 30.0C mobo: N/A
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 171 Uptime: 2 min Memory: 696.5/3782.4MB Client: Shell (zsh) inxi: 2.2.38
Also i'm already trying the newest iso for deepin which is 16.03 afaik. I didn't try 15.12 or older than 16.03
  • Sr. Mitglied
  • I'm new. Be nice!
  • Branch: Stable
  • Kernel: 4.6 (x64)
« Reply #8 on: 08. May 2016, 01:24:29 »
Quote
Have you tried the preview version of Manjaro 16.6 though?
Offline peynir
  • Neuling
  • Skill: Novice
« Reply #9 on: 08. May 2016, 02:11:43 »
I cant see any 16.06 build for deepin DE. Can you provide me a link?
  • Sr. Mitglied
  • I'm new. Be nice!
  • Branch: Stable
  • Kernel: 4.6 (x64)
« Reply #10 on: 09. May 2016, 00:00:23 »
I think that currently there is only one for Xfce.
