Author Topic: Switch between Display Managers  (Read 844 times)
Offline gigi88
  • Jr. Mitglied
  • Desktop: XFCE
  • GPU Card: Nvidia GT 750m
  • GPU driver: non-free
  • Kernel: 3.12 and 3.16
  • Skill: Novice
« on: 07. May 2016, 12:06:45 »
Hi everyone
I am running 3.16.7.27-1-MANJARO and I tried yesterday to install another display manager (MDM or SDDM) using https://wiki.manjaro.org/index.php/Install_Display_Managers. Originally I had the LightDM on my system.
After reboot I had no display manager, because for some reason there where two active on the system....and after reboot I got a black login promt screen. I fixed the problem by removing the SDDM or MDM and following the post of FadeMind from here and I successfully returned to my original LighDM.
So here is my question. In case I install another Display Manager to my system what is the proper way to switch between them and not to have a conflict at the next reboot?
This is what I have now:
[/size]
Code: [Select]
● lightdm.service - Light Display Manager
   Loaded: loaded (/usr/lib/systemd/system/lightdm.service; enabled; vendor pres
   Active: active (running) since Sat 2016-05-07 11:36:47 CEST; 24min ago
     Docs: man:lightdm(1)
 Main PID: 598 (lightdm)
   CGroup: /system.slice/lightdm.service
           ├─598 /usr/bin/lightdm
           └─610 /usr/lib/xorg-server/Xorg :0 -seat seat0 -auth /run/lightdm/roo
May 07 11:36:47 StefanPC systemd[1]: Starting Light Display Manager...
May 07 11:36:47 StefanPC systemd[1]: Started Light Display Manager.
May 07 11:36:52 StefanPC lightdm[710]: pam_unix(lightdm-greeter:session): sessio
May 07 11:37:01 StefanPC lightdm[789]: pam_unix(lightdm:auth): authentication fa
May 07 11:37:09 StefanPC lightdm[861]: pam_unix(lightdm:auth): authentication fa
May 07 11:37:15 StefanPC lightdm[863]: pam_unix(lightdm:session): session opened
[code]
[/size][/size]
Offline eugen-b
  • Support Team
  • Branch: testing
  • Desktop: LXDE, Fluxbox, JWM, LXQt, bspwm
  • GPU Card: Intel 82945G/GZ
  • GPU driver: free
  • Kernel: 4.5, 4.6
  • Skill: Intermediate
Re: Switch between Display Managers
« Reply #1 on: 07. May 2016, 16:17:17 »
You need to disable the old one and then to enable the new one, systemd or openrc way.
MSI Wind Nettop, Intel Atom 230 1.6GHz (64bit), 2GB RAM
DEs: NET-minimal + (LXDE / Fluxbox / JWM); LXQt OpenRC
how to install on btrfs subvolumes
http://manjaro.github.io/donate/
Offline c00ter
  • Held Mitglied
  • Towelie's cupcake
  • Branch: ☮Olive☮
  • Desktop: Depends©
  • GPU Card: Intel HD4400M CPU: Core i7-4510U
  • GPU driver: Intel/Free
  • Kernel: 4.4-lts & 4.5
  • Skill: Novice
« Reply #2 on: 08. May 2016, 03:15:55 »
One example:
Code: [Select]
sudo systemctl disable gdm.service
sudo systemctl enable lightdm.service
Regards
“What, me worry?” ― Alfred E. Newman
Manjaro Wiki: https://wiki.manjaro.org/
Arch Wiki: https://wiki.archlinux.org/
Pacman Rosetta: https://wiki.archlinux.org/index.php/Pacman/Rosetta
