Author Topic: networkmanager-qt last unstable update breaks plasma-nm  (Read 1236 times)
Offline papa33
  • Jr. Mitglied
Hello,
this afternoon there was an update in the unstable repos of the package networkmanager-qt.
I just wanted to report that this update breaks the plasma network widget plasma-nm.
Offline Kirek
  • Core Team
  • Branch: unstable
  • Desktop: Plasma 5
  • GPU Card: Intel HD4000 + Nvidia 620M / Geforxe GTX 970
  • GPU driver: nonfree
  • Kernel: Latest
  • Skill: Intermediate
Re: networkmanager-qt last unstable update breaks plasma-nm
« Reply #1 on: 06. May 2016, 14:59:39 »
Should be fixed with plasma-nm 5.6.3-2
Offline AJSlye
  • Maintainer
  • Netrunner Rolling Edition moderator / maintainer
  • Branch: Stable / Testing / Unstable
  • Desktop: Netrunner Rolling
  • GPU Card: Intel
  • GPU driver: Intel
  • Kernel: 4.4.1-1-MANJARO x86_64 (64 bit)
  • Skill: Guru
« Reply #2 on: 06. May 2016, 15:07:20 »
That's the price we pay for running on the unstable branch instead of testing or stable. Maybe your mirror was not completely synced or you updated too soon, both networkmanager-qt 5.21.0-2 and plasma-nm 5.6.3-2 were there when I updated just now.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #3 on: 06. May 2016, 17:51:46 »
nm-tray works for you ?
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
Offline AJSlye
  • Maintainer
  • GPU Card: Intel
  • GPU driver: Intel
  • Skill: Guru
« Reply #4 on: 06. May 2016, 18:46:25 »
If you mean plasma-nm, then yes it's working fine.
If not, what is nm-tray?
I can't find this in the repositories.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #5 on: 06. May 2016, 18:52:11 »
It was a bit off-topic. HERE
Offline AJSlye
  • Maintainer
  • GPU Card: Intel
  • GPU driver: Intel
  • Skill: Guru
« Reply #6 on: 06. May 2016, 19:16:14 »
Ah, neat.
