Author Topic: Usb drives not auto mounting  (Read 4370 times)
Offline LizziAS
  • Vollwertiges Mitglied
  • Branch: Hyssop
  • Desktop: OB-OpenRC
  • GPU Card: 6520G
  • GPU driver: Catalyst
  • Kernel: Zen
  • Skill: Intermediate
Re: Usb drives not auto mounting
« Reply #15 on: 05. May 2016, 21:04:00 »
following this thread    https://forum.manjaro.org/index.php?topic=32877.0
i was able to get it to work.  I had to edit options in thunar -> edit -> prefences -> advanced and click the boxes to auto mount usbdrives and such
then after rebooting it worked but with the caveat that i had to eject them from thunar before removing them from the computer, otherwise when i inserted  a new usb drive my desktop would lock up and require a hardboot.
I'm marking this as solved then.
What say you Eugen-b?
Offline LizziAS
  • Branch: Hyssop
  • GPU Card: 6520G
  • Kernel: Zen
« Reply #16 on: 05. May 2016, 21:11:32 »
Thunar works pretty good in openbox but sometime i like to use pcmanfm too so i usually have them both installed.
Offline eugen-b
  • Support Team
  • Branch: testing
  • Desktop: LXDE, Fluxbox, JWM, LXQt, bspwm
  • GPU Card: Intel 82945G/GZ
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #17 on: 05. May 2016, 22:33:05 »
No it doesn't work for me.
Installed and added to rc fuse and autofs, edited /etc/xdg/openbox/autostart, enable Thunar volume management, checked .xinitrc to have ck-session, but still no removable media are shown in Thunar.
MSI Wind Nettop, Intel Atom 230 1.6GHz (64bit), 2GB RAM
DEs: NET-minimal + (LXDE / Fluxbox / JWM); LXQt OpenRC
how to install on btrfs subvolumes
http://manjaro.github.io/donate/
Offline eugen-b
  • Support Team
  • Branch: testing
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #18 on: 05. May 2016, 22:46:59 »
I installed pcmanfm - same behaviour as Thunar.
Offline LizziAS
  • Branch: Hyssop
  • GPU Card: 6520G
  • Kernel: Zen
« Reply #19 on: 05. May 2016, 22:51:33 »
i didn't enable ck-session in the .init file thingy
Offline LizziAS
  • Branch: Hyssop
  • GPU Card: 6520G
  • Kernel: Zen
« Reply #20 on: 05. May 2016, 22:57:21 »
 in /etc/xdg/openbox/autostart did you add a command for pcmanfm same as thunat one?  Eugen-b?
Offline eugen-b
  • Support Team
  • Branch: testing
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #21 on: 05. May 2016, 23:10:27 »
No, forgot it first, but now I did it following your advice and the SD card shows up in pcmanfm, but not in Thunar.
The command was dbus-launch pcmanfm --daemon-mode &
What do you have in .xinitrc?
« Last Edit: 05. May 2016, 23:19:55 by eugen-b »
Offline LizziAS
  • Branch: Hyssop
  • GPU Card: 6520G
  • Kernel: Zen
« Reply #22 on: 06. May 2016, 03:05:56 »
Code: [Select]
#!/bin/sh
# ~/.xinitrc
# Executed by startx
export GTK2_RC_FILES="$HOME/.gtkrc-2.0"
DEFAULT_SESSION=openbox-session
case $1 in
  openbox) exec ck-launch-session openbox-session ;;
  *) exec ck-launch-session $DEFAULT_SESSION ;;
esac
Offline LizziAS
  • Branch: Hyssop
  • GPU Card: 6520G
  • Kernel: Zen
« Reply #23 on: 06. May 2016, 03:06:56 »
That was there for me i didn't put it there
Offline LizziAS
  • Branch: Hyssop
  • GPU Card: 6520G
  • Kernel: Zen
« Reply #24 on: 06. May 2016, 03:14:23 »
but i also ran this command in terminal:
yaourt -S sysvinit openrc eudev udev-openrc eudev-systemdcompat dbus-openrc procps-ng-nosystemd syslog-ng-nosystemd udisks2-nosystemd consolekit polkit-consolekit upower-pm-utils udisks2-nosystemd desktop-privileges xorg-xwrapper acpid-openrc alsa-utils-openrc autofs-openrc consolekit consolekit-openrc cronie-openrc dbus-openrc cups-openrc displaymanager-openrc fuse-openrc haveged-openrc hdparm-openrc openssh-openrc samba-openrc syslog-ng-openrc avahi-openrc
adapted from this page:
http://systemd-free.org/install.php
Offline viordiasko
  • Neuling
  • So far, impressed.
  • Branch: Stable
  • Desktop: XFCE/Openbox
  • GPU Card: nVidia GTX760
  • GPU driver: non-free
  • Kernel: 4.1.23-1-MANJARO x86_64
« Reply #25 on: 06. May 2016, 03:45:24 »
I had no removeable drives visible in thunar in Openbox. I solved it by running from a terminal / changing menu entries to:
Code: [Select]
dbus-launch thunar
No "--daemon" option. Now I can see all the removable drives & mount, eject them  :D (and I've rebooted since).
Also
I've just used thunar-volman-settings to automount removeable drives / media when hotplugged / inserted & it works. I haven't rebooted for this yet.
Offline suska
  • Neuling
  • I'm new. Be nice!
  • Branch: testing
  • Desktop: xfce-openbox-openrc
  • GPU Card: GM45
  • GPU driver: free
  • Kernel: 4.6
  • Skill: Novice
« Reply #26 on: 06. May 2016, 09:55:44 »
Code: [Select]
dbus-launch thunar
Got this issue 2 weeks ago. That´s what i did and was the only way for me to get it working.
Offline eugen-b
  • Support Team
  • Branch: testing
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #27 on: 06. May 2016, 14:21:19 »
Same with my, but I checked that it was there, that's what I meant.
@viordiasko, I haven't tried your method yet, looking forward to trying it, thanks!
EDIT: I can now confirm that it works. It opens a Thunar window at start but that's a minor annoyance, could be mitigated with wmctrl -c thunar & added to startup file.
« Last Edit: 06. May 2016, 15:02:48 by eugen-b »
Offline viordiasko
  • Neuling
  • Branch: Stable
« Reply #28 on: 07. May 2016, 00:10:39 »
@eugen-b You're welcome.
To be clear: I didn't add it to auto start. I changed the top level menu entry for thunar in my pipe menu
(~/.config/obmenu-generator/schema.pl).
Code: [Select]
    {item => ['dbus-launch thunar',        'File Manager',      'file-manager']},
 :) BONUS: I also noticed that using dbus-launch tomboy stops tomboy crashing on launch complaining like this:
Code: [Select]
Unhandled Exception:
System.NullReferenceException: Object reference not set to an instance of an object
  at DBus.BusG.Init (DBus.Connection conn, DBus.GLib.IOFunc dispatchHandler) <0x41116ab0 + 0x0001e> in <filename unknown>:0  etc. etc.
Now I have to work out how to change the menu entry for tomboy. It seems to be auto generated as part of the 'Accesories' category of apps in schema.pl .  Possibly changing the 'Exec=tomboy --search' line in the .desktop file in /usr/share/application. ???
Offline eugen-b
  • Support Team
  • Branch: testing
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #29 on: 07. May 2016, 01:20:17 »
@viordiasko, I've just found it out myself that I can edit the thunar.desktop file to Exec=dbus-launch thunar %F
This way obmenu-generator will create the entries with this command. Only the top menu entry needs to be edited in schema.pl, as you wrote.
aaditya will be happy about the solution.
