Author Topic: Fan not working  (Read 1445 times)
Offline peynir
  • Neuling
  • Skill: Novice
Fan not working
« on: 04. May 2016, 00:25:51 »
Hello there.
My Acer ES1-331 laptop have a little fan but it does not work in latest manjaro. But it does work on Ubuntu/debian based distros. I tried Ubuntu Mate 16.04 with an usb drive and i can confirm it works.
I tried to get sudo sensors detect and sudo pwmconfig but no luck. pwmconfig retuns;
Code: [Select]
/usr/bin/pwmconfig: There are no pwm-capable sensor modules installed
What can i do from this point?
Thanks.
My infos:
Code: [Select]
System:    Host: Peyloride-Manjaro Kernel: 4.4.8-1-MANJARO x86_64 (64 bit gcc: 5.3.0)
           Desktop: KDE Plasma 5.6.3 (Qt 5.6.0) Distro: Manjaro Linux
Machine:   System: Acer (portable) product: Aspire ES1-331 v: V1.11
           Mobo: Acer model: Aspire ES1-331 v: V1.11 Bios: Insyde v: V1.11 date: 08/12/2015
CPU:       Quad core Intel Celeron N3150 (-MCP-) cache: 1024 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 12805
           clock speeds: max: 2080 MHz 1: 2080 MHz 2: 2080 MHz 3: 1801 MHz 4: 1912 MHz
Graphics:  Card: Intel Device 22b1 bus-ID: 00:02.0
           Display Server: X.Org 1.17.4 driver: intel Resolution: 1366x768@60.01hz
           GLX Renderer: Mesa DRI Intel HD Graphics (Cherryview)
           GLX Version: 3.0 Mesa 11.2.1 Direct Rendering: Yes
Audio:     Card Intel Device 2284 driver: snd_hda_intel bus-ID: 00:1b.0 Sound: ALSA v: k4.4.8-1-MANJARO
Network:   Card-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
           driver: r8168 v: 8.040.00-NAPI port: 1000 bus-ID: 01:00.1
           IF: enp1s0f1 state: down mac: <filter>
           Card-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter driver: ath9k bus-ID: 02:00.0
Drives:    HDD Total Size: NA (-) ID-1: /dev/mmcblk0 model: N/A size: 31.3GB
Partition: ID-1: / size: 21G used: 13G (65%) fs: ext4 dev: /dev/mmcblk0p2
           ID-2: swap-1 size: 8.73GB used: 0.00GB (0%) fs: swap dev: /dev/mmcblk0p3
Sensors:   System Temperatures: cpu: 57.0C mobo: N/A
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 207 Uptime: 1 day Memory: 2862.6/3782.4MB Init: systemd Gcc sys: 5.3.0
           Client: Shell (zsh 5.2) inxi: 2.2.38
Code: [Select]
Linux Peyloride-Manjaro 4.4.8-1-MANJARO #1 SMP PREEMPT Thu Apr 21 00:21:08 UTC 2016 x86_64 GNU/Linux
I can provide any logs at request.
Offline crazyg4merz
  • Held Mitglied
  • Experience it, that's the way of learning!!
  • Branch: stable
  • Desktop: Gnome
  • GPU Card: Nvidia GTX 970
  • GPU driver: non-free
  • Kernel: Linux420-x64
  • Skill: Intermediate
Re: Fan not working
« Reply #1 on: 04. May 2016, 21:01:42 »
You're using custom built kernel? Try changing back to official kernel and see if it works?
Offline peynir
  • Neuling
  • Skill: Novice
Re: Fan not working
« Reply #2 on: 05. May 2016, 16:03:03 »
Thanks for reply but i do not use custom kernel. I did nothing to kernel actually, i use it like how it comes
Offline curiouseag
  • Sr. Mitglied
  • I'm new. Be nice!
  • Branch: stable
  • Desktop: undicieded
  • GPU Card: Intel Core i3-5010U
  • GPU driver: Intel
  • Kernel: grsec self build
  • Skill: Advanced
Re: Fan not working
« Reply #3 on: 05. May 2016, 16:13:24 »
sounds like a kernel config issue.
I need infos from the ubuntu kernel
Code: [Select]
cat /proc/config.gz > configor
Code: [Select]
zcat /proc/config.gz > config
and add the file here please.
Offline peynir
  • Neuling
  • Skill: Novice
Re: Fan not working
« Reply #4 on: 06. May 2016, 01:22:54 »
But there is an issue. There isn't a file named config.gz
Code: [Select]
zsh: no such file or directory: config
Offline Rob
  • Core Team
  • Alias: Korrode
  • Branch: Unstable
  • Desktop: Xfce+Compiz
  • GPU Card: nVidia GTX560Ti
  • Kernel: linux314 x64
  • Skill: Advanced
Re: Fan not working
« Reply #5 on: 06. May 2016, 01:35:15 »
Manjaro offers 10+ series of kernel, we even have the series' used in Ubuntu that Canonical maintain. You can install them from the Manjaro Settings Manager then reboot and select the one you want from the advanced options in the Grub boot menu.
Try some series other than 4.4.
Offline peynir
  • Neuling
  • Skill: Novice
Re: Fan not working
« Reply #6 on: 07. May 2016, 17:33:30 »
I can confirm fan is working again with kernel 4.5. Thanks everyone!
