Author Topic: [Solved] Wrong System Language in Desktop Environment  (Read 1443 times)
Offline Cedrik_K
  • Neuling
  • Be nice!
  • Branch: stable
  • Desktop: KDE Plasma
  • GPU Card: nVidia GTX 970
  • GPU driver: non-free driver
  • Skill: Novice
Good Evening,
i recently installed manjaro 15.12 on my laptop and installed some suggested language packages
with the manjaro settings manager. after the reboot parts of my desktop are in dutch.
I removed all langugae packages except the en_GB but that did not solve the problem.
So really love this country but how do i get  "Bescheden √∂ver Reedschappen" back to the normal output?
Thanks
« Last Edit: 04. May 2016, 22:07:29 by Cedrik_K »
Offline badbodh
  • Held Mitglied
  • Windows assumes I'm stupid, Linux proves it.
  • Branch: Testing
  • Desktop: Xfce, i3
  • GPU Card: Intel Mobile 4 Series
  • Kernel: linux41 64-bit
  • Skill: Intermediate
Re: Wrong System Language in Desktop Environment
« Reply #1 on: 03. May 2016, 01:08:15 »
share the contents of your /etc/locale.conf and /etc/environment
KDE may have its own language/regional settings module, check there too.
You can't feel the love till it hurts a little. Go rolling, go bleeding-edge !
Offline gohlip
  • Held Mitglied
  • Desktop: OpenBox
  • GPU Card: nvidia
  • GPU driver: nonfree
  • Kernel: linux46 - x64
« Reply #2 on: 03. May 2016, 06:00:09 »
At /etc/locale.gen
Uncomment what you want and comment out what you do not want.
Then at terminal,
Code: [Select]
# locale-genThen check with
Code: [Select]
$ localectl list-localesTo set system language, say "en_GB.utf8"
Code: [Select]
# localectl set-locale LANG="en_GB.utf8"
[edit] - Then only at kde settings (locale), do you modify whatever you want to set.
« Last Edit: 03. May 2016, 06:04:03 by gohlip »
Life is a sexually transmitted disease with a 100% mortality rate.
Offline Cedrik_K
  • Neuling
  • Be nice!
  • Branch: stable
  • Skill: Novice
« Reply #3 on: 04. May 2016, 21:21:04 »
hello again, i tried the Manjaro setting manager for switching and
reinstalling several languages - no success.
Using the command line like gohlip mentioned did also not work.
The content of /etc/locale.conf ist:
Code: [Select]
LANG=en_GB.UTF-8
LC_NUMERIC=de_DE.UTF-8
LC_TIME=de_DE.UTF-8
LC_MONETARY=de_DE.UTF-8
LC_PAPER=de_DE.UTF-8
LC_NAME=de_DE.UTF-8
LC_ADDRESS=de_DE.UTF-8
LC_TELEPHONE=de_DE.UTF-8
LC_MEASUREMENT=de_DE.UTF-8
LC_IDENTIFICATION=de_DE.UTF-8
The content of /etc/environment ist:
Code: [Select]
# This file is parsed by pam_env module
# Syntax: simple "KEY=VAL" pairs on separate lines
BROWSER=/usr/bin/xdg-open
Everything looks as it should be - to me.
But the Dutch is still there... spread over the entire system.
Offline Cedrik_K
  • Neuling
  • Be nice!
  • Branch: stable
  • Skill: Novice
Re: [Solved] Wrong System Language in Desktop Environment
« Reply #4 on: 04. May 2016, 22:10:40 »
Okay i found it .
Its hidden in the System settings -> Personalisation -> Regional Settings
A little bit tricky but it's there  ^-^
thanks.
