Author Topic: iso without plymouth ?  (Read 5004 times)
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • Desktop: i3, Deepin, Cinnamon
  • GPU Card: Intel ValleyView Gen7
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
  • Skill: Intermediate
Re: iso without plymouth ?
« Reply #15 on: 03. May 2016, 14:54:15 »
There is also something else going on at the moment:
https://github.com/manjaro/manjaro-tools/issues/208#issuecomment-216500091
But for me also xfce-minimal, which uses Plymouth does not work.
So, that your build with plymouth does work makes me think that your's is a different problem maybe... maybe not? ;)
i3 is also always without plymouth and I do like Chrysostomus. Normally there's no issue with that for me.
manjaro is addictive ::)
* manjaro-i3  * manjaro-cinnamon  * manjaro-deepin
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • GPU driver: nonfree
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #16 on: 03. May 2016, 15:02:23 »
I dit a git pull or  the profiles, but not changed manjaro-tools self. I always use an old 0.11.
I will search if i have an old profile on my external disk.  ;)
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #17 on: 03. May 2016, 16:17:44 »
Same problem with the 16.03 profile.  :( I think now to changes in the files called by manjaro-tools.
Offline Chrysostomus
  • Maintainer
  • Neckbeards are cool
    • Git
  • Branch: unstable
  • Desktop: Gnome, bspwm
  • GPU Card: Intel HD4000
  • GPU driver: free
  • Kernel: linux44-x64
« Reply #18 on: 03. May 2016, 16:45:04 »
Usually when I get into this kind of situation, I pick one of the working profiles and rebuild my own profile around it. That usually helps if I cannot find the actually cause of the problem.
Offline curiouseag
  • Sr. Mitglied
  • I'm new. Be nice!
  • Branch: stable
  • Desktop: undicieded
  • GPU Card: Intel Core i3-5010U
  • GPU driver: Intel
  • Kernel: grsec self build
  • Skill: Advanced
« Reply #19 on: 03. May 2016, 16:59:20 »
is it systemd related?
I bet openrc works. If so, it is a service file. Maybe missconfigured?
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #20 on: 03. May 2016, 17:09:02 »
What I did just above, but same problem. So, i can't study the differences.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #21 on: 03. May 2016, 17:15:40 »
With only  plymouth_boot=false in profile.conf :
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #22 on: 03. May 2016, 17:47:39 »
Wow ! We are absolutely no more free of plymouth :
Offline curiouseag
  • Sr. Mitglied
  • I'm new. Be nice!
  • Branch: stable
  • GPU driver: Intel
  • Skill: Advanced
« Reply #23 on: 03. May 2016, 17:54:45 »
edit the sddm service file and remove plymouth stuff
  • Maintainer
    • Git
  • Branch: unstable
  • GPU driver: free
« Reply #24 on: 03. May 2016, 17:57:43 »
Maybe you should study /var/lib/manjaro-tools/iso/... to see if the service file for plymouth exists in the image despite your settings. If so, you can manually delete it and rebuild the iso.
Plymouth needs to work
1) kernel parameter 'splash'
2) plymouth hook in mkinitcpio.conf
3) service file that integrates plymouth to displaymanager.
4) plymouth package installed
You most likely have one of these in your image. Having plymouth installed should not cause harm by itself, but without it there should be no service files for it. So I'm guessing you have 4 and one of the other three.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #25 on: 03. May 2016, 18:12:13 »
Tried (i removed the line "After"), but always black screen if I start sddm.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #26 on: 03. May 2016, 18:23:48 »
1) quiet net.iframes=0, so no
2) i did a search on /etc/mkinitcpio.conf, none
3) displaymanager -> sddm.service
4) no
but, as you can read on my capture, a lot of services depends on plymouth.
Offline artoo
  • OpenRC Team
  • Branch: Unstable
  • Desktop: LXQT/Plasma5, openrc & eudev
  • Kernel: x86_64
  • Skill: Advanced
« Reply #27 on: 03. May 2016, 18:28:27 »
I recall that it is the stupid sddm systemd unit file, that has a plymouth depend in it.
Other DMs deliver a separate plymouth service to start DM.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #28 on: 03. May 2016, 18:42:24 »
Cloned packages-extra and reinstalled manjaro-tools-git (0.11.5) -> same.
sddm is the recommended display manager for lxqt.
Offline artoo
  • OpenRC Team
  • Branch: Unstable
  • Kernel: x86_64
  • Skill: Advanced
« Reply #29 on: 03. May 2016, 18:56:56 »
Yes, its basically a package issue, or deployment issue of the unit file in sddm package.
Perhaps file a feature request upstream to include two separate unit files.
