Author Topic: PulseAudio dummy output and no sound issue after update  (Read 2348 times)
Offline linuxtopia
  • Neuling
  • I'm new. Be nice!
  • Branch: stable
  • Desktop: xfce
  • Skill: Novice
Re: PulseAudio dummy output and no sound issue after update
« Reply #15 on: 08. May 2016, 17:05:19 »
Yep I have found a solution for mine from Turkish Manjaro Forum by @ata. Thanks to him a lot.
Firstly run the command:
Code: [Select]
sudo rm /etc/asound.conf
Then:
Code: [Select]
alsamixer
F5 and push keyboard left/right arrow keys.
And then reboot the system hurray that would be work. Just opened the Pulse Audio Mixer and unmute volume then everyting worked properly. Thanks for all your help and advice.
*One final thing that I had uninstalled fluidsynth before all these work.
Offline qomo
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
« Reply #16 on: 17. June 2016, 08:39:13 »
still no sound .......
