Author Topic: Configuring Battery icon to show on panel  (Read 807 times)
Offline Shehriyar
  • Neuling
  • On the road to become an advanced Linux user.
  • Branch: Stable
  • Desktop: Bspwm
  • GPU Card: Intel HD Graphics
  • GPU driver: Free
  • Kernel: linux44-x64
  • Skill: Novice
« on: 02. May 2016, 17:28:55 »
Hi. My panel doesn't display the battery status. I checked the conkyrc file and saw that it was using BAT1. I checked my battery and it is BAT0. I tried to replace BAT1 with BAT0 but it didn't work. What am I supposed to do?
Offline Chrysostomus
  • Maintainer
  • Neckbeards are cool
    • Git
  • Branch: unstable
  • Desktop: Gnome, bspwm
  • GPU Card: Intel HD4000
  • GPU driver: free
  • Skill: Intermediate
Re: Configuring Battery icon to show on panel
« Reply #1 on: 02. May 2016, 17:52:48 »
First, determine if your panel is actually using that conky. Assuming its limepanel, check /usr/bin/limepanel. The latest version does not use conky. If that is what you have, then
1)
Code: [Select]
cp /usr/bin/limepanel to $HOME/.bin/mylimepanel2) make it executable with
Code: [Select]
chmod +x $HOME/.bin/mylimepanel3) replace BAT1 with BAT0 in $HOME/.bin/mylimepanel
Code: [Select]
sed -i s/BAT1/BAT0/g  $HOME/.bin/mylimepanel 4) edit your autostart to run mylimepanel instead of limepanel
Offline Shehriyar
  • Neuling
  • Branch: Stable
  • Desktop: Bspwm
  • GPU driver: Free
  • Skill: Novice
« Reply #2 on: 02. May 2016, 18:14:05 »
Thank you! It worked.
