Author Topic: Did a recent update break Steam?  (Read 1087 times)
Offline mr_bigmouth_502
  • Neuling
  • Linux n00b with several years experience
  • Desktop: KDE Plasma 5
  • GPU Card: 1GB Radeon R7 250X GHz Edition
  • GPU driver: open source Radeon driver
  • Kernel: Linux 4.4.x
  • Skill: Novice
« on: 30. April 2016, 05:03:59 »
Every time I try running Steam, I get this:
Code: [Select]
Running Steam on manjarolinux 16.06-pre2 64-bit
STEAM_RUNTIME is enabled automatically
Installing breakpad exception handler for appid(steam)/version(1459463254)
libGL error: unable to load driver: radeonsi_dri.so
libGL error: driver pointer missing
libGL error: failed to load driver: radeonsi
libGL error: unable to load driver: swrast_dri.so
libGL error: failed to load driver: swrast
Using the "purge libraries" shortcut does NOTHING for me. Strange, because it used to work just fine before.
Wat do? I'm at my wit's end here. :P
Offline ConsciousSun
  • Neuling
  • Skill: Advanced
Re: Did a recent update break Steam?
« Reply #1 on: 30. April 2016, 05:22:44 »
STEAM_RUNTIME=0 steam
works and I can run steam.
It's hard to know what's broken with steam though, a lot of games don't start and it's not clear if it's a game problem or a steam problem or some other problem.  Unturned hasn't worked in a month or two.
Offline Rob
  • Core Team
  • Alias: Korrode
  • Branch: Unstable
  • Desktop: Xfce+Compiz
  • GPU Card: nVidia GTX560Ti
  • GPU driver: non-free
  • Kernel: linux314 x64
  • Skill: Advanced
« Reply #2 on: 30. April 2016, 06:24:16 »
Reading update announcements is essential.
https://forum.manjaro.org/index.php?topic=33377.0
  • Neuling
  • Skill: Novice
« Reply #3 on: 30. April 2016, 16:53:45 »
I got this error after doing that:
Code: [Select]
You are missing the following 32-bit libraries, and Steam may not run:
libgtk-x11-2.0.so.0
libgdk_pixbuf-2.0.so.0
How would I install these?
Offline Orbmiser
  • Sr. Mitglied
  • Photographer / Techy Ole' Fart
  • Branch: Stable
  • Desktop: Netrunner Plasma 5
  • GPU Card: Ati 4350 Dual Displays
  • GPU driver: Free Open Driver
  • Kernel: 4.1.16-1
  • Skill: Novice
« Reply #4 on: 30. April 2016, 17:05:49 »
As mentioned reading the update announcement mentions.
Steam might not work due incompatiblity of libgpg. You my try followed command to "fix" it:
Code: [Select]
find ~/.steam/root/ -name "libgpg-error.so*" -print -delete
Offline Tids
  • Jr. Mitglied
  • Rawr :3
    • Telegram
  • Desktop: Plasma
  • GPU Card: Radeon R7 (APU AMD A8-760)
  • GPU driver: free
  • Kernel: x86_64
  • Skill: Intermediate
« Reply #5 on: 01. May 2016, 02:18:45 »
i always use
Code: [Select]
pacman -S steam-nativeand the "Steam (Native Libraries)" Launcher. Never had an issue with it. btw i cant even start the "normal" steam but i dont care :D
Manjaro б(>ε<)∂ Telegram - Steam - Hatchet
  • Neuling
  • Skill: Advanced
« Reply #6 on: 02. May 2016, 05:24:44 »
@Rob & @Orbmiser,
The OP's problem has been around a long time.
They should try @Tids suggestion.
Offline mips
  • Held Mitglied
  • Valkyrja
  • Branch: Testing
  • Desktop: XFCE
  • GPU Card: GTX 960
  • GPU driver: video-nvidia
  • Kernel: 3.16
« Reply #7 on: 02. May 2016, 23:15:55 »
Steam on linux always seem to have issues. I enjoy my gaming, I tried it on linux but decided to stick to gaming on windows as it just works better & most AAA titles are only available on windows anyway. Use the best tool for the job. My windows usage is 99.99% gaming only I should add.
Offline mandog
  • Held Mitglied
  • Architect Forum And G+ Forum Owner With Daniel S
  • Branch: All
  • Desktop: Gnome, Mate, E19, Openbox,FLuxbox,Budgie, XFCE openRC,
  • GPU Card: nvidia
  • GPU driver: Non Free
  • Kernel: latest
  • Skill: Advanced
« Reply #8 on: 03. May 2016, 01:21:01 »
I find it best to use the best tool for the job, if windows does a job better then I use it but that is only 5% of the time
A ENGLISHMAN IN PERU
I'm dyslexic Please do not complain about punctuation or spelling,
FANBOY,Taken from the urban dictionary
 A pathetic insult often used by fanboys themselves to try and put down people who don't like whatever it is they like.
  • Neuling
  • Skill: Novice
« Reply #9 on: 04. May 2016, 02:18:27 »
I managed to get it working by installing steam-native, then running it with "STEAM_RUNTIME=0 steam". Running it as just "steam" takes me back to square 1.
  • Neuling
  • Skill: Novice
« Reply #10 on: 08. May 2016, 05:56:55 »
Welp, it looks like I still have library issues running specific games, particularly Shadow Warrior Classic Redux, which I've been itching to play lately. Why are Steam and its games so insistent on using 32-bit libraries in 2016, when most of Steam's Linux users are on 64-bit systems? I'm going to see if reinstalling the OS helps, and maybe I'll look into running Steam from a 32-bit chroot.
