Author Topic: copy + paste files not working with Ctrl+c and Ctrl+v  (Read 1542 times)
Offline whytrytofly
  • Neuling
  • heya di heya ho!
  • Skill: Intermediate
« on: 29. April 2016, 12:25:05 »
Hello,
when trying to copy and paste with the key im used to which are Ctrls+c for copying and Ctrls+v for pasting in pcmanfm-qt, simply nothin happens. need to do that with the mouse. did i set something wrongly? im on the 16.04 version!
Offline whytrytofly
  • Neuling
  • heya di heya ho!
Re: copy + paste files not working with Ctrl+c and Ctrl+v
« Reply #1 on: 29. April 2016, 13:23:19 »
I just realized that its the same for deleting files!
Offline excalibur1234
  • Global Moderator
  • Branch: unstable
  • Desktop: net-minimal + LXQt
  • GPU driver: video-nouveau
  • Kernel: 4.6
« Reply #2 on: 29. April 2016, 14:55:41 »
interesting to see this problem on lxqt 0.10, too.
i am using the latest git build of lxqt and i am experiencing the same problem. i am relatively certain qt5.6 is the cause of this problem. it used to work perfectly in qt5.5.
qt5.6 is suppposed to be a LTS release...
it is also crazy to see ctrl+c and ctrl+v working in firefox and other non-qt applications.
also, i can copy and past between qterminal (with ctrl+shift+c) and firefox.
it is great to see the "ctrl+c" keyboard shorcut gone from pcmanfm-qt's menu. go to the edit menu --> copy. to the right of the word "copy" there should be a display of the keyboard shortcut for copying ("ctrl+c"). but that it gone. which means pcmanfm-qt and other qt applications only disply the working keyboard shortcuts.
overall, this is a really strange problem!
unfortunately, i do not have a solution or workaround. if you find one, please share it!
Need more information? Search here:   Manjaro Forum   |   Manjaro Wiki   |   Arch Wiki
Offline whytrytofly
  • Neuling
  • heya di heya ho!
« Reply #3 on: 29. April 2016, 15:17:48 »
:(...unfortunately thats a major drawback! well i could use pcmanfm instead, though it certianly is not what lxqt ams for!
Offline whytrytofly
  • Neuling
  • heya di heya ho!
« Reply #4 on: 29. April 2016, 15:24:19 »
well in fact thats a simple workaround for users that use lxqt on a daily basis! still an important issue to be considered. thanks for the quick answer
Offline eugen-b
  • Support Team
  • Branch: testing
  • Desktop: LXDE, Fluxbox, JWM, LXQt, bspwm
  • GPU Card: Intel 82945G/GZ
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #5 on: 29. April 2016, 16:34:34 »
Code: [Select]
Version         : 0.10.0-4
I don't have this issue on OpenRC.
MSI Wind Nettop, Intel Atom 230 1.6GHz (64bit), 2GB RAM
DEs: NET-minimal + (LXDE / Fluxbox / JWM); LXQt OpenRC
how to install on btrfs subvolumes
http://manjaro.github.io/donate/
  • Global Moderator
  • Branch: unstable
  • Kernel: 4.6
« Reply #6 on: 29. April 2016, 18:43:49 »
Code: [Select]
Version         : 0.10.0-4
do you have qt5.6 installed?
here is mine:
Code: [Select]
~ » pcmanfm-qt -v
(pcmanfm-qt:9285): Gtk-WARNING **: Im Modulpfad »adwaita« konnte keine Themen-Engine gefunden werden,
** (pcmanfm-qt:9285): WARNING **: XDG_TEMPLATES_DIR is set to invalid path, ignoring it
pcmanfm-qt 0.11.0
Offline eugen-b
  • Support Team
  • Branch: testing
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #7 on: 29. April 2016, 21:23:01 »
Yes, I have qt5.6
[2016-04-27 14:20] [ALPM] upgraded qt5-base (5.6.0-3 -> 5.6.0-4)
