Author Topic: Manjaro 16.06pre3 - 64 bit xfce Steam does not start  (Read 1363 times)
Offline fluxboxer
  • Neuling
  • I'm new. Be nice!
  • Desktop: Fluxbox
  • GPU Card: Intel HD Graphics 5500 (Broadwell GT2) and NVIDIA GM108M [GeForce 840M]
  • GPU driver: Bumblebee non-free
  • Kernel: x86_64 Linux 4.1.15-1-MANJARO
  • Skill: Advanced
« on: 28. April 2016, 21:49:12 »
After installing Manjaro 16.06pre3 - 64 Bit xfce Steam does not start
Starting  primusrun steam  affects the following messsages:
[ ~]$ primusrun steam
Running Steam on manjarolinux 16.06-pre3 64-bit
STEAM_RUNTIME is enabled automatically
Installing breakpad exception handler for appid(steam)/version(1459463254)
libGL error: unable to load driver: i965_dri.so
libGL error: driver pointer missing
libGL error: failed to load driver: i965
libGL error: unable to load driver: swrast_dri.so
libGL error: failed to load driver: swrast
Fontconfig error: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 72: non-double matrix element
Fontconfig warning: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 80: saw unknown, expected number
[0428/213851:ERROR:main_delegate.cc(777)] Could not load cef_extensions.pak
[0428/213851:ERROR:browser_main_loop.cc(203)] Running without the SUID sandbox! See https://code.google.com/p/chromium/wiki/LinuxSUIDSandboxDevelopment for more information on developing with the sandbox on.
Installing breakpad exception handler for appid(steamwebhelper)/version(20160331191033)
Installing breakpad exception handler for appid(steamwebhelper)/version(1459451433)
Installing breakpad exception handler for appid(steamwebhelper)/version(1459463254)
Created shared memory when not owner SteamController_Shared_mem
** (steam:30869): WARNING **: Unknown device type 14
** (steam:30869): WARNING **: Could not create object for /org/freedesktop/NetworkManager/Devices/1: unknown object type
Steam: An X Error occurred
X Error of failed request:  GLXBadContext
Major opcode of failed request:  154
Serial number of failed request:  33
xerror_handler: X failed, continuing
X Error of failed request:  BadValue (integer parameter out of range for operation)
Value in failed request:  0x0
Serial number of failed request:  32
primus: fatal: failed to acquire direct rendering context for display thread
** (steam:30869): WARNING **: Ignoring invalid property 'autoconnect-priority'
** (steam:30869): WARNING **: Ignoring invalid property 'secondaries'
** (steam:30869): WARNING **: Ignoring invalid property 'route-data'
** (steam:30869): WARNING **: Ignoring invalid property 'address-data'
What can i do ??
Offline Strit
  • Maintainer
  • Manjaro Torrent Maintainer
    • Strits.dk
  • Branch: Stable
  • Desktop: XFCE
  • GPU Card: GTX 760 OC
  • GPU driver: Non-free nvidia 361
  • Kernel: 4.4.8-1-MANJARO
  • Skill: Intermediate
Re: Manjaro 16.06pre3 - 64 bit xfce Steam does not start
« Reply #1 on: 29. April 2016, 14:49:11 »
Looks like it's trying to load the intel driver (i965).
Do you have the intel driver installed?
Sorry, didn't see you used primusrun. Is it set up correctly?
Desktop PC: Manjaro XFCE 15.12 (stable, kernel 4.4)
Private Laptop: Manjaro Strit 16.03 (unstable, kernel 4.6)
Work Laptop: Manjaro Strit 16.03 (stable, kernel 4.4)
Netbook: Arch Linux XFCE/LXqt (i686, kernel 4.0)
Offline fluxboxer
  • Neuling
  • I'm new. Be nice!
  • Desktop: Fluxbox
  • Skill: Advanced
« Reply #2 on: 29. April 2016, 21:48:58 »
the driver (bublebee) Intel + Nvidia works correct if i Start other Programs with primusrun
└─> primusrun inxi -G
Graphics:  Card-1: Intel Broadwell-U Integrated Graphics
           Card-2: NVIDIA GM108M [GeForce 840M]
           Display Server: X.Org 1.17.4 driver: intel
           Resolution: 1366x768@60.00hz, 1024x768@75.08hz
           GLX Renderer: GeForce 840M/PCIe/SSE2
           GLX Version: 4.5.0 NVIDIA 361.42
with 2 Montiors
only Steam will not start.
Offline tomahna
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
« Reply #3 on: 30. April 2016, 20:48:56 »
Have you tried deleting steam runtime libraries ?
find ~/.steam/root/ \( -name "libgcc_s.so*" -o -name "libstdc++.so*" -o -name "libxcb.so*" -o -name "libgpg-error.so*" \) -print -delete
Source : https://wiki.archlinux.org/index.php/Steam/Troubleshooting#Deleting_the_runtime_libraries
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • GPU driver: non-free
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
« Reply #4 on: 06. May 2016, 14:52:27 »
In unstable branch we have a newer steam package ...
Offline jonathon
  • Core Team
  • Technologist - Teacher - Tea drinker
  • Branch: Unstable
  • Desktop: MATE 1.14
  • GPU Card: Nvidia GTX680M
  • GPU driver: Bumblebee nvidia+intel
  • Kernel: 4.6.0-*-MANJARO x86_64
  • Skill: Advanced
« Reply #5 on: 06. May 2016, 21:00:56 »
The "better" way so you don't have to do this each and every time the Steam client updates would be to change your launcher command:
env LD_PRELOAD='/usr/$LIB/libstdc++.so.6 /usr/$LIB/libgcc_s.so.1 /usr/$LIB/libxcb.so.1 /usr/$LIB/libgpg-error.so' /usr/bin/steam %U
This particular issue is due to the newer libgpg in Arch.
« Last Edit: 06. May 2016, 21:05:11 by jonathon »
MSI GT70: Core i7-3630QM, 16GB, Nvidia GTX680M, Intel 2230, Manjaro-MATE-amd64-EFI
Lenovo X230: Core i5-3320M, 4GB, Intel HD4000, Intel 6205, Manjaro-MATE-amd64
Dell Studio 1749: Core i5 540, 8GB, ATi HD5650, Intel WLAN, Manjaro-Xfce-amd64
Let's go in the garden; you'll find something waiting.
