Author Topic: volume resets to 100% on start up  (Read 826 times)
Offline jrasmussen
  • Jr. Mitglied
  • I'm new. Be nice!
  • Branch: stable
  • Desktop: Cinnamon
  • Kernel: linux44
  • Skill: Novice
« on: 27. April 2016, 22:56:19 »
Hi,
I'm wondering if there is a way to set/configure the default sound setting (or have the last setting remembered).  Mine seems to always start at 100%...which is much too loud.
Thanks,
John
Offline badbodh
  • Held Mitglied
  • Windows assumes I'm stupid, Linux proves it.
  • Branch: Testing
  • Desktop: Xfce, i3
  • GPU Card: Intel Mobile 4 Series
  • Kernel: linux41 64-bit
  • Skill: Intermediate
Re: volume resets to 100% on start up
« Reply #1 on: 28. April 2016, 00:55:01 »
add the following command to your cinnamon settings > startup programs
Code: [Select]
pactl set-sink-volume 0 50%it will set your default audio device (0) to 50% at login. Change 0 to another sink number to set another audio device to 50%.
Run
Code: [Select]
pactl list|grep Sink to see which device has what sink number.
« Last Edit: 28. April 2016, 00:58:16 by badbodh »
You can't feel the love till it hurts a little. Go rolling, go bleeding-edge !
Offline jrasmussen
  • Jr. Mitglied
  • I'm new. Be nice!
  • Branch: stable
  • Desktop: Cinnamon
  • Kernel: linux44
  • Skill: Novice
« Reply #2 on: 28. April 2016, 00:58:31 »
Thanks!  I will give that a try.
Code: [Select]
Run
Code: [Select]
pactl list|grep Sink to see which.
Offline jrasmussen
  • Jr. Mitglied
  • I'm new. Be nice!
  • Branch: stable
  • Desktop: Cinnamon
  • Kernel: linux44
  • Skill: Novice
« Reply #3 on: 29. April 2016, 21:30:40 »
Just in case this is helpful for anyone else with this issue...in my case, I discovered it seemed to be linked to the Enpass password manager which I have set to autostart.  When I went into the Enpass settings and unchecked the "Unlock Feedback" option (which plays a sound when unlocking the keychain), that has solved my problem.  Volume now remains where I left it last on start up.
Offline badbodh
  • Held Mitglied
  • Branch: Testing
  • Desktop: Xfce, i3
« Reply #4 on: 29. April 2016, 21:49:50 »
then you should notify enpass developers about this bug
Offline jrasmussen
  • Jr. Mitglied
  • I'm new. Be nice!
  • Branch: stable
  • Desktop: Cinnamon
  • Kernel: linux44
  • Skill: Novice
« Reply #5 on: 29. April 2016, 22:03:22 »
Thanks, I hadn't thought of that but will certainly let them know.
