Author Topic: LightDM does not start after 2016-04-26 Update [FIX]  (Read 6126 times)
Offline aaditya
  • OpenRC Team
    • My Website
  • Branch: Testing
  • Desktop: Xfce, Openbox
  • GPU Card: Intel HD 4000
  • Kernel: Linux 4.4 x86_64
  • Skill: Intermediate
Re: LightDM does not start after 2016-04-26 Update
« Reply #60 on: 11. May 2016, 06:12:00 »
Thanks @Rob.
Fix from oberon2007
Also it works if it is applied before reboot the VM.
only updating did not work for me either, but commenting out the lines as given in the post above worked.
Offline v17564
  • Vollwertiges Mitglied
  • I'm new. Be nice!
  • Skill: Novice
« Reply #61 on: 18. May 2016, 13:23:05 »
Hello @aaditya.
Only the update don't work. You should aplly the fix, comment lines in the file /etc/X11/xorg.conf.d/90-mhwd.conf, for that VM start ijn graphic mode.
You can aplly before reboot or after reboot. If you aplly after reboot, you need open a console with ALT+F2, etc, like oberon2007 say.
