Author Topic: LightDM does not start after 2016-04-26 Update [FIX]  (Read 6110 times)
Offline Holmes
  • Mirror Support Team
  • Brazilian and Hispanic Support Team
    • Manjaro Brasil
  • Branch: Stable
  • Desktop: Manjaro XFCE
  • GPU Card: Mobile Intel (R) 945
  • GPU driver: Non-free
  • Kernel: kernellinux
  • Skill: Novice
Re: LightDM does not start after 2016-04-26 Update
« Reply #15 on: 29. April 2016, 01:07:24 »
Change to sddm it is qt based...................
Code: [Select]
sudo pacman -S sddm-consolekit
https://wiki.gentoo.org/wiki/SDDM
vlw fwi, Holmes :)
==> Manjaro Brasil I Manjaro Hispano
==> IRC Manjaro Brasil: #manjaro-br I IRC Manjaro Hispano: #manjaro-es
Offline xircon
  • Held Mitglied
  • Branch: Unstable
  • Desktop: Plasma
  • GPU Card: Intel 4th gen
  • GPU driver: free
  • Kernel: Always the newest!
  • Skill: Advanced
« Reply #16 on: 29. April 2016, 01:11:04 »
But did it work?
Offline Holmes
    • Manjaro Brasil
  • Branch: Stable
  • Skill: Novice
« Reply #17 on: 29. April 2016, 03:10:33 »
not work sddm in Manjaro JWM OpenRC
vlw fwi, Holmes :)
« Last Edit: 29. April 2016, 03:21:33 by Holmes »
Offline thrasymachus
  • Neuling
  • I'm new. Be nice!
  • Desktop: Awesome WM
  • Skill: Intermediate
« Reply #18 on: 29. April 2016, 03:50:23 »
same result for me too, sddm gives the same blank hung screen, xdm has crashed
Offline aaditya
  • OpenRC Team
    • My Website
  • Branch: Testing
  • Desktop: Xfce, Openbox
  • GPU Card: Intel HD 4000
  • Kernel: Linux 4.4 x86_64
« Reply #19 on: 29. April 2016, 05:22:07 »
You guys could give lxdm-consolekit from the aur a try too, it is gtk2 based.
Code: [Select]
yaourt -S lxdm-consolekitAnd edit /etc/conf.d/xdm to set displaymanager=lxdm
I will try to update my system on sunday and see if i can replicate this lightdm issue.
Offline Rob
  • Core Team
  • Alias: Korrode
  • Branch: Unstable
  • Desktop: Xfce+Compiz
  • GPU Card: nVidia GTX560Ti
  • GPU driver: non-free
  • Kernel: linux314 x64
  • Skill: Advanced
« Reply #20 on: 29. April 2016, 06:26:20 »
Hows about someone post their Xorg.0.log so we can read the actual errors.
Offline aaditya
  • OpenRC Team
    • My Website
  • Branch: Testing
« Reply #21 on: 29. April 2016, 06:44:53 »
Good point, and also lightdm logs in /var/log/lightdm if they exist.
  • Neuling
  • I'm new. Be nice!
« Reply #22 on: 29. April 2016, 07:45:26 »
beyond the first post, which shows that xdm is crashing?
and rc-status lists xdm as having crashed
Offline v17564
  • Vollwertiges Mitglied
  • I'm new. Be nice!
  • Skill: Novice
« Reply #23 on: 29. April 2016, 09:58:59 »
Hello @aaditya and all the other.
Is a large post.
lxdm
Before update lxdm work. After update don't work, see images attachment.
errors.log
Code: [Select]
Apr 29 09:17:19 manjaro /etc/init.d/xdm[7814]: start-stop-daemon: no matching processes found
Apr 29 09:25:15 manjaro /etc/init.d/xdm[3208]: start-stop-daemon: no matching processes found
Apr 29 09:27:53 manjaro /etc/init.d/xdm[2634]: start-stop-daemon: no matching processes found
lxdm.log
Code: [Select]
** Message: find greeter (nil)
** Message: find idle (nil)
** Message: 1461914741: add xserver watch
X.Org X Server 1.17.4
Release Date: 2015-10-28
Build Operating System: Linux 4.2.5-1-ARCH x86_64
Current Operating System: Linux manjaro 4.4.8-1-MANJARO #1 SMP PREEMPT Thu Apr 21 00:21:08 UTC 2016 x86_64
Kernel command line: BOOT_IMAGE=/vmlinuz-4.4-x86_64 root=UUID=d467ee8c-1fbf-4096-b022-c5f7bb40ba96 rw ipv6.disable=1 resume=UUID=95041a69-c44e-43dd-9a2c-2e2511f5dd17
Build Date: 01 November 2015  10:36:50AM
Current version of pixman: 0.34.0
Before reporting problems, check http://wiki.x.org
Markers: (--) probed, (**) from config file, (==) default setting,
(==) Log file: "/var/log/Xorg.0.log", Time: Fri Apr 29 09:25:41 2016
(==) Using config directory: "/etc/X11/xorg.conf.d"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
(EE)
Fatal server error:
(EE) no screens found(EE)
(EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
 for help.
(EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
(EE)
(EE) Server terminated with error (1). Closing log file.
** Message: 1461914747: start xserver in 100 retry
** Message: exit cb
** Message: free session
Xorg.0.log
Code: [Select]
[    83.070]
[    83.070] X Protocol Version 11, Revision 0
[    83.070] Build Operating System: Linux 4.2.5-1-ARCH x86_64
[    83.070] Current Operating System: Linux manjaro 4.4.8-1-MANJARO #1 SMP PREEMPT Thu Apr 21 00:21:08 UTC 2016 x86_64
[    83.070] Kernel command line: BOOT_IMAGE=/vmlinuz-4.4-x86_64 root=UUID=d467ee8c-1fbf-4096-b022-c5f7bb40ba96 rw ipv6.disable=1 resume=UUID=95041a69-c44e-43dd-9a2c-2e2511f5dd17
[    83.070] Build Date: 01 November 2015  10:36:50AM
[    83.098]
[    83.098] Current version of pixman: 0.34.0
[    83.098] Before reporting problems, check http://wiki.x.org
[    83.098] Markers: (--) probed, (**) from config file, (==) default setting,
[    83.098] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Apr 29 09:26:50 2016
[    83.099] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    83.099] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    83.099] (==) No Layout section.  Using the first Screen section.
[    83.099] (==) No screen section available. Using defaults.
[    83.099] (**) |-->Screen "Default Screen Section" (0)
[    83.099] (**) |   |-->Monitor "<default monitor>"
[    83.099] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[    83.099] (**) |   |-->Device "Device0"
[    83.099] (==) No monitor specified for screen "Default Screen Section".
[    83.099] (==) Automatically adding devices
[    83.099] (==) Automatically enabling devices
[    83.099] (==) Automatically adding GPU devices
[    83.099] (WW) The directory "/usr/share/fonts/Type1/" does not exist.
[    83.099] Entry deleted from font path.
[    83.099] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi/".
[    83.099] (Run 'mkfontdir' on "/usr/share/fonts/100dpi/").
[    83.099] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi/".
[    83.099] (Run 'mkfontdir' on "/usr/share/fonts/75dpi/").
[    83.099] (==) FontPath set to:
/usr/share/fonts/misc/,
/usr/share/fonts/TTF/,
/usr/share/fonts/OTF/
[    83.099] (==) ModulePath set to "/usr/lib/xorg/modules"
[    83.099] (**) Extension "Composite" is enabled
[    83.099] (**) Extension "RENDER" is enabled
[    83.099] (==) |-->Input Device "Mouse0"
[    83.099] (==) No Layout section. Using the first core pointer device.
[    83.099] (II) The server relies on udev to provide the list of input devices.
[    83.099] (II) Loader magic: 0x817d60
[    83.099] (II) Module ABI versions:
[    83.099] X.Org ANSI C Emulation: 0.4
[    83.099] X.Org Video Driver: 19.0
[    83.099] X.Org XInput driver : 21.1
[    83.099] X.Org Server Extension : 9.0
[    83.101] (EE) systemd-logind: failed to get session: The name org.freedesktop.login1 was not provided by any .service files
[    83.101] (II) xfree86: Adding drm device (/dev/dri/card0)
[    83.165] (--) PCI:*(0:0:2:0) 80ee:beef:0000:0000 rev 0, Mem @ 0xe0000000/134217728
[    83.166] (II) Open ACPI successful (/var/run/acpid.socket)
[    83.166] (II) LoadModule: "glx"
[    83.166] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    83.167] (II) Module glx: vendor="X.Org Foundation"
[    83.167] compiled for 1.17.4, module version = 1.0.0
[    83.167] ABI class: X.Org Server Extension, version 9.0
[    83.167] (==) AIGLX enabled
[    83.167] (II) LoadModule: "vboxvideo"
[    83.167] (II) Loading /usr/lib/xorg/modules/drivers/vboxvideo.so
[    83.167] (II) Module vboxvideo: vendor="Oracle Corporation"
[    83.167] compiled for 1.17.4, module version = 1.0.1
[    83.167] Module class: X.Org Video Driver
[    83.167] ABI class: X.Org Video Driver, version 19.0
[    83.167] (**) Load address of symbol "VBOXVIDEO" is 0x7fa7c7713380
[    83.167] (II) LoadModule: "vboxmouse"
[    83.168] (WW) Warning, couldn't open module vboxmouse
[    83.168] (II) UnloadModule: "vboxmouse"
[    83.168] (II) Unloading vboxmouse
[    83.168] (EE) Failed to load module "vboxmouse" (module does not exist, 0)
[    83.168] (II) VBoxVideo: guest driver for VirtualBox: vbox
[    83.168] (++) using VT number 1
[    83.168] (--) controlling tty is VT number 1, auto-enabling KeepTty
[    83.168] (II) vboxvideo: kernel driver found, not loading.
[    83.168] (EE) No devices detected.
[    83.168] (EE)
Fatal server error:
[    83.168] (EE) no screens found(EE)
[    83.168] (EE)
 for help.
[    83.168] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[    83.168] (EE)
Logs
Please read my post « Reply #9 on: Yesterday at 19:49:36 »
There are no logs
About philm post
He write over icon theme that don't support GTK version 3.20. Copy and paste from philm post:
Quote
With this we updated Gnome and GTK to 3.20. This will break most of the themes, which will be fixed if and when their developers decide to update them. Some GTK 3.20-compliant themes are ready now - see further down this post.
More copy and paste:
Quote
The new default Manjaro GTK theme, which is GTK 3.20 compatible, is Vertex-Maia
You can install it with:
sudo pacman -Sy vertex-maia-themes vertex-maia-icon-theme xcursor-maia
Then select it in your environment's appearance/theme settings area.
In Xfce in "menu -> configure -> appearance" only can change four things: style, icons, letter type and configuration.
Philm don't write about LightDM Greeter Theme, only write that "will break most of the themes" and not on lightdm not start. They are two very different things, i think.
Xorg.0.log with LightDM
Before apply updates
Code: [Select]
[    46.877]
[    46.877] X Protocol Version 11, Revision 0
[    46.877] Build Operating System: Linux 4.2.5-1-ARCH x86_64
[    46.877] Current Operating System: Linux manjaro 4.4.6-1-MANJARO #1 SMP PREEMPT Sat Mar 19 06:00:37 CET 2016 x86_64
[    46.877] Kernel command line: BOOT_IMAGE=/vmlinuz-4.4-x86_64 root=UUID=d467ee8c-1fbf-4096-b022-c5f7bb40ba96 rw ipv6.disable=1 resume=UUID=95041a69-c44e-43dd-9a2c-2e2511f5dd17
[    46.877] Build Date: 01 November 2015  10:36:50AM
[    46.877]
[    46.877] Current version of pixman: 0.34.0
[    46.877] Before reporting problems, check http://wiki.x.org
[    46.877] Markers: (--) probed, (**) from config file, (==) default setting,
[    46.877] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Apr 29 08:13:01 2016
[    46.877] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    46.877] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    46.877] (==) No Layout section.  Using the first Screen section.
[    46.877] (==) No screen section available. Using defaults.
[    46.877] (**) |-->Screen "Default Screen Section" (0)
[    46.877] (**) |   |-->Monitor "<default monitor>"
[    46.877] (==) No device specified for screen "Default Screen Section".
[    46.877] (**) |   |-->Device "Device0"
[    46.877] (==) No monitor specified for screen "Default Screen Section".
[    46.877] (==) Automatically adding devices
[    46.877] (==) Automatically enabling devices
[    46.877] (==) Automatically adding GPU devices
[    46.877] (WW) The directory "/usr/share/fonts/Type1/" does not exist.
[    46.877] Entry deleted from font path.
[    46.877] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi/".
[    46.877] (Run 'mkfontdir' on "/usr/share/fonts/100dpi/").
[    46.877] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi/".
[    46.877] (Run 'mkfontdir' on "/usr/share/fonts/75dpi/").
[    46.877] (==) FontPath set to:
[    46.877] (==) ModulePath set to "/usr/lib/xorg/modules"
[    46.877] (**) Extension "Composite" is enabled
[    46.877] (**) Extension "RENDER" is enabled
[    46.877] (==) |-->Input Device "Mouse0"
[    46.877] (==) No Layout section. Using the first core pointer device.
[    46.877] (II) The server relies on udev to provide the list of input devices.
[    46.877] (II) Loader magic: 0x817d60
[    46.877] (II) Module ABI versions:
[    46.877] X.Org ANSI C Emulation: 0.4
[    46.877] X.Org Video Driver: 19.0
[    46.877] X.Org XInput driver : 21.1
[    46.877] X.Org Server Extension : 9.0
[    46.878] (EE) systemd-logind: failed to get session: The name org.freedesktop.login1 was not provided by any .service files
[    46.878] (II) xfree86: Adding drm device (/dev/dri/card0)
[    46.881] (--) PCI:*(0:0:2:0) 80ee:beef:0000:0000 rev 0, Mem @ 0xe0000000/134217728
[    46.882] (II) Open ACPI successful (/var/run/acpid.socket)
[    46.882] (II) LoadModule: "glx"
[    46.882] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    46.883] (II) Module glx: vendor="X.Org Foundation"
[    46.883] compiled for 1.17.4, module version = 1.0.0
[    46.883] ABI class: X.Org Server Extension, version 9.0
[    46.883] (==) AIGLX enabled
[    46.883] (II) LoadModule: "vboxvideo"
[    46.883] (II) Loading /usr/lib/xorg/modules/drivers/vboxvideo.so
[    46.883] (II) Module vboxvideo: vendor="Oracle Corporation"
[    46.883] compiled for 1.17.4, module version = 1.0.1
[    46.883] Module class: X.Org Video Driver
[    46.883] ABI class: X.Org Video Driver, version 19.0
[    46.883] (**) Load address of symbol "VBOXVIDEO" is 0x7fd7695cd3e0
[    46.883] (II) LoadModule: "vboxmouse"
[    46.884] (WW) Warning, couldn't open module vboxmouse
[    46.884] (II) UnloadModule: "vboxmouse"
[    46.884] (II) Unloading vboxmouse
[    46.884] (EE) Failed to load module "vboxmouse" (module does not exist, 0)
[    46.884] (II) VBoxVideo: guest driver for VirtualBox: vbox
[    46.884] (++) using VT number 7
[    46.884] (II) VBoxVideo(0): VirtualBox guest additions video driver version 5.0.16_OSEr105871
[    46.884] (II) Loading sub module "ramdac"
[    46.884] (II) LoadModule: "ramdac"
[    46.884] (II) Module "ramdac" already built-in
[    46.884] (II) Loading sub module "fb"
[    46.884] (II) LoadModule: "fb"
[    46.884] (II) Loading /usr/lib/xorg/modules/libfb.so
[    46.884] (II) Module fb: vendor="X.Org Foundation"
[    46.884] compiled for 1.17.4, module version = 1.0.0
[    46.884] ABI class: X.Org ANSI C Emulation, version 0.4
[    46.884] (II) Loading sub module "shadowfb"
[    46.884] (II) LoadModule: "shadowfb"
[    46.884] (II) Loading /usr/lib/xorg/modules/libshadowfb.so
[    46.884] (II) Module shadowfb: vendor="X.Org Foundation"
[    46.884] (II) Loading sub module "vgahw"
[    46.884] (II) LoadModule: "vgahw"
[    46.884] (II) Loading /usr/lib/xorg/modules/libvgahw.so
[    46.884] (II) Module vgahw: vendor="X.Org Foundation"
[    46.884] compiled for 1.17.4, module version = 0.1.0
[    46.884] ABI class: X.Org Video Driver, version 19.0
[    46.884] (II) Loading sub module "dri2"
[    46.884] (II) LoadModule: "dri2"
[    46.884] (II) Module "dri2" already built-in
[    46.884] (II) VBoxVideo(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[    46.884] (==) VBoxVideo(0): Depth 24, (--) framebuffer bpp 32
[    46.884] (--) VBoxVideo(0): Virtual size is 32766x32766 (pitch 32766)
[    46.884] (**) VBoxVideo(0):  Built-in mode "800x600": 29.3 MHz (scaled from 0.0 MHz), 36.4 kHz, 60.0 Hz
[    46.884] (II) VBoxVideo(0): Modeline "800x600"x0.0   29.31  800 802 804 806  600 602 604 606 (36.4 kHz b)
[    46.884] (II) VBoxVideo(0): vgaHWGetIOBase: hwp->IOBase is 0x03d0
[    46.884] (==) VBoxVideo(0): RGB weight 888
[    46.884] (==) VBoxVideo(0): Default visual is TrueColor
[    46.884] (==) VBoxVideo(0): Using gamma correction (1.0, 1.0, 1.0)
[    46.884] (==) VBoxVideo(0): DPI set to (96, 96)
[    46.884] (--) Depth 24 pixmap format is 32 bpp
[    46.888] (II) VBoxVideo(0): [DRI2] Setup complete
[    46.888] (II) VBoxVideo(0): [DRI2]   DRI driver: vboxvideo
[    46.910] (II) VBoxVideo(0): Requested monitor count: 1
[    46.910] (II) VBoxVideo(0): Output VGA-0 has no monitor section
[    46.910] (II) VBoxVideo(0): Printing probed modes for output VGA-0
[    46.910] (II) VBoxVideo(0): Modeline "800x600"x60.0   29.31  800 802 804 806  600 602 604 606 (36.4 kHz Pb)
[    46.910] (II) VBoxVideo(0): Modeline "2560x1600"x60.0  247.26  2560 2562 2564 2566  1600 1602 1604 1606 (96.4 kHz b)
[    46.910] (II) VBoxVideo(0): Modeline "2560x1440"x60.0  222.63  2560 2562 2564 2566  1440 1442 1444 1446 (86.8 kHz b)
[    46.910] (II) VBoxVideo(0): Modeline "2048x1536"x60.0  190.04  2048 2050 2052 2054  1536 1538 1540 1542 (92.5 kHz b)
[    46.910] (II) VBoxVideo(0): Modeline "1920x1600"x60.0  185.59  1920 1922 1924 1926  1600 1602 1604 1606 (96.4 kHz b)
[    46.910] (II) VBoxVideo(0): Modeline "1920x1080"x60.0  125.50  1920 1922 1924 1926  1080 1082 1084 1086 (65.2 kHz b)
[    46.910] (II) VBoxVideo(0): Modeline "1600x1200"x60.0  116.21  1600 1602 1604 1606  1200 1202 1204 1206 (72.4 kHz b)
[    46.910] (II) VBoxVideo(0): Modeline "1680x1050"x60.0  106.82  1680 1682 1684 1686  1050 1052 1054 1056 (63.4 kHz b)
[    46.910] (II) VBoxVideo(0): Modeline "1400x1050"x60.0   89.08  1400 1402 1404 1406  1050 1052 1054 1056 (63.4 kHz b)
[    46.910] (II) VBoxVideo(0): Modeline "1280x1024"x60.0   79.47  1280 1282 1284 1286  1024 1026 1028 1030 (61.8 kHz b)
[    46.910] (II) VBoxVideo(0): Modeline "1024x768"x60.0   47.83  1024 1026 1028 1030  768 770 772 774 (46.4 kHz b)
[    46.910] (II) VBoxVideo(0): Modeline "800x600"x60.0   29.31  800 802 804 806  600 602 604 606 (36.4 kHz b)
[    46.910] (II) VBoxVideo(0): Modeline "640x480"x60.0   18.84  640 642 644 646  480 482 484 486 (29.2 kHz b)
[    46.910] (II) VBoxVideo(0): Output VGA-0 connected
[    46.910] (II) VBoxVideo(0): Using exact sizes for initial modes
[    46.910] (II) VBoxVideo(0): Output VGA-0 using initial mode 800x600
[    46.910] (II) VBoxVideo(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[    46.910] (II) VBoxVideo(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[    46.910] (==) VBoxVideo(0): DPMS enabled
[    46.910] (--) RandR disabled
[    46.914] (II) Next line is added to allow vboxvideo_drv.so to appear as whitelisted driver
[    46.914] (II) The file referenced, is *NOT* loaded
[    46.914] (II) Loading /usr/lib/xorg/modules/drivers//ati_drv.so
[    46.914] (EE) AIGLX error: vboxvideo does not export required DRI extension
[    46.914] (EE) AIGLX: reverting to software rendering
[    46.932] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[    46.932] (II) AIGLX: Loaded and initialized swrast
[    46.932] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[    46.932] (II) VBoxVideo(0): Setting screen physical size to 211 x 158
[    47.066] (II) LoadModule: "vboxmouse"
[    47.066] (WW) Warning, couldn't open module vboxmouse
[    47.066] (II) UnloadModule: "vboxmouse"
[    47.066] (II) Unloading vboxmouse
[    47.066] (EE) Failed to load module "vboxmouse" (module does not exist, 0)
[    47.066] (EE) No input driver matching `vboxmouse'
[    47.067] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[    47.067] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    47.067] (**) Power Button: Applying InputClass "system-keyboard"
[    47.067] (**) Power Button: Applying InputClass "Keyboard Defaults"
[    47.067] (II) LoadModule: "evdev"
[    47.067] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    47.067] (II) Module evdev: vendor="X.Org Foundation"
[    47.067] compiled for 1.17.4, module version = 2.10.1
[    47.067] Module class: X.Org XInput Driver
[    47.067] ABI class: X.Org XInput driver, version 21.1
[    47.067] (II) Using input driver 'evdev' for 'Power Button'
[    47.067] (**) Power Button: always reports core events
[    47.067] (**) evdev: Power Button: Device: "/dev/input/event2"
[    47.067] (--) evdev: Power Button: Vendor 0 Product 0x1
[    47.067] (--) evdev: Power Button: Found keys
[    47.067] (II) evdev: Power Button: Configuring as keyboard
[    47.067] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event2"
[    47.067] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    47.067] (**) Option "xkb_rules" "evdev"
[    47.067] (**) Option "xkb_model" "pc105"
[    47.067] (**) Option "xkb_layout" "es"
[    47.067] (WW) Option "xkb_variant" requires a string value
[    47.067] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    47.088] (II) config/udev: Adding input device Sleep Button (/dev/input/event3)
[    47.088] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[    47.088] (**) Sleep Button: Applying InputClass "system-keyboard"
[    47.088] (**) Sleep Button: Applying InputClass "Keyboard Defaults"
[    47.088] (II) Using input driver 'evdev' for 'Sleep Button'
[    47.088] (**) Sleep Button: always reports core events
[    47.088] (**) evdev: Sleep Button: Device: "/dev/input/event3"
[    47.088] (--) evdev: Sleep Button: Vendor 0 Product 0x3
[    47.088] (--) evdev: Sleep Button: Found keys
[    47.088] (II) evdev: Sleep Button: Configuring as keyboard
[    47.088] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSLPBN:00/input/input4/event3"
[    47.088] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 7)
[    47.088] (**) Option "xkb_rules" "evdev"
[    47.088] (**) Option "xkb_model" "pc105"
[    47.088] (**) Option "xkb_layout" "es"
[    47.088] (WW) Option "xkb_variant" requires a string value
[    47.088] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    47.088] (II) config/udev: Adding input device Video Bus (/dev/input/event4)
[    47.088] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    47.088] (**) Video Bus: Applying InputClass "system-keyboard"
[    47.088] (**) Video Bus: Applying InputClass "Keyboard Defaults"
[    47.088] (II) Using input driver 'evdev' for 'Video Bus'
[    47.088] (**) Video Bus: always reports core events
[    47.088] (**) evdev: Video Bus: Device: "/dev/input/event4"
[    47.088] (--) evdev: Video Bus: Vendor 0 Product 0x6
[    47.088] (--) evdev: Video Bus: Found keys
[    47.088] (II) evdev: Video Bus: Configuring as keyboard
[    47.088] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/LNXVIDEO:00/input/input5/event4"
[    47.088] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[    47.089] (II) config/udev: Adding input device VirtualBox mouse integration (/dev/input/event1)
[    47.089] (**) VirtualBox mouse integration: Applying InputClass "evdev pointer catchall"
[    47.089] (II) Using input driver 'evdev' for 'VirtualBox mouse integration'
[    47.089] (**) VirtualBox mouse integration: always reports core events
[    47.089] (**) evdev: VirtualBox mouse integration: Device: "/dev/input/event1"
[    47.089] (--) evdev: VirtualBox mouse integration: Vendor 0x80ee Product 0xcafe
[    47.089] (--) evdev: VirtualBox mouse integration: Found 1 mouse buttons
[    47.089] (--) evdev: VirtualBox mouse integration: Found absolute axes
[    47.089] (--) evdev: VirtualBox mouse integration: Found x and y absolute axes
[    47.089] (--) evdev: VirtualBox mouse integration: Found absolute touchscreen
[    47.089] (II) evdev: VirtualBox mouse integration: Configuring as touchscreen
[    47.089] (**) evdev: VirtualBox mouse integration: YAxisMapping: buttons 4 and 5
[    47.089] (**) evdev: VirtualBox mouse integration: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    47.089] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:04.0/input/input2/event1"
[    47.089] (II) XINPUT: Adding extended input device "VirtualBox mouse integration" (type: TOUCHSCREEN, id 9)
[    47.089] (II) evdev: VirtualBox mouse integration: initialized for absolute axes.
[    47.089] (**) VirtualBox mouse integration: (accel) keeping acceleration scheme 1
[    47.089] (**) VirtualBox mouse integration: (accel) acceleration profile 0
[    47.089] (**) VirtualBox mouse integration: (accel) acceleration factor: 2.000
[    47.089] (**) VirtualBox mouse integration: (accel) acceleration threshold: 4
[    47.090] (II) config/udev: Adding input device VirtualBox mouse integration (/dev/input/mouse0)
[    47.090] (II) No input driver specified, ignoring this device.
[    47.090] (II) This device may have been added with another device file.
[    47.090] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
[    47.090] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[    47.090] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[    47.090] (**) AT Translated Set 2 keyboard: Applying InputClass "Keyboard Defaults"
[    47.090] (II) Using input driver 'evdev' for 'AT Translated Set 2 keyboard'
[    47.090] (**) AT Translated Set 2 keyboard: always reports core events
[    47.090] (**) evdev: AT Translated Set 2 keyboard: Device: "/dev/input/event0"
[    47.090] (--) evdev: AT Translated Set 2 keyboard: Vendor 0x1 Product 0x1
[    47.090] (--) evdev: AT Translated Set 2 keyboard: Found keys
[    47.090] (II) evdev: AT Translated Set 2 keyboard: Configuring as keyboard
[    47.090] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input0/event0"
[    47.090] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 10)
[    47.090] (**) Option "xkb_rules" "evdev"
[    47.090] (**) Option "xkb_model" "pc105"
[    47.090] (**) Option "xkb_layout" "es"
[    47.090] (WW) Option "xkb_variant" requires a string value
[    47.090] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    47.091] (II) config/udev: Adding input device ImExPS/2 Generic Explorer Mouse (/dev/input/event5)
[    47.091] (**) ImExPS/2 Generic Explorer Mouse: Applying InputClass "evdev pointer catchall"
[    47.091] (II) Using input driver 'evdev' for 'ImExPS/2 Generic Explorer Mouse'
[    47.091] (**) ImExPS/2 Generic Explorer Mouse: always reports core events
[    47.091] (**) evdev: ImExPS/2 Generic Explorer Mouse: Device: "/dev/input/event5"
[    47.091] (--) evdev: ImExPS/2 Generic Explorer Mouse: Vendor 0x2 Product 0x6
[    47.091] (--) evdev: ImExPS/2 Generic Explorer Mouse: Found 9 mouse buttons
[    47.091] (--) evdev: ImExPS/2 Generic Explorer Mouse: Found scroll wheel(s)
[    47.091] (--) evdev: ImExPS/2 Generic Explorer Mouse: Found relative axes
[    47.091] (--) evdev: ImExPS/2 Generic Explorer Mouse: Found x and y relative axes
[    47.091] (II) evdev: ImExPS/2 Generic Explorer Mouse: Configuring as mouse
[    47.091] (II) evdev: ImExPS/2 Generic Explorer Mouse: Adding scrollwheel support
[    47.091] (**) evdev: ImExPS/2 Generic Explorer Mouse: YAxisMapping: buttons 4 and 5
[    47.091] (**) evdev: ImExPS/2 Generic Explorer Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    47.091] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input6/event5"
[    47.091] (II) XINPUT: Adding extended input device "ImExPS/2 Generic Explorer Mouse" (type: MOUSE, id 11)
[    47.091] (II) evdev: ImExPS/2 Generic Explorer Mouse: initialized for relative axes.
[    47.092] (**) ImExPS/2 Generic Explorer Mouse: (accel) keeping acceleration scheme 1
[    47.092] (**) ImExPS/2 Generic Explorer Mouse: (accel) acceleration profile 0
[    47.092] (**) ImExPS/2 Generic Explorer Mouse: (accel) acceleration factor: 2.000
[    47.092] (**) ImExPS/2 Generic Explorer Mouse: (accel) acceleration threshold: 4
[    47.092] (II) config/udev: Adding input device ImExPS/2 Generic Explorer Mouse (/dev/input/mouse1)
[    47.092] (II) No input driver specified, ignoring this device.
[    47.092] (II) This device may have been added with another device file.
After apply updates
Code: [Select]
[    32.817]
[    32.817] X Protocol Version 11, Revision 0
[    32.817] Build Operating System: Linux 4.2.5-1-ARCH x86_64
[    32.817] Current Operating System: Linux manjaro 4.4.6-1-MANJARO #1 SMP PREEMPT Sat Mar 19 06:00:37 CET 2016 x86_64
[    32.817] Kernel command line: initrd=/manjaro/boot/x86_64/manjaro.img misobasedir=manjaro misolabel=MJRO1603 nouveau.modeset=1 i915.modeset=1 radeon.modeset=1 logo.nologo overlay=free quiet vga=0x317  lang=es_ES keytable=es layout=es
[    32.817] Build Date: 01 November 2015  10:36:50AM
[    32.817]
[    32.817] Current version of pixman: 0.34.0
[    32.817] Before reporting problems, check http://wiki.x.org
[    32.817] Markers: (--) probed, (**) from config file, (==) default setting,
[    32.817] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Apr 29 07:29:31 2016
[    32.821] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    32.821] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    32.829] (==) No Layout section.  Using the first Screen section.
[    32.829] (==) No screen section available. Using defaults.
[    32.829] (**) |-->Screen "Default Screen Section" (0)
[    32.829] (**) |   |-->Monitor "<default monitor>"
[    32.829] (==) No device specified for screen "Default Screen Section".
[    32.829] (**) |   |-->Device "Device0"
[    32.829] (==) No monitor specified for screen "Default Screen Section".
[    32.830] (==) Automatically adding devices
[    32.830] (==) Automatically enabling devices
[    32.830] (==) Automatically adding GPU devices
[    32.837] (WW) The directory "/usr/share/fonts/Type1/" does not exist.
[    32.837] Entry deleted from font path.
[    32.837] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi/".
[    32.837] (Run 'mkfontdir' on "/usr/share/fonts/100dpi/").
[    32.837] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi/".
[    32.837] (Run 'mkfontdir' on "/usr/share/fonts/75dpi/").
[    32.837] (==) FontPath set to:
[    32.837] (==) ModulePath set to "/usr/lib/xorg/modules"
[    32.837] (**) Extension "Composite" is enabled
[    32.837] (**) Extension "RENDER" is enabled
[    32.837] (==) |-->Input Device "Mouse0"
[    32.837] (==) No Layout section. Using the first core pointer device.
[    32.837] (II) The server relies on udev to provide the list of input devices.
[    32.837] (II) Loader magic: 0x817d60
[    32.837] (II) Module ABI versions:
[    32.837] X.Org ANSI C Emulation: 0.4
[    32.837] X.Org Video Driver: 19.0
[    32.837] X.Org XInput driver : 21.1
[    32.837] X.Org Server Extension : 9.0
[    32.840] (EE) systemd-logind: failed to get session: The name org.freedesktop.login1 was not provided by any .service files
[    32.840] (II) xfree86: Adding drm device (/dev/dri/card0)
[    32.843] (--) PCI:*(0:0:2:0) 80ee:beef:0000:0000 rev 0, Mem @ 0xe0000000/134217728
[    32.843] (II) Open ACPI successful (/var/run/acpid.socket)
[    32.843] (II) LoadModule: "glx"
[    32.844] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    32.885] (II) Module glx: vendor="X.Org Foundation"
[    32.885] compiled for 1.17.4, module version = 1.0.0
[    32.885] ABI class: X.Org Server Extension, version 9.0
[    32.885] (==) AIGLX enabled
[    32.885] (II) LoadModule: "vboxvideo"
[    32.886] (II) Loading /usr/lib/xorg/modules/drivers/vboxvideo.so
[    32.886] (II) Module vboxvideo: vendor="Oracle Corporation"
[    32.886] compiled for 1.17.4, module version = 1.0.1
[    32.886] Module class: X.Org Video Driver
[    32.886] ABI class: X.Org Video Driver, version 19.0
[    32.886] (**) Load address of symbol "VBOXVIDEO" is 0x7fc606b563e0
[    32.886] (II) LoadModule: "vboxmouse"
[    32.887] (WW) Warning, couldn't open module vboxmouse
[    32.887] (II) UnloadModule: "vboxmouse"
[    32.887] (II) Unloading vboxmouse
[    32.887] (EE) Failed to load module "vboxmouse" (module does not exist, 0)
[    32.887] (II) VBoxVideo: guest driver for VirtualBox: vbox
[    32.887] (++) using VT number 7
[    32.889] (II) VBoxVideo(0): VirtualBox guest additions video driver version 5.0.16_OSEr105871
[    32.889] (II) Loading sub module "ramdac"
[    32.889] (II) LoadModule: "ramdac"
[    32.889] (II) Module "ramdac" already built-in
[    32.889] (II) Loading sub module "fb"
[    32.889] (II) LoadModule: "fb"
[    32.889] (II) Loading /usr/lib/xorg/modules/libfb.so
[    32.904] (II) Module fb: vendor="X.Org Foundation"
[    32.904] compiled for 1.17.4, module version = 1.0.0
[    32.904] ABI class: X.Org ANSI C Emulation, version 0.4
[    32.904] (II) Loading sub module "shadowfb"
[    32.904] (II) LoadModule: "shadowfb"
[    32.904] (II) Loading /usr/lib/xorg/modules/libshadowfb.so
[    32.933] (II) Module shadowfb: vendor="X.Org Foundation"
[    32.933] compiled for 1.17.4, module version = 1.0.0
[    32.933] ABI class: X.Org ANSI C Emulation, version 0.4
[    32.933] (II) Loading sub module "vgahw"
[    32.933] (II) LoadModule: "vgahw"
[    32.934] (II) Loading /usr/lib/xorg/modules/libvgahw.so
[    32.934] (II) Module vgahw: vendor="X.Org Foundation"
[    32.934] compiled for 1.17.4, module version = 0.1.0
[    32.934] ABI class: X.Org Video Driver, version 19.0
[    32.934] (II) Loading sub module "dri2"
[    32.934] (II) LoadModule: "dri2"
[    32.934] (II) Module "dri2" already built-in
[    32.934] (II) VBoxVideo(0): Creating default Display subsection in Screen section
[    32.934] (==) VBoxVideo(0): Depth 24, (--) framebuffer bpp 32
[    32.934] (--) VBoxVideo(0): Virtual size is 32766x32766 (pitch 32766)
[    32.934] (**) VBoxVideo(0):  Built-in mode "800x600": 29.3 MHz (scaled from 0.0 MHz), 36.4 kHz, 60.0 Hz
[    32.934] (II) VBoxVideo(0): Modeline "800x600"x0.0   29.31  800 802 804 806  600 602 604 606 (36.4 kHz b)
[    32.934] (II) VBoxVideo(0): vgaHWGetIOBase: hwp->IOBase is 0x03d0
[    32.934] (==) VBoxVideo(0): RGB weight 888
[    32.934] (==) VBoxVideo(0): Default visual is TrueColor
[    32.934] (==) VBoxVideo(0): Using gamma correction (1.0, 1.0, 1.0)
[    32.934] (==) VBoxVideo(0): DPI set to (96, 96)
[    32.934] (--) Depth 24 pixmap format is 32 bpp
[    32.937] (II) VBoxVideo(0): [DRI2] Setup complete
[    32.937] (II) VBoxVideo(0): [DRI2]   DRI driver: vboxvideo
[    33.018] (II) VBoxVideo(0): Requested monitor count: 1
[    33.018] (II) VBoxVideo(0): Output VGA-0 has no monitor section
[    33.018] (II) VBoxVideo(0): Printing probed modes for output VGA-0
[    33.018] (II) VBoxVideo(0): Modeline "1024x768"x60.0   47.83  1024 1026 1028 1030  768 770 772 774 (46.4 kHz Pb)
[    33.018] (II) VBoxVideo(0): Modeline "2560x1600"x60.0  247.26  2560 2562 2564 2566  1600 1602 1604 1606 (96.4 kHz b)
[    33.018] (II) VBoxVideo(0): Modeline "2560x1440"x60.0  222.63  2560 2562 2564 2566  1440 1442 1444 1446 (86.8 kHz b)
[    33.018] (II) VBoxVideo(0): Modeline "2048x1536"x60.0  190.04  2048 2050 2052 2054  1536 1538 1540 1542 (92.5 kHz b)
[    33.018] (II) VBoxVideo(0): Modeline "1920x1600"x60.0  185.59  1920 1922 1924 1926  1600 1602 1604 1606 (96.4 kHz b)
[    33.018] (II) VBoxVideo(0): Modeline "1920x1080"x60.0  125.50  1920 1922 1924 1926  1080 1082 1084 1086 (65.2 kHz b)
[    33.018] (II) VBoxVideo(0): Modeline "1600x1200"x60.0  116.21  1600 1602 1604 1606  1200 1202 1204 1206 (72.4 kHz b)
[    33.018] (II) VBoxVideo(0): Modeline "1680x1050"x60.0  106.82  1680 1682 1684 1686  1050 1052 1054 1056 (63.4 kHz b)
[    33.018] (II) VBoxVideo(0): Modeline "1400x1050"x60.0   89.08  1400 1402 1404 1406  1050 1052 1054 1056 (63.4 kHz b)
[    33.018] (II) VBoxVideo(0): Modeline "1280x1024"x60.0   79.47  1280 1282 1284 1286  1024 1026 1028 1030 (61.8 kHz b)
[    33.018] (II) VBoxVideo(0): Modeline "1024x768"x60.0   47.83  1024 1026 1028 1030  768 770 772 774 (46.4 kHz b)
[    33.018] (II) VBoxVideo(0): Modeline "800x600"x60.0   29.31  800 802 804 806  600 602 604 606 (36.4 kHz b)
[    33.018] (II) VBoxVideo(0): Modeline "640x480"x60.0   18.84  640 642 644 646  480 482 484 486 (29.2 kHz b)
[    33.018] (II) VBoxVideo(0): Output VGA-0 connected
[    33.018] (II) VBoxVideo(0): Using exact sizes for initial modes
[    33.018] (II) VBoxVideo(0): Output VGA-0 using initial mode 1024x768
[    33.018] (II) VBoxVideo(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[    33.018] (II) VBoxVideo(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[    33.018] (==) VBoxVideo(0): DPMS enabled
[    33.018] (--) RandR disabled
[    33.024] (II) Next line is added to allow vboxvideo_drv.so to appear as whitelisted driver
[    33.024] (II) The file referenced, is *NOT* loaded
[    33.024] (II) Loading /usr/lib/xorg/modules/drivers//ati_drv.so
[    33.024] (EE) AIGLX error: vboxvideo does not export required DRI extension
[    33.024] (EE) AIGLX: reverting to software rendering
[    34.141] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[    34.141] (II) AIGLX: Loaded and initialized swrast
[    34.141] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[    34.141] (II) VBoxVideo(0): Setting screen physical size to 270 x 203
[    34.558] (II) LoadModule: "vboxmouse"
[    34.560] (WW) Warning, couldn't open module vboxmouse
[    34.560] (II) UnloadModule: "vboxmouse"
[    34.560] (II) Unloading vboxmouse
[    34.560] (EE) Failed to load module "vboxmouse" (module does not exist, 0)
[    34.560] (EE) No input driver matching `vboxmouse'
[    34.562] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[    34.562] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    34.562] (**) Power Button: Applying InputClass "system-keyboard"
[    34.562] (**) Power Button: Applying InputClass "Keyboard Defaults"
[    34.562] (II) LoadModule: "evdev"
[    34.562] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    34.576] (II) Module evdev: vendor="X.Org Foundation"
[    34.576] compiled for 1.17.4, module version = 2.10.1
[    34.576] Module class: X.Org XInput Driver
[    34.576] ABI class: X.Org XInput driver, version 21.1
[    34.576] (II) Using input driver 'evdev' for 'Power Button'
[    34.576] (**) Power Button: always reports core events
[    34.576] (**) evdev: Power Button: Device: "/dev/input/event0"
[    34.576] (--) evdev: Power Button: Vendor 0 Product 0x1
[    34.576] (--) evdev: Power Button: Found keys
[    34.576] (II) evdev: Power Button: Configuring as keyboard
[    34.576] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input0/event0"
[    34.576] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    34.576] (**) Option "xkb_rules" "evdev"
[    34.576] (**) Option "xkb_model" "pc105"
[    34.576] (**) Option "xkb_layout" "es"
[    34.576] (WW) Option "xkb_variant" requires a string value
[    34.576] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    34.614] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[    34.614] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[    34.614] (**) Sleep Button: Applying InputClass "system-keyboard"
[    34.614] (**) Sleep Button: Applying InputClass "Keyboard Defaults"
[    34.614] (II) Using input driver 'evdev' for 'Sleep Button'
[    34.614] (**) Sleep Button: always reports core events
[    34.614] (**) evdev: Sleep Button: Device: "/dev/input/event1"
[    34.614] (--) evdev: Sleep Button: Vendor 0 Product 0x3
[    34.614] (--) evdev: Sleep Button: Found keys
[    34.614] (II) evdev: Sleep Button: Configuring as keyboard
[    34.614] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSLPBN:00/input/input1/event1"
[    34.614] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 7)
[    34.614] (**) Option "xkb_rules" "evdev"
[    34.614] (**) Option "xkb_model" "pc105"
[    34.614] (**) Option "xkb_layout" "es"
[    34.614] (WW) Option "xkb_variant" requires a string value
[    34.614] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    34.615] (II) config/udev: Adding input device Video Bus (/dev/input/event2)
[    34.615] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    34.615] (**) Video Bus: Applying InputClass "system-keyboard"
[    34.615] (**) Video Bus: Applying InputClass "Keyboard Defaults"
[    34.615] (II) Using input driver 'evdev' for 'Video Bus'
[    34.615] (**) Video Bus: always reports core events
[    34.615] (**) evdev: Video Bus: Device: "/dev/input/event2"
[    34.615] (--) evdev: Video Bus: Vendor 0 Product 0x6
[    34.615] (--) evdev: Video Bus: Found keys
[    34.615] (II) evdev: Video Bus: Configuring as keyboard
[    34.615] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/LNXVIDEO:00/input/input2/event2"
[    34.615] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[    34.615] (**) Option "xkb_rules" "evdev"
[    34.615] (**) Option "xkb_model" "pc105"
[    34.615] (**) Option "xkb_layout" "es"
[    34.615] (WW) Option "xkb_variant" requires a string value
[    34.615] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    34.615] (II) config/udev: Adding input device VirtualBox mouse integration (/dev/input/event5)
[    34.615] (**) VirtualBox mouse integration: Applying InputClass "evdev pointer catchall"
[    34.616] (II) Using input driver 'evdev' for 'VirtualBox mouse integration'
[    34.616] (**) VirtualBox mouse integration: always reports core events
[    34.616] (**) evdev: VirtualBox mouse integration: Device: "/dev/input/event5"
[    34.616] (--) evdev: VirtualBox mouse integration: Vendor 0x80ee Product 0xcafe
[    34.616] (--) evdev: VirtualBox mouse integration: Found 1 mouse buttons
[    34.616] (--) evdev: VirtualBox mouse integration: Found absolute axes
[    34.616] (--) evdev: VirtualBox mouse integration: Found x and y absolute axes
[    34.616] (--) evdev: VirtualBox mouse integration: Found absolute touchscreen
[    34.616] (II) evdev: VirtualBox mouse integration: Configuring as touchscreen
[    34.616] (**) evdev: VirtualBox mouse integration: YAxisMapping: buttons 4 and 5
[    34.616] (**) evdev: VirtualBox mouse integration: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    34.616] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:04.0/input/input6/event5"
[    34.616] (II) XINPUT: Adding extended input device "VirtualBox mouse integration" (type: TOUCHSCREEN, id 9)
[    34.616] (II) evdev: VirtualBox mouse integration: initialized for absolute axes.
[    34.616] (**) VirtualBox mouse integration: (accel) keeping acceleration scheme 1
[    34.616] (**) VirtualBox mouse integration: (accel) acceleration profile 0
[    34.616] (**) VirtualBox mouse integration: (accel) acceleration factor: 2.000
[    34.616] (**) VirtualBox mouse integration: (accel) acceleration threshold: 4
[    34.616] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[    34.616] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[    34.616] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[    34.616] (**) AT Translated Set 2 keyboard: Applying InputClass "Keyboard Defaults"
[    34.616] (II) Using input driver 'evdev' for 'AT Translated Set 2 keyboard'
[    34.616] (**) AT Translated Set 2 keyboard: always reports core events
[    34.616] (**) evdev: AT Translated Set 2 keyboard: Device: "/dev/input/event3"
[    34.616] (--) evdev: AT Translated Set 2 keyboard: Vendor 0x1 Product 0x1
[    34.616] (--) evdev: AT Translated Set 2 keyboard: Found keys
[    34.616] (II) evdev: AT Translated Set 2 keyboard: Configuring as keyboard
[    34.616] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
[    34.616] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 10)
[    34.616] (**) Option "xkb_rules" "evdev"
[    34.616] (**) Option "xkb_model" "pc105"
[    34.617] (**) Option "xkb_layout" "es"
[    34.617] (WW) Option "xkb_variant" requires a string value
[    34.617] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    34.617] (II) config/udev: Adding input device ImExPS/2 Generic Explorer Mouse (/dev/input/event4)
[    34.617] (**) ImExPS/2 Generic Explorer Mouse: Applying InputClass "evdev pointer catchall"
[    34.617] (II) Using input driver 'evdev' for 'ImExPS/2 Generic Explorer Mouse'
[    34.617] (**) ImExPS/2 Generic Explorer Mouse: always reports core events
[    34.617] (**) evdev: ImExPS/2 Generic Explorer Mouse: Device: "/dev/input/event4"
[    34.617] (--) evdev: ImExPS/2 Generic Explorer Mouse: Vendor 0x2 Product 0x6
[    34.617] (--) evdev: ImExPS/2 Generic Explorer Mouse: Found 9 mouse buttons
[    34.617] (--) evdev: ImExPS/2 Generic Explorer Mouse: Found scroll wheel(s)
[    34.617] (--) evdev: ImExPS/2 Generic Explorer Mouse: Found relative axes
[    34.617] (--) evdev: ImExPS/2 Generic Explorer Mouse: Found x and y relative axes
[    34.617] (II) evdev: ImExPS/2 Generic Explorer Mouse: Configuring as mouse
[    34.617] (II) evdev: ImExPS/2 Generic Explorer Mouse: Adding scrollwheel support
[    34.617] (**) evdev: ImExPS/2 Generic Explorer Mouse: YAxisMapping: buttons 4 and 5
[    34.617] (**) evdev: ImExPS/2 Generic Explorer Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    34.617] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input5/event4"
[    34.617] (II) XINPUT: Adding extended input device "ImExPS/2 Generic Explorer Mouse" (type: MOUSE, id 11)
[    34.617] (II) evdev: ImExPS/2 Generic Explorer Mouse: initialized for relative axes.
[    34.617] (**) ImExPS/2 Generic Explorer Mouse: (accel) keeping acceleration scheme 1
[    34.617] (**) ImExPS/2 Generic Explorer Mouse: (accel) acceleration profile 0
[    34.617] (**) ImExPS/2 Generic Explorer Mouse: (accel) acceleration factor: 2.000
[    34.617] (**) ImExPS/2 Generic Explorer Mouse: (accel) acceleration threshold: 4
[    34.618] (II) config/udev: Adding input device ImExPS/2 Generic Explorer Mouse (/dev/input/mouse0)
[    34.618] (II) No input driver specified, ignoring this device.
[    34.618] (II) This device may have been added with another device file.
Do you need some other information?
« Last Edit: 29. April 2016, 10:04:39 by v17564 »
Offline artoo
  • OpenRC Team
  • Branch: Unstable
  • Desktop: LXQT/Plasma5, openrc & eudev
  • Kernel: x86_64
  • Skill: Advanced
« Reply #24 on: 29. April 2016, 10:19:43 »
Code: [Select]
You do'n't have virtualbox guest modules installed or something is wrong with it.
Offline v17564
  • I'm new. Be nice!
  • Skill: Novice
« Reply #25 on: 29. April 2016, 11:58:30 »
Hello @artoo
Code: [Select]
I have instaled virtualbox guest additions. The attacment image show virtualbox guest version 5.0.16 instaled "before update", after update must be instaled the new version 5.0.18.
From « Reply #3 on: Yesterday at 10:24:50 »
This is my complete pacman.log from the first instalation 19/04/16:
Code: [Select]
[2016-04-19 06:09] [PACMAN] Running 'pacman -Syy'
[2016-04-19 06:09] [PACMAN] synchronizing package lists
[2016-04-19 06:09] [PACMAN] Running 'pacman --noconfirm --cachedir /var/cache/pacman/pkg --config /opt/livecd/pacman-gfx.conf --root / --needed -Sy virtualbox-guest-utils linux44-virtualbox-guest-modules'
[2016-04-19 06:09] [ALPM] transaction started
[2016-04-19 06:09] [ALPM] installed linux44-virtualbox-guest-modules (5.0.16-8)
[2016-04-19 06:09] [ALPM-SCRIPTLET] ===> You may want to load vboxguest, vboxsf and vboxvideo
[2016-04-19 06:10] [ALPM] installed virtualbox-guest-utils (5.0.16-0.1)
[2016-04-19 06:10] [ALPM] transaction completed
Update process:
Code: [Select]
[2016-04-28 09:38] [ALPM] upgraded lightdm (1:1.18.0-1 -> 1:1.18.1-1)
[2016-04-28 09:38] [ALPM] upgraded linux44-virtualbox-guest-modules (5.0.16-8 -> 5.0.18-1)
[2016-04-28 09:38] [ALPM] upgraded virtualbox-guest-utils (5.0.16-0.1 -> 5.0.18-0.1)
[2016-04-28 09:38] [ALPM] transaction completed
More information:
Code: [Select]
[@manjaro modules-load.d]$ ls -la
total 24
drwxr-xr-x  2 root root 4096 abr 19 08:10 .
drwxr-xr-x 79 root root 4096 abr 29 12:06 ..
-rw-r--r--  1 root root   27 mar 19 11:39 linux44-virtualbox-guest-modules.conf
-rw-r--r--  1 root root   58 abr 19 08:10 mhwd-gpu.conf
-rw-r--r--  1 root root   87 abr 19 08:10 mhwd-virtualbox.conf
-rw-r--r--  1 root root   34 sep 30  2015 modules.conf
[@manjaro modules-load.d]$ cat linux44-virtualbox-guest-modules.conf
vboxguest
vboxsf
vboxvideo
« Last Edit: 29. April 2016, 12:36:32 by v17564 »
Offline v17564
  • I'm new. Be nice!
  • Skill: Novice
« Reply #26 on: 29. April 2016, 13:38:02 »
Hello.
rc.log just after update when i exec reboot:
Code: [Select]
* Stopping lightdm ...
 * start-stop-daemon: no matching processes found
Log's subdirectory:
Code: [Select]
cat errors.log
Apr 29 13:26:17 manjaro /etc/init.d/xdm[8174]: start-stop-daemon: no matching processes found
Quote
ls -l
-rw-r--r-- 1 root root         0 Apr 29 13:26 Xorg.0.log
-rw-r--r-- 1 root root      4908 Apr 29 13:26 Xorg.0.log.old
The fault is inmediate.
« Last Edit: 29. April 2016, 13:44:45 by v17564 »
Offline artoo
  • OpenRC Team
  • Branch: Unstable
  • Kernel: x86_64
  • Skill: Advanced
« Reply #27 on: 29. April 2016, 14:45:49 »
Again, according to your log, your vbox guest modules(vboxvideo) is not loaded.
Its basically not an openrc issue.
Please post
Code: [Select]
lsmod | grep vbox
Offline v17564
  • I'm new. Be nice!
  • Skill: Novice
« Reply #28 on: 29. April 2016, 14:50:24 »
Please post
Code: [Select]
lsmod | grep vbox
Hello @artoo
I do not say that the issue is in openrc, in fact i don't know why occurs the issue. I only want to remarks that the issue takes place immediately after update.
Code: [Select]
$ lsmod | grep vbox
vboxvideo              16384  2
drm                   286720  4 vboxvideo
vboxguest             221184  6
« Last Edit: 29. April 2016, 15:58:57 by v17564 »
Offline artoo
  • OpenRC Team
  • Branch: Unstable
  • Kernel: x86_64
  • Skill: Advanced
« Reply #29 on: 29. April 2016, 18:06:04 »
Is your user member of vboxguest group?
Do you use vbox dkms modules?
