Author Topic: LightDM does not start after 2016-04-26 Update [FIX]  (Read 6125 times)
Offline v17564
  • Vollwertiges Mitglied
  • I'm new. Be nice!
  • Skill: Novice
« on: 27. April 2016, 10:20:53 »
Hello @aaditya.
System: Manjaro 16.03 OpenRC x64 running in VirtualBox.
I aplly the today update (27/04/16) and after reboot the xdm don't start. I try twice but with the same result.
I have installed Manjaro OpenRC 0.8.13 x64 in my job phisical machine and the update work without problems.
This is the error:
Code: [Select]
cat errors.log
Apr 27 09:54:20 manjaro /etc/init.d/xdm[7856]: start-stop-daemon: no matching processes found
everything.log after reboot
Quote
Apr 27 09:54:18 manjaro shutdown[7507]: shutting down for system reboot
Apr 27 09:54:19 manjaro init[1]: Switching to runlevel: 6
Apr 27 09:54:19 manjaro kernel: traps: ck-remove-direc[7516] trap int3 ip:7f45f509b7eb sp:7ffe4a71dfe0 error:0
Apr 27 09:54:19 manjaro acpid[1395]: client 1628[0:0] has disconnected
Apr 27 09:54:19 manjaro acpid[1395]: client connected from 7518[0:0]
Apr 27 09:54:19 manjaro acpid[1395]: 1 client rule loaded
Apr 27 09:54:20 manjaro crond[1710]: (CRON) INFO (Shutting down)
Apr 27 09:54:20 manjaro bluetoothd[1655]: Terminating
Apr 27 09:54:20 manjaro bluetoothd[1655]: Stopping SDP server
Apr 27 09:54:20 manjaro bluetoothd[1655]: Exit
Apr 27 09:54:20 manjaro avahi-daemon[1737]: Got SIGTERM, quitting.
Apr 27 09:54:20 manjaro avahi-daemon[1737]: Leaving mDNS multicast group on interface enp0s3.IPv4 with address 10.0.2.15.
Apr 27 09:54:20 manjaro avahi-daemon[1737]: avahi-daemon 0.6.32 exiting.
Apr 27 09:54:21 manjaro acpid[1395]: exiting
Apr 27 09:54:21 manjaro syslog-ng[1367]: syslog-ng shutting down; version='3.6.3'
Apr 27 09:54:48 manjaro syslog-ng[1369]: syslog-ng starting up; version='3.6.3'
Apr 27 09:54:48 manjaro acpid[1401]: starting up with netlink and the input layer
Apr 27 09:54:48 manjaro acpid[1401]: 1 rule loaded
Apr 27 09:54:48 manjaro acpid[1401]: waiting for events: event logging is off
Apr 27 09:54:49 manjaro bluetoothd[1660]: Bluetooth daemon 5.39
Apr 27 09:54:49 manjaro kernel: Bluetooth: Core ver 2.21
Apr 27 09:54:49 manjaro kernel: NET: Registered protocol family 31
Apr 27 09:54:49 manjaro kernel: Bluetooth: HCI device and connection manager initialized
Apr 27 09:54:49 manjaro kernel: Bluetooth: HCI socket layer initialized
Apr 27 09:54:49 manjaro kernel: Bluetooth: L2CAP socket layer initialized
Apr 27 09:54:49 manjaro kernel: Bluetooth: SCO socket layer initialized
Apr 27 09:54:49 manjaro crond[1713]: (CRON) STARTUP (1.5.0)
Apr 27 09:54:49 manjaro crond[1713]: (CRON) INFO (Syslog will be used instead of sendmail.)
Apr 27 09:54:49 manjaro crond[1713]: (CRON) INFO (RANDOM_DELAY will be scaled with factor 80% if used.)
Apr 27 09:54:49 manjaro crond[1713]: (CRON) INFO (running with inotify support)
Apr 27 09:54:49 manjaro bluetoothd[1660]: Starting SDP server
Apr 27 09:54:49 manjaro bluetoothd[1660]: Bluetooth management interface 1.10 initialized
Apr 27 09:54:49 manjaro NetworkManager[1256]: <info>  use BlueZ version 5
Apr 27 09:54:49 manjaro kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Apr 27 09:54:49 manjaro kernel: Bluetooth: BNEP filters: protocol multicast
Apr 27 09:54:49 manjaro kernel: Bluetooth: BNEP socket layer initialized
Apr 27 09:54:49 manjaro avahi-daemon[1740]: Found user 'avahi' (UID 84) and group 'avahi' (GID 84).
Apr 27 09:54:49 manjaro avahi-daemon[1740]: Successfully dropped root privileges.
Apr 27 09:54:49 manjaro avahi-daemon[1740]: avahi-daemon 0.6.32 starting up.
Apr 27 09:54:49 manjaro avahi-daemon[1740]: Successfully called chroot().
Apr 27 09:54:49 manjaro avahi-daemon[1740]: Successfully dropped remaining capabilities.
Apr 27 09:54:49 manjaro avahi-daemon[1740]: No service file found in /etc/avahi/services.
Apr 27 09:54:49 manjaro avahi-daemon[1740]: socket() failed: Address family not supported by protocol
Apr 27 09:54:49 manjaro avahi-daemon[1740]: Failed to create IPv6 socket, proceeding in IPv4 only mode
Apr 27 09:54:49 manjaro avahi-daemon[1740]: Joining mDNS multicast group on interface enp0s3.IPv4 with address 10.0.2.15.
Apr 27 09:54:49 manjaro avahi-daemon[1740]: New relevant interface enp0s3.IPv4 for mDNS.
Apr 27 09:54:49 manjaro avahi-daemon[1740]: Network interface enumeration completed.
Apr 27 09:54:49 manjaro avahi-daemon[1740]: Registering new address record for 10.0.2.15 on enp0s3.IPv4.
Apr 27 09:54:50 manjaro acpid[1401]: client connected from 1641[0:0]
Apr 27 09:54:50 manjaro acpid[1401]: 1 client rule loaded
Apr 27 09:54:50 manjaro acpid[1401]: client 1641[0:0] has disconnected
Apr 27 09:54:50 manjaro acpid[1401]: client connected from 1815[0:0]
Apr 27 09:54:50 manjaro avahi-daemon[1740]: Server startup complete. Host name is manjaro.local. Local service cookie is 791999316.
Apr 27 09:54:51 manjaro NetworkManager[1256]: <info>  startup complete
« Last Edit: 09. May 2016, 17:36:03 by v17564 »
Offline aaditya
  • OpenRC Team
    • My Website
  • Branch: Testing
  • Desktop: Xfce, Openbox
  • GPU Card: Intel HD 4000
  • Kernel: Linux 4.4 x86_64
  • Skill: Intermediate
Re: LightDM does not start after 2016-04-26 Update
« Reply #1 on: 27. April 2016, 14:00:35 »
Hi v17564,
Try installing the themes suggested by Philm in his update post.
Code: [Select]
sudo pacman -S vertex-maia-themes vertex-maia-icon-theme xcursor-maia
After that you could change the lightdm theme to Vertex-Maia via editing /etc/lightdm/lightdm-gtk-greeter.conf or using the lightdm-gtk-greeter-settings package.
« Last Edit: 27. April 2016, 19:36:41 by aaditya »
Offline thrasymachus
  • Neuling
  • I'm new. Be nice!
  • Desktop: Awesome WM
« Reply #2 on: 28. April 2016, 02:56:56 »
I followed these instructions, but the same crash is happening...is it related to mhwd?
I am getting the same error.log entry for xdm as well
« Last Edit: 28. April 2016, 04:13:27 by thrasymachus »
Offline v17564
  • I'm new. Be nice!
  • Skill: Novice
« Reply #3 on: 28. April 2016, 10:24:50 »
Hello @aaditya.
I follw the instrucctions but don't work.
- First install the theme with the command:
Code: [Select]
sudo pacman -S vertex-maia-themes vertex-maia-icon-theme xcursor-maiaThen I select the new icons theme to Vertex-maia and the style to Menda. After this I install the update but lightdm don't start and the error is the same of the previos post.
This is my complete pacman.log :
Code: [Select]
[2016-04-19 06:09] [PACMAN] Running 'pacman -Syy'
[2016-04-19 06:09] [PACMAN] synchronizing package lists
[2016-04-19 06:09] [PACMAN] Running 'pacman --noconfirm --cachedir /var/cache/pacman/pkg --config /opt/livecd/pacman-gfx.conf --root / --needed -Sy virtualbox-guest-utils linux44-virtualbox-guest-modules'
[2016-04-19 06:09] [ALPM] transaction started
[2016-04-19 06:09] [ALPM] installed linux44-virtualbox-guest-modules (5.0.16-8)
[2016-04-19 06:09] [ALPM-SCRIPTLET] ===> You may want to load vboxguest, vboxsf and vboxvideo
[2016-04-19 06:10] [ALPM] installed virtualbox-guest-utils (5.0.16-0.1)
[2016-04-19 06:10] [ALPM] transaction completed
[2016-04-19 13:07] [ALPM] transaction started
[2016-04-19 13:07] [ALPM] removed xarchiver (0.5.4-3)
[2016-04-19 13:07] [ALPM] removed orage (4.12.1-2)
[2016-04-19 13:07] [ALPM] installed p7zip (15.14.1-0.1)
[2016-04-19 13:07] [ALPM] installed bleachbit (1.10-1)
[2016-04-19 13:07] [ALPM] installed file-roller (3.16.4-1)
[2016-04-19 13:07] [ALPM] installed gamin (0.1.10-8)
[2016-04-19 13:07] [ALPM] installed medit (1.2.0-2)
[2016-04-19 13:07] [ALPM] installed tangerine-icon-theme (0.27-3)
[2016-04-19 13:07] [ALPM] installed human-icon-theme (0.36-4)
[2016-04-19 13:07] [ALPM] transaction completed
[2016-04-19 13:08] [ALPM] transaction started
[2016-04-19 13:08] [ALPM] installed ufw (0.34-1)
[2016-04-19 13:08] [ALPM] installed python2-netifaces (0.10.4-2)
[2016-04-19 13:08] [ALPM] installed libxslt (1.1.28-4)
[2016-04-19 13:08] [ALPM] installed aspell (0.60.6.1-4)
[2016-04-19 13:08] [ALPM-SCRIPTLET] ==> aspell comes with no default dictionary
[2016-04-19 13:08] [ALPM] installed hspell (1.3-1)
[2016-04-19 13:08] [ALPM] installed libvoikko (4.0.2-1)
[2016-04-19 13:08] [ALPM] installed enchant (1.6.0-7)
[2016-04-19 13:08] [ALPM] installed geoclue2 (2.4.3-1)
[2016-04-19 13:08] [ALPM] installed harfbuzz-icu (1.2.4-1)
[2016-04-19 13:08] [ALPM] installed webkitgtk (2.4.10-1)
[2016-04-19 13:08] [ALPM] installed gufw (15.10.0-1)
[2016-04-19 13:08] [ALPM] installed ufw-openrc (20151014-1)
[2016-04-19 13:08] [ALPM-SCRIPTLET] ==> run 'rc-update add ufw default'
[2016-04-19 13:08] [ALPM] transaction completed
[2016-04-19 13:20] [PACMAN] Running 'pacman --noconfirm --noprogressbar -Sy'
[2016-04-19 13:20] [PACMAN] synchronizing package lists
[2016-04-19 13:20] [PACMAN] starting full system upgrade
[2016-04-19 13:20] [PACMAN] Running 'pacman --noconfirm --noprogressbar -S firefox-i18n-en-us aspell-en hunspell-en vim-spell-en firefox-i18n-es-es aspell-es hunspell-es vim-spell-es'
[2016-04-19 13:20] [ALPM] transaction started
[2016-04-19 13:20] [ALPM] installed firefox-i18n-en-us (45.0.1-1)
[2016-04-19 13:20] [ALPM] installed aspell-en (2016.01.19-1)
[2016-04-19 13:20] [ALPM] installed hunspell-en (2016.01.19-1)
[2016-04-19 13:20] [ALPM] installed vim-spell-en (20120802-1)
[2016-04-19 13:20] [ALPM] installed firefox-i18n-es-es (45.0.1-1)
[2016-04-19 13:20] [ALPM] installed aspell-es (1.11-6)
[2016-04-19 13:20] [ALPM] installed hunspell-es (1:2.0-1)
[2016-04-19 13:20] [ALPM] installed vim-spell-es (20120802-1)
[2016-04-19 13:20] [ALPM] transaction completed
[2016-04-28 09:17] [PACMAN] Running 'pacman -S vertex-maia-themes vertex-maia-icon-theme xcursor-maia'
[2016-04-28 09:17] [ALPM] transaction started
[2016-04-28 09:17] [ALPM] installed vertex-maia-themes (20160425-1)
[2016-04-28 09:17] [ALPM-SCRIPTLET]
[2016-04-28 09:17] [ALPM-SCRIPTLET] ==> vertex-maia-themes:
[2016-04-28 09:17] [ALPM-SCRIPTLET]   -> For seamless integration of Firefox and Palemoon browsers
[2016-04-28 09:17] [ALPM-SCRIPTLET]   -> please copy the 'chrome' folder of the desired theme to your browser profile
[2016-04-28 09:17] [ALPM-SCRIPTLET]   -> or create a symlink.
[2016-04-28 09:17] [ALPM-SCRIPTLET] ==> For example:
[2016-04-28 09:17] [ALPM-SCRIPTLET]   -> 'ln -s /usr/share/themes/Palemoon/Vertex-Maia-Dark/chrome/ ~/.moonchild\ productions/pale\ moon/<xyz123>.default/chrome'
[2016-04-28 09:17] [ALPM] installed vertex-maia-icon-theme (20160421-1)
[2016-04-28 09:17] [ALPM] installed xcursor-maia (20160417-1)
[2016-04-28 09:17] [ALPM] transaction completed
[2016-04-28 09:36] [ALPM] transaction started
[2016-04-28 09:36] [ALPM] upgraded tzdata (2016c-1 -> 2016d-1)
[2016-04-28 09:36] [ALPM] upgraded glib2 (2.46.2-4 -> 2.48.0-1)
[2016-04-28 09:36] [ALPM] upgraded gtk-update-icon-cache (3.18.9-1 -> 3.20.3-1)
[2016-04-28 09:36] [ALPM] upgraded harfbuzz (1.2.4-1 -> 1.2.6-1)
[2016-04-28 09:36] [ALPM] upgraded fontconfig (2.11.94-1 -> 2.11.95-1)
[2016-04-28 09:36] [ALPM-SCRIPTLET] updating font cache... done.
[2016-04-28 09:36] [ALPM] upgraded libelf (0.165-1 -> 0.166-1)
[2016-04-28 09:36] [ALPM] upgraded elfutils (0.165-1 -> 0.166-1)
[2016-04-28 09:36] [ALPM] upgraded libgcrypt (1.6.5-1 -> 1.7.0-1)
[2016-04-28 09:36] [ALPM] upgraded libxml2 (2.9.3-1 -> 2.9.3+14+gd5bd2a9-1)
[2016-04-28 09:36] [ALPM] upgraded libutil-linux (2.27.1-1 -> 2.28-1)
[2016-04-28 09:36] [ALPM] upgraded cracklib (2.9.4-1 -> 2.9.6-1)
[2016-04-28 09:36] [ALPM] upgraded util-linux (2.27.1-1 -> 2.28-1)
[2016-04-28 09:36] [ALPM] upgraded mesa (11.1.2-1 -> 11.2.1-1)
[2016-04-28 09:36] [ALPM] upgraded mhwd-db (0.5.7-1 -> 0.5.7-4)
[2016-04-28 09:36] [ALPM] upgraded linux-firmware (20160113.40e9ae8-1 -> 20160315.deb1d83-1)
[2016-04-28 09:36] [ALPM] upgraded grep (2.24-1 -> 2.25-1)
[2016-04-28 09:36] [ALPM] upgraded gzip (1.6-1 -> 1.7-1)
[2016-04-28 09:36] [ALPM] upgraded linux44 (4.4.6-1 -> 4.4.8-1)
[2016-04-28 09:36] [ALPM-SCRIPTLET] >>> Updating module dependencies. Please wait ...
[2016-04-28 09:36] [ALPM-SCRIPTLET] >>> Generating initial ramdisk, using mkinitcpio.  Please wait...
[2016-04-28 09:36] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux44.preset: 'default'
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-4.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.4-x86_64.img
[2016-04-28 09:36] [ALPM-SCRIPTLET] ==> Starting build: 4.4.8-1-MANJARO
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Running build hook: [usr]
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Running build hook: [shutdown]
[2016-04-28 09:36] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2016-04-28 09:36] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-4.4-x86_64.img
[2016-04-28 09:36] [ALPM-SCRIPTLET] ==> Image generation successful
[2016-04-28 09:36] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux44.preset: 'fallback'
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-4.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.4-x86_64-fallback.img -S autodetect
[2016-04-28 09:36] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-4.4-x86_64-fallback.img
[2016-04-28 09:36] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2016-04-28 09:36] [ALPM-SCRIPTLET] Found background: /usr/share/grub/background.png
[2016-04-28 09:36] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-4.4-x86_64
[2016-04-28 09:36] [ALPM-SCRIPTLET] Found initrd image: /boot/initramfs-4.4-x86_64.img
[2016-04-28 09:36] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-4.4-x86_64-fallback.img
[2016-04-28 09:36] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2016-04-28 09:36] [ALPM-SCRIPTLET] done
[2016-04-28 09:36] [ALPM] upgraded archlinux-keyring (20160215-1 -> 20160402-1)
[2016-04-28 09:36] [ALPM-SCRIPTLET] ==> Appending keys from archlinux.gpg...
[2016-04-28 09:36] [ALPM-SCRIPTLET] gpg: marginals needed: 3  completes needed: 1  trust model: PGP
[2016-04-28 09:36] [ALPM-SCRIPTLET] gpg: depth: 0  valid:   1  signed:  16  trust: 0-, 0q, 0n, 0m, 0f, 1u
[2016-04-28 09:36] [ALPM-SCRIPTLET] gpg: depth: 1  valid:  16  signed:  66  trust: 0-, 0q, 0n, 16m, 0f, 0u
[2016-04-28 09:36] [ALPM-SCRIPTLET] gpg: depth: 2  valid:  66  signed:   7  trust: 66-, 0q, 0n, 0m, 0f, 0u
[2016-04-28 09:36] [ALPM-SCRIPTLET] gpg: next trustdb check due at 2016-10-19
[2016-04-28 09:36] [ALPM-SCRIPTLET] ==> Locally signing trusted keys in keyring...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Locally signing key 0E8B644079F599DFC1DDC3973348882F6AC6A4C2...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Locally signing key 684148BB25B49E986A4944C55184252D824B18E8...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Locally signing key 91FFE0700E80619CEB73235CA88E23E377514E00...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Locally signing key 44D4A033AC140143927397D47EFD567D4C7EA887...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Locally signing key 27FFC4769E19F096D41D9265A04F9397CDFD6BB0...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Locally signing key AB19265E5D7D20687D303246BA1DFB64FFF979E7...
[2016-04-28 09:36] [ALPM-SCRIPTLET] ==> Importing owner trust values...
[2016-04-28 09:36] [ALPM-SCRIPTLET] ==> Disabling revoked keys in keyring...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Disabling key F5A361A3A13554B85E57DDDAAF7EF7873CFD4BB6...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Disabling key 7FA647CD89891DEDC060287BB9113D1ED21E1A55...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Disabling key D4DE5ABDE2A7287644EAC7E36D1A9E70E19DAA50...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Disabling key BC1FBE4D2826A0B51E47ED62E2539214C6C11350...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Disabling key 9515D8A8EAB88E49BB65EDBCE6B456CAF15447D5...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Disabling key 4A8B17E20B88ACA61860009B5CED81B7C2E5C0D2...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Disabling key 63F395DE2D6398BBE458F281F2DBB4931985A992...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Disabling key 0B20CA1931F5DA3A70D0F8D2EA6836E1AB441196...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Disabling key 8F76BEEA0289F9E1D3E229C05F946DED983D4366...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Disabling key 66BD74A036D522F51DD70A3C7F2A16726521E06D...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Disabling key 81D7F8241DB38BC759C80FCE3A726C6170E80477...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Disabling key E7210A59715F6940CF9A4E36A001876699AD6E84...
[2016-04-28 09:36] [ALPM-SCRIPTLET] ==> Updating trust database...
[2016-04-28 09:36] [ALPM] upgraded manjaro-keyring (20160302-2 -> 20160416-1)
[2016-04-28 09:36] [ALPM-SCRIPTLET] ==> Appending keys from manjaro.gpg...
[2016-04-28 09:36] [ALPM-SCRIPTLET] gpg: depth: 1  valid:  16  signed:  67  trust: 0-, 0q, 0n, 16m, 0f, 0u
[2016-04-28 09:36] [ALPM-SCRIPTLET] gpg: depth: 2  valid:  67  signed:   7  trust: 67-, 0q, 0n, 0m, 0f, 0u
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Locally signing key 7C89F4D439B2BFACF425107B62443D89B35859F8...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Locally signing key 22C903DE964E6FE321656E318DB9F8C18DF53602...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Locally signing key 16DC688DF3EECC72323954237EC47C82A42D53A2...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Locally signing key 5A97ED6B72418199F0C22B23137C934B5DCB998E...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Locally signing key B4663188A692DB1E45A98EE95BD96CC4247B52CC...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Locally signing key 35B4FF23EA9477582C2A0AF12B80869C5C0102A6...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Locally signing key 1E7908935AAB9A00D6B47503363DFFFD59152F77...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Locally signing key 77DC01C9971AC3C39A0626F72C089F09AC97B894...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Locally signing key 74C2F2CC05A0AB7D859839938934292D604F8BA2...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Locally signing key 39F0EC1AE50B37E5F3196F09DAD3B211663CA268...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Locally signing key E4CDFE50A2DA85D58C8A8C70CAA6A59611C7F07E...
[2016-04-28 09:36] [ALPM-SCRIPTLET] gpg: setting ownertrust to 4
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Disabling key FAA6840E8C3FC7F89BEE0DC8AC7AB10BCB6CDD17...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Disabling key 540DE7083B89314CF70EA6F0C1B1AD0DA80EBF3E...
[2016-04-28 09:36] [ALPM-SCRIPTLET] gpg: depth: 0  valid:   1  signed:  17  trust: 0-, 0q, 0n, 0m, 0f, 1u
[2016-04-28 09:36] [ALPM-SCRIPTLET] gpg: depth: 1  valid:  17  signed:  66  trust: 0-, 0q, 0n, 17m, 0f, 0u
[2016-04-28 09:36] [ALPM] upgraded pacman-mirrorlist (20160404-1 -> 20160423-1)
[2016-04-28 09:36] [ALPM-SCRIPTLET] :: Querying servers, this may take some time...
[2016-04-28 09:37] [ALPM-SCRIPTLET] :: Generated and saved '/etc/pacman.d/mirrorlist' mirrorlist.
[2016-04-28 09:37] [ALPM-SCRIPTLET] hint: use `pacman-mirrors` to generate and update your pacman mirrorlist.
[2016-04-28 09:37] [ALPM] upgraded libtasn1 (4.7-1 -> 4.8-1)
[2016-04-28 09:37] [ALPM] upgraded sqlite (3.12.0-1 -> 3.12.2-1)
[2016-04-28 09:37] [ALPM] upgraded gnutls (3.4.10-1 -> 3.4.11-1)
[2016-04-28 09:37] [ALPM] upgraded pango (1.39.0-1 -> 1.40.1-1)
[2016-04-28 09:37] [ALPM] upgraded adwaita-icon-theme (3.18.0-1 -> 3.20-1)
[2016-04-28 09:37] [ALPM] upgraded at-spi2-core (2.18.3-1 -> 2.20.1-1)
[2016-04-28 09:37] [ALPM] upgraded atk (2.18.0-1 -> 2.20.0-1)
[2016-04-28 09:37] [ALPM] upgraded at-spi2-atk (2.18.1-1 -> 2.20.1-1)
[2016-04-28 09:37] [ALPM] upgraded btrfs-progs (4.4.1-1 -> 4.5.1-1)
[2016-04-28 09:37] [ALPM] upgraded shared-mime-info (1.5-1 -> 1.6-1)
[2016-04-28 09:37] [ALPM] upgraded dconf (0.24.0-1 -> 0.26.0-1)
[2016-04-28 09:37] [ALPM] upgraded colord (1.2.12-1 -> 1.3.2-1)
[2016-04-28 09:37] [ALPM] upgraded libxkbcommon (0.6.0-1 -> 0.6.1-1)
[2016-04-28 09:37] [ALPM] upgraded json-glib (1.0.4-1 -> 1.2.0-1)
[2016-04-28 09:37] [ALPM] installed wayland-protocols (1.3-1)
[2016-04-28 09:37] [ALPM] upgraded gsettings-desktop-schemas (3.18.1-1 -> 3.20.0-1)
[2016-04-28 09:37] [ALPM] upgraded glib-networking (2.46.1-1 -> 2.48.0-1)
[2016-04-28 09:37] [ALPM] upgraded libsoup (2.52.2-1 -> 2.54.0.1-1)
[2016-04-28 09:37] [ALPM] upgraded gtk3 (3.18.9-1 -> 3.20.3-1)
[2016-04-28 09:37] [ALPM] upgraded libinput (1.2.2-1 -> 1.2.4-1)
[2016-04-28 09:37] [ALPM] upgraded clutter (1.24.2-1 -> 1.26.0-1)
[2016-04-28 09:37] [ALPM] upgraded clutter-gtk (1.6.6-1 -> 1.8.0-1)
[2016-04-28 09:37] [ALPM] upgraded consolekit (1.1.0-3 -> 1.1.0-6)
[2016-04-28 09:37] [ALPM] upgraded cpupower (4.5-1 -> 4.5-2)
[2016-04-28 09:37] [ALPM] upgraded poppler (0.41.0-1 -> 0.42.0-1)
[2016-04-28 09:37] [ALPM] upgraded ocl-icd (2.2.8-1 -> 2.2.9-1)
[2016-04-28 09:37] [ALPM] upgraded imagemagick (6.9.3.7-1 -> 6.9.3.8-1)
[2016-04-28 09:37] [ALPM] upgraded cups-filters (1.8.3-1 -> 1.8.3-2)
[2016-04-28 09:37] [ALPM] upgraded dconf-editor (3.18.2-1 -> 3.20.1-1)
[2016-04-28 09:37] [ALPM] upgraded device-mapper (2.02.148-1 -> 2.02.149-1)
[2016-04-28 09:37] [ALPM] upgraded dhcpcd (6.10.1-1 -> 6.10.2-1)
[2016-04-28 09:37] [ALPM] upgraded ethtool (1:4.2-1 -> 1:4.5-1)
[2016-04-28 09:37] [ALPM] upgraded f2fs-tools (1.6.0-1 -> 1.6.1-1)
[2016-04-28 09:37] [ALPM] upgraded file (5.25-1 -> 5.26-1)
[2016-04-28 09:37] [ALPM] upgraded unzip (6.0-11 -> 6.0-12)
[2016-04-28 09:37] [ALPM] upgraded file-roller (3.16.4-1 -> 3.20.1-1)
[2016-04-28 09:37] [ALPM] upgraded icu (56.1-2 -> 57.1-1)
[2016-04-28 09:37] [ALPM] upgraded libraw1394 (2.1.1-1 -> 2.1.2-1)
[2016-04-28 09:38] [ALPM] upgraded firefox (45.0.1-1 -> 45.0.2-1)
[2016-04-28 09:38] [ALPM] upgraded firefox-i18n-en-us (45.0.1-1 -> 45.0.2-1)
[2016-04-28 09:38] [ALPM] upgraded firefox-i18n-es-es (45.0.1-1 -> 45.0.2-1)
[2016-04-28 09:38] [ALPM] upgraded gcr (3.18.0-1 -> 3.20.0-1)
[2016-04-28 09:38] [ALPM] upgraded glibmm (2.46.3-1 -> 2.48.1-1)
[2016-04-28 09:38] [ALPM] upgraded gnome-keyring (1:3.18.3-1 -> 1:3.20.0-1)
[2016-04-28 09:38] [ALPM] upgraded gnome-themes-standard (3.18.0-1 -> 3.20-1)
[2016-04-28 09:38] [ALPM] upgraded gobject-introspection-runtime (1.46.0-1 -> 1.48.0-1)
[2016-04-28 09:38] [ALPM] upgraded gstreamer (1.6.3-1 -> 1.8.1-1)
[2016-04-28 09:38] [ALPM] upgraded gst-plugins-base-libs (1.6.3-1 -> 1.8.1-1)
[2016-04-28 09:38] [ALPM] upgraded gst-libav (1.6.3-3 -> 1.8.1-1)
[2016-04-28 09:38] [ALPM] upgraded gst-plugins-base (1.6.3-1 -> 1.8.1-1)
[2016-04-28 09:38] [ALPM] upgraded imlib2 (1.4.7-1 -> 1.4.8-1)
[2016-04-28 09:38] [ALPM] upgraded gst-plugins-good (1.6.3-1 -> 1.8.1-1)
[2016-04-28 09:38] [ALPM] upgraded gtksourceview3 (3.18.2-1 -> 3.20.1-1)
[2016-04-28 09:38] [ALPM] upgraded gvfs (1.26.3-1 -> 1.28.1-1)
[2016-04-28 09:38] [ALPM] upgraded gvfs-mtp (1.26.3-1 -> 1.28.1-1)
[2016-04-28 09:38] [ALPM] upgraded harfbuzz-icu (1.2.4-1 -> 1.2.6-1)
[2016-04-28 09:38] [ALPM] upgraded inxi (2.2.36-1 -> 2.2.38-1)
[2016-04-28 09:38] [ALPM] installed libmnl (1.0.3-2)
[2016-04-28 09:38] [ALPM] installed libnftnl (1.0.5-1)
[2016-04-28 09:38] [ALPM] upgraded iptables (1.4.21-3 -> 1.6.0-1)
[2016-04-28 09:38] [ALPM] upgraded iproute2 (4.4.0-1 -> 4.5.0-2)
[2016-04-28 09:38] [ALPM] upgraded iputils (20150815.1c59920-3 -> 20160308.0db72a4-1)
[2016-04-28 09:38] [ALPM] upgraded libxkbcommon-x11 (0.6.0-1 -> 0.6.1-1)
[2016-04-28 09:38] [ALPM] upgraded qt5-base (5.6.0-2 -> 5.6.0-4)
[2016-04-28 09:38] [ALPM] upgraded kitemmodels (5.20.0-1 -> 5.21.0-1)
[2016-04-28 09:38] [ALPM] upgraded libcanberra (0.30-5 -> 0.30-6)
[2016-04-28 09:38] [ALPM] upgraded libgtop (2.32.0-1 -> 2.34.0-1)
[2016-04-28 09:38] [ALPM] upgraded libqmi (1.12.8-1 -> 1.12.10-1)
[2016-04-28 09:38] [ALPM] upgraded lightdm (1:1.18.0-1 -> 1:1.18.1-1)
[2016-04-28 09:38] [ALPM] upgraded linux44-ndiswrapper (1.59-7 -> 1.59-9)
[2016-04-28 09:38] [ALPM] upgraded linux44-virtualbox-guest-modules (5.0.16-8 -> 5.0.18-1)
[2016-04-28 09:38] [ALPM] upgraded logrotate (3.9.1-1 -> 3.9.2-1)
[2016-04-28 09:38] [ALPM] upgraded lvm2 (2.02.148-1 -> 2.02.149-1)
[2016-04-28 09:38] [ALPM] upgraded manjaro-firmware (20160117-1 -> 20160419-1)
[2016-04-28 09:38] [ALPM] upgraded manjaro-settings-manager (0.4.14-1 -> 0.4.14-2)
[2016-04-28 09:38] [ALPM] upgraded pangomm (2.38.1-2 -> 2.40.0-1)
[2016-04-28 09:38] [ALPM] upgraded poppler-qt5 (0.41.0-1 -> 0.42.0-1)
[2016-04-28 09:38] [ALPM] upgraded pygobject-devel (3.18.2-1 -> 3.20.0-1)
[2016-04-28 09:38] [ALPM] upgraded python-gobject (3.18.2-1 -> 3.20.0-1)
[2016-04-28 09:38] [ALPM] upgraded python2-gobject (3.18.2-1 -> 3.20.0-1)
[2016-04-28 09:38] [ALPM] upgraded syslinux (6.03-5 -> 6.03-6)
[2016-04-28 09:38] [ALPM-SCRIPTLET]
[2016-04-28 09:38] [ALPM-SCRIPTLET] ==> For setting up Syslinux BIOS using the syslinux-install_update script follow
[2016-04-28 09:38] [ALPM-SCRIPTLET]     https://wiki.archlinux.org/index.php/Syslinux#Automatic_Install
[2016-04-28 09:38] [ALPM] upgraded tint2 (0.12.8-1 -> 0.12.9-1)
[2016-04-28 09:38] [ALPM] warning: /usr/lib/ufw/user6.rules saved as /usr/lib/ufw/user6.rules.pacsave
[2016-04-28 09:38] [ALPM] warning: /usr/lib/ufw/user.rules saved as /usr/lib/ufw/user.rules.pacsave
[2016-04-28 09:38] [ALPM] upgraded ufw (0.34-1 -> 0.35-1)
[2016-04-28 09:38] [ALPM] upgraded vim-spell-en (20120802-1 -> 20150901-1)
[2016-04-28 09:38] [ALPM] upgraded vim-spell-es (20120802-1 -> 20150901-1)
[2016-04-28 09:38] [ALPM] upgraded virtualbox-guest-utils (5.0.16-0.1 -> 5.0.18-0.1)
[2016-04-28 09:38] [ALPM] upgraded vte-common (0.42.5-1 -> 0.44.1-1)
[2016-04-28 09:38] [ALPM] upgraded vte3 (0.42.5-1 -> 0.44.1-1)
[2016-04-28 09:38] [ALPM] upgraded webkitgtk (2.4.10-1 -> 2.4.11-1)
[2016-04-28 09:38] [ALPM] upgraded xdg-user-dirs (0.15-2 -> 0.15-4)
[2016-04-28 09:38] [ALPM-SCRIPTLET] /tmp/alpm_4ZMuGH/.INSTALL: line 8: systemctl: command not found
[2016-04-28 09:38] [ALPM] upgraded xdg-utils (1.1.1-1 -> 1.1.1-2)
[2016-04-28 09:38] [ALPM] upgraded xfce-theme-greenbird (20150412-1 -> 20150412-2)
[2016-04-28 09:38] [ALPM] upgraded xfce4-whiskermenu-plugin (1.5.2-1 -> 1.5.3-1)
[2016-04-28 09:38] [ALPM] transaction completed
Offline v17564
  • I'm new. Be nice!
  • Skill: Novice
« Reply #4 on: 28. April 2016, 12:19:20 »
Hello @aaditya.
System: Manjaro OpenRC 15.12 x64
I make a clean install, in a VirtualBox, of the version: Manjaro OpenRC 15.12 x64 that it's installed in one of my home computer. After, i install all updates, run "pacdiff" and reboot. In the new boot, ligthDM don't start, don't show the login screen. The theme is the default theme of the iso: aaditya
The file "error.log" don't exist.
This the complete "everything.log" (the hour difference is for the UTC/local):
Code: [Select]
Apr 28 13:27:00 manjaro syslog-ng[1555]: syslog-ng starting up; version='3.6.3'
Apr 28 13:27:00 manjaro acpid[1586]: starting up with netlink and the input layer
Apr 28 13:27:00 manjaro acpid[1586]: 2 rules loaded
Apr 28 13:27:00 manjaro acpid[1586]: waiting for events: event logging is off
Apr 28 13:27:01 manjaro /etc/init.d/alsasound[1818]: No mixer config in /var/lib/alsa/asound.state, you have to unmute your card!
Apr 28 13:27:01 manjaro crond[1892]: (CRON) STARTUP (1.5.0)
Apr 28 13:27:01 manjaro crond[1892]: (CRON) INFO (Syslog will be used instead of sendmail.)
Apr 28 13:27:01 manjaro crond[1892]: (CRON) INFO (RANDOM_DELAY will be scaled with factor 20% if used.)
Apr 28 13:27:01 manjaro bluetoothd[1841]: Bluetooth daemon 5.36
Apr 28 13:27:02 manjaro crond[1892]: (CRON) INFO (running with inotify support)
Apr 28 13:27:02 manjaro kernel: Bluetooth: Core ver 2.20
Apr 28 13:27:02 manjaro kernel: NET: Registered protocol family 31
Apr 28 13:27:02 manjaro kernel: Bluetooth: HCI device and connection manager initialized
Apr 28 13:27:02 manjaro kernel: Bluetooth: HCI socket layer initialized
Apr 28 13:27:02 manjaro kernel: Bluetooth: L2CAP socket layer initialized
Apr 28 13:27:02 manjaro kernel: Bluetooth: SCO socket layer initialized
Apr 28 13:27:02 manjaro bluetoothd[1841]: Starting SDP server
Apr 28 13:27:02 manjaro bluetoothd[1841]: Bluetooth management interface 1.9 initialized
Apr 28 13:27:02 manjaro kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Apr 28 13:27:02 manjaro kernel: Bluetooth: BNEP filters: protocol multicast
Apr 28 13:27:02 manjaro kernel: Bluetooth: BNEP socket layer initialized
Apr 28 13:27:02 manjaro NetworkManager[1442]: <info>  use BlueZ version 5
Apr 28 13:27:02 manjaro avahi-daemon[1924]: Found user 'avahi' (UID 84) and group 'avahi' (GID 84).
Apr 28 13:27:02 manjaro avahi-daemon[1924]: Successfully dropped root privileges.
Apr 28 13:27:02 manjaro avahi-daemon[1924]: avahi-daemon 0.6.32-rc starting up.
Apr 28 13:27:02 manjaro avahi-daemon[1924]: Successfully called chroot().
Apr 28 13:27:02 manjaro avahi-daemon[1924]: Successfully dropped remaining capabilities.
Apr 28 13:27:02 manjaro avahi-daemon[1924]: Loading service file /services/sftp-ssh.service.
Apr 28 13:27:02 manjaro avahi-daemon[1924]: Loading service file /services/ssh.service.
Apr 28 13:27:02 manjaro avahi-daemon[1924]: Joining mDNS multicast group on interface enp0s3.IPv6 with address fe80::a00:27ff:fe03:6e6d.
Apr 28 13:27:02 manjaro avahi-daemon[1924]: New relevant interface enp0s3.IPv6 for mDNS.
Apr 28 13:27:02 manjaro avahi-daemon[1924]: Joining mDNS multicast group on interface enp0s3.IPv4 with address 10.0.2.15.
Apr 28 13:27:02 manjaro avahi-daemon[1924]: New relevant interface enp0s3.IPv4 for mDNS.
Apr 28 13:27:02 manjaro avahi-daemon[1924]: Network interface enumeration completed.
Apr 28 13:27:02 manjaro avahi-daemon[1924]: Registering new address record for fe80::a00:27ff:fe03:6e6d on enp0s3.*.
Apr 28 13:27:02 manjaro avahi-daemon[1924]: Registering new address record for 10.0.2.15 on enp0s3.IPv4.
Apr 28 13:27:02 manjaro acpid[1586]: client connected from 1803[0:0]
Apr 28 13:27:02 manjaro acpid[1586]: 1 client rule loaded
Apr 28 13:27:03 manjaro avahi-daemon[1924]: Server startup complete. Host name is manjaro.local. Local service cookie is 382100718.
Apr 28 13:27:03 manjaro avahi-daemon[1924]: Service "manjaro" (/services/ssh.service) successfully established.
Apr 28 13:27:03 manjaro avahi-daemon[1924]: Service "manjaro" (/services/sftp-ssh.service) successfully established.
Apr 28 13:27:04 manjaro NetworkManager[1442]: <info>  startup complete
Apr 28 13:27:04 manjaro console-kit-daemon[1634]: WARNING: Failed to let cgmanager know that it can remove the cgroup when it's empty, the error was: invalid request
Apr 28 13:27:25 manjaro console-kit-daemon[1634]: WARNING: Failed to let cgmanager know that it can remove the cgroup when it's empty, the error was: invalid request
Apr 28 13:27:27 manjaro kernel: fuse init (API version 7.23)
Apr 28 13:27:27 manjaro dbus[1416]: [system] Activating service name='org.freedesktop.UPower' (using servicehelper)
Apr 28 13:27:28 manjaro dbus[1416]: [system] Successfully activated service 'org.freedesktop.UPower'
Apr 28 13:27:28 manjaro dbus[1416]: [system] Activating service name='org.freedesktop.UDisks2' (using servicehelper)
Apr 28 13:27:28 manjaro udisksd[2242]: udisks daemon version 2.1.6 starting
Apr 28 13:27:28 manjaro dbus[1416]: [system] Successfully activated service 'org.freedesktop.UDisks2'
Apr 28 13:27:28 manjaro udisksd[2242]: Acquired the name org.freedesktop.UDisks2 on the system message bus
--- Updates installed bettewn 13:28 and 13:38, first reboot -----
Apr 28 13:34:44 manjaro NetworkManager[1442]: <info>  kernel firmware directory '/usr/lib/firmware' changed
Apr 28 13:35:12 manjaro dbus[1416]: [system] Reloaded configuration
Apr 28 13:35:12 manjaro avahi-daemon[1924]: Files changed, reloading.
Apr 28 13:35:12 manjaro avahi-daemon[1924]: Service group file /services/ssh.service vanished, removing services.
Apr 28 13:35:12 manjaro avahi-daemon[1924]: Service group file /services/sftp-ssh.service vanished, removing services.
Apr 28 13:35:12 manjaro avahi-daemon[1924]: No service file found in /etc/avahi/services.
Apr 28 13:35:14 manjaro dbus[1416]: [system] Reloaded configuration
Apr 28 13:35:20 manjaro dbus[1416]: [system] Reloaded configuration
Apr 28 13:35:21 manjaro dbus[1416]: [system] Reloaded configuration
Apr 28 13:35:23 manjaro dbus[1416]: [system] Reloaded configuration
Apr 28 13:35:55 manjaro dbus[1416]: [system] Reloaded configuration
Apr 28 13:36:02 manjaro dbus[1416]: [system] Reloaded configuration
Apr 28 13:36:03 manjaro dbus[1416]: [system] Reloaded configuration
Apr 28 13:36:07 manjaro NetworkManager[1442]: <info>  kernel firmware directory '/usr/lib/firmware' changed
Apr 28 13:36:08 manjaro dbus[1416]: [system] Reloaded configuration
Apr 28 13:36:09 manjaro dbus[1416]: [system] Reloaded configuration
Apr 28 13:36:11 manjaro dbus[1416]: [system] Reloaded configuration
Apr 28 13:36:11 manjaro NetworkManager[1442]: <warn>  error requesting auth for org.freedesktop.NetworkManager.wifi.share.protected: (0) Authorization check failed: GDBus.Error:org.freedesktop.PolicyKit1.Error.Failed: Action org.freedesktop.NetworkManager.wifi.share.protected is not registered
Apr 28 13:36:11 manjaro NetworkManager[1442]: <warn>  error requesting auth for org.freedesktop.NetworkManager.wifi.share.open: (0) Authorization check failed: GDBus.Error:org.freedesktop.PolicyKit1.Error.Failed: Action org.freedesktop.NetworkManager.wifi.share.open is not registered
Apr 28 13:36:11 manjaro NetworkManager[1442]: <warn>  error requesting auth for org.freedesktop.NetworkManager.enable-disable-network: (0) Authorization check failed: GDBus.Error:org.freedesktop.PolicyKit1.Error.Failed: Action org.freedesktop.NetworkManager.enable-disable-network is not registered
Apr 28 13:36:11 manjaro NetworkManager[1442]: <warn>  error requesting auth for org.freedesktop.NetworkManager.sleep-wake: (0) Authorization check failed: GDBus.Error:org.freedesktop.PolicyKit1.Error.Failed: Action org.freedesktop.NetworkManager.sleep-wake is not registered
Apr 28 13:36:11 manjaro NetworkManager[1442]: <warn>  error requesting auth for org.freedesktop.NetworkManager.enable-disable-wifi: (0) Authorization check failed: GDBus.Error:org.freedesktop.PolicyKit1.Error.Failed: Action org.freedesktop.NetworkManager.enable-disable-wifi is not registered
Apr 28 13:36:11 manjaro NetworkManager[1442]: <warn>  error requesting auth for org.freedesktop.NetworkManager.enable-disable-wwan: (0) Authorization check failed: GDBus.Error:org.freedesktop.PolicyKit1.Error.Failed: Action org.freedesktop.NetworkManager.enable-disable-wwan is not registered
Apr 28 13:36:11 manjaro NetworkManager[1442]: <warn>  error requesting auth for org.freedesktop.NetworkManager.enable-disable-wimax: (0) Authorization check failed: GDBus.Error:org.freedesktop.PolicyKit1.Error.Failed: Action org.freedesktop.NetworkManager.enable-disable-wimax is not registered
Apr 28 13:36:11 manjaro NetworkManager[1442]: <warn>  error requesting auth for org.freedesktop.NetworkManager.network-control: (0) Authorization check failed: GDBus.Error:org.freedesktop.PolicyKit1.Error.Failed: Action org.freedesktop.NetworkManager.network-control is not registered
Apr 28 13:36:11 manjaro NetworkManager[1442]: <warn>  error requesting auth for org.freedesktop.NetworkManager.settings.modify.system: (0) Authorization check failed: GDBus.Error:org.freedesktop.PolicyKit1.Error.Failed: Action org.freedesktop.NetworkManager.settings.modify.system is not registered
Apr 28 13:36:11 manjaro NetworkManager[1442]: <warn>  error requesting auth for org.freedesktop.NetworkManager.settings.modify.own: (0) Authorization check failed: GDBus.Error:org.freedesktop.PolicyKit1.Error.Failed: Action org.freedesktop.NetworkManager.settings.modify.own is not registered
Apr 28 13:36:11 manjaro NetworkManager[1442]: <warn>  error requesting auth for org.freedesktop.NetworkManager.settings.modify.hostname: (0) Authorization check failed: GDBus.Error:org.freedesktop.PolicyKit1.Error.Failed: Action org.freedesktop.NetworkManager.settings.modify.hostname is not registered
Apr 28 13:36:12 manjaro dbus[1416]: [system] Reloaded configuration
Apr 28 13:36:12 manjaro NetworkManager[1442]: <info>  VPN: unloaded org.freedesktop.NetworkManager.openvpn
Apr 28 13:36:12 manjaro NetworkManager[1442]: <info>  VPN: loaded org.freedesktop.NetworkManager.openvpn
Apr 28 13:36:20 manjaro dbus[1416]: [system] Reloaded configuration
Apr 28 13:36:21 manjaro dbus[1416]: [system] Reloaded configuration
Apr 28 13:37:53 manjaro dbus[1416]: [system] Activating service name='org.manjaro.pamac' (using servicehelper)
Apr 28 13:37:53 manjaro dbus[1416]: [system] Successfully activated service 'org.manjaro.pamac'
Apr 28 13:40:52 manjaro shutdown[11897]: shutting down for system reboot
Apr 28 13:40:52 manjaro init[1]: Switching to runlevel: 6
Apr 28 13:40:54 manjaro crond[1892]: (CRON) INFO (Shutting down)
Apr 28 13:40:55 manjaro bluetoothd[1841]: Terminating
Apr 28 13:40:55 manjaro bluetoothd[1841]: Stopping SDP server
Apr 28 13:40:55 manjaro bluetoothd[1841]: Exit
Apr 28 13:40:55 manjaro console-kit-daemon[1634]: WARNING: Failed to get the session id from cgmanager, the error was: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Apr 28 13:40:55 manjaro console-kit-daemon[1634]: WARNING: Failed to get the session id from cgmanager, the error was: Connection is closed
Apr 28 13:40:55 manjaro console-kit-daemon[1634]: WARNING: Couldn't read /proc/2164/environ: Failed to open file '/proc/2164/environ': No such file or directory
Apr 28 13:40:56 manjaro avahi-daemon[1924]: Got SIGTERM, quitting.
Apr 28 13:40:56 manjaro avahi-daemon[1924]: Leaving mDNS multicast group on interface enp0s3.IPv6 with address fe80::a00:27ff:fe03:6e6d.
Apr 28 13:40:56 manjaro avahi-daemon[1924]: Leaving mDNS multicast group on interface enp0s3.IPv4 with address 10.0.2.15.
Apr 28 13:40:56 manjaro avahi-daemon[1924]: avahi-daemon 0.6.32-rc exiting.
Apr 28 13:40:56 manjaro acpid[1586]: exiting
Apr 28 13:40:56 manjaro syslog-ng[1555]: syslog-ng shutting down; version='3.6.3'
Apr 28 11:47:36 manjaro syslog-ng[1416]: syslog-ng starting up; version='3.6.3'
Apr 28 11:47:36 manjaro acpid[1445]: starting up with netlink and the input layer
Apr 28 11:47:36 manjaro acpid[1445]: 2 rules loaded
Apr 28 11:47:36 manjaro acpid[1445]: waiting for events: event logging is off
Apr 28 11:47:37 manjaro kernel: Bluetooth: Core ver 2.20
Apr 28 11:47:37 manjaro kernel: NET: Registered protocol family 31
Apr 28 11:47:37 manjaro kernel: Bluetooth: HCI device and connection manager initialized
Apr 28 11:47:37 manjaro kernel: Bluetooth: HCI socket layer initialized
Apr 28 11:47:37 manjaro kernel: Bluetooth: L2CAP socket layer initialized
Apr 28 11:47:37 manjaro kernel: Bluetooth: SCO socket layer initialized
Apr 28 11:47:37 manjaro bluetoothd[1704]: Bluetooth daemon 5.39
Apr 28 11:47:37 manjaro crond[1757]: (CRON) STARTUP (1.5.0)
Apr 28 11:47:37 manjaro crond[1757]: (CRON) INFO (Syslog will be used instead of sendmail.)
Apr 28 11:47:37 manjaro crond[1757]: (CRON) INFO (RANDOM_DELAY will be scaled with factor 44% if used.)
Apr 28 11:47:38 manjaro crond[1757]: (CRON) INFO (running with inotify support)
Apr 28 11:47:38 manjaro avahi-daemon[1783]: Found user 'avahi' (UID 84) and group 'avahi' (GID 84).
Apr 28 11:47:38 manjaro avahi-daemon[1783]: Successfully dropped root privileges.
Apr 28 11:47:38 manjaro avahi-daemon[1783]: avahi-daemon 0.6.32 starting up.
Apr 28 11:47:38 manjaro avahi-daemon[1783]: Successfully called chroot().
Apr 28 11:47:38 manjaro avahi-daemon[1783]: Successfully dropped remaining capabilities.
Apr 28 11:47:38 manjaro avahi-daemon[1783]: No service file found in /etc/avahi/services.
Apr 28 11:47:38 manjaro avahi-daemon[1783]: Joining mDNS multicast group on interface enp0s3.IPv6 with address fe80::a00:27ff:fe03:6e6d.
Apr 28 11:47:38 manjaro avahi-daemon[1783]: New relevant interface enp0s3.IPv6 for mDNS.
Apr 28 11:47:38 manjaro avahi-daemon[1783]: Joining mDNS multicast group on interface enp0s3.IPv4 with address 10.0.2.15.
Apr 28 11:47:38 manjaro avahi-daemon[1783]: New relevant interface enp0s3.IPv4 for mDNS.
Apr 28 11:47:38 manjaro avahi-daemon[1783]: Network interface enumeration completed.
Apr 28 11:47:38 manjaro avahi-daemon[1783]: Registering new address record for fe80::a00:27ff:fe03:6e6d on enp0s3.*.
Apr 28 11:47:38 manjaro avahi-daemon[1783]: Registering new address record for 10.0.2.15 on enp0s3.IPv4.
Apr 28 11:47:38 manjaro bluetoothd[1704]: Starting SDP server
Apr 28 11:47:38 manjaro bluetoothd[1704]: Bluetooth management interface 1.9 initialized
Apr 28 11:47:38 manjaro kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Apr 28 11:47:38 manjaro kernel: Bluetooth: BNEP filters: protocol multicast
Apr 28 11:47:38 manjaro kernel: Bluetooth: BNEP socket layer initialized
Apr 28 11:47:38 manjaro NetworkManager[1302]: <info>  use BlueZ version 5
Apr 28 11:47:38 manjaro acpid[1445]: client connected from 1663[0:0]
Apr 28 11:47:38 manjaro acpid[1445]: 1 client rule loaded
Apr 28 11:47:38 manjaro avahi-daemon[1783]: Server startup complete. Host name is manjaro.local. Local service cookie is 1399606708.
Apr 28 11:47:39 manjaro NetworkManager[1302]: <info>  startup complete
# cat pamac.log
Code: [Select]
[2016-04-28 13:28] Upgraded manjaro-system (20151213-2 -> 20160301-1)
[2016-04-28 13:33] Upgraded linux-api-headers (4.1.4-1 -> 4.4.1-1)
[2016-04-28 13:33] Upgraded tzdata (2015g-1 -> 2016d-1)
[2016-04-28 13:33] Upgraded iana-etc (20151016-1 -> 20160314-1)
[2016-04-28 13:33] Generating locales...
[2016-04-28 13:33]   en_US.UTF-8... done
[2016-04-28 13:33]   en_US.ISO-8859-1... done
[2016-04-28 13:33]   es_ES.UTF-8... done
[2016-04-28 13:33] Generation complete.
[2016-04-28 13:33] Upgraded glibc (2.22-3 -> 2.23-1)
[2016-04-28 13:33] Upgraded gcc-libs (5.3.0-3 -> 5.3.0-5)
[2016-04-28 13:33] Upgraded acpid (2.0.25-1 -> 2.0.27-1)
[2016-04-28 13:33] ==> Install one of the optional depends for network support!
[2016-04-28 13:33] Upgraded openrc (0.19.1-1 -> 0.20.5-1)
[2016-04-28 13:33] Upgraded libcap (2.24-2 -> 2.25-1)
[2016-04-28 13:33] Upgraded cracklib (2.9.4-1 -> 2.9.6-1)
[2016-04-28 13:33] Upgraded libutil-linux (2.27.1-1 -> 2.28-1)
[2016-04-28 13:33] Upgraded perl (5.22.1-1 -> 5.22.1-2)
[2016-04-28 13:33] Upgraded openssl (1.0.2.e-1 -> 1.0.2.g-3)
[2016-04-28 13:33] Upgraded libldap (2.4.43-1 -> 2.4.44-1)
[2016-04-28 13:33] Upgraded krb5 (1.13.2-1 -> 1.13.2-3)
[2016-04-28 13:33] ==> run 'rc-update add acpid default'
[2016-04-28 13:33] Upgraded acpid-openrc (20151014-1 -> 20160402-1)
[2016-04-28 13:33] Upgraded pcre (8.38-2 -> 8.38-3)
[2016-04-28 13:33] Upgraded glib2 (2.46.2-2 -> 2.48.0-1)
[2016-04-28 13:33] Upgraded libpng (1.6.20-1 -> 1.6.21-1)
[2016-04-28 13:33] Upgraded gdk-pixbuf2 (2.32.3-1 -> 2.34.0-1)
[2016-04-28 13:33] Upgraded gtk-update-icon-cache (3.18.6-1 -> 3.20.3-1)
[2016-04-28 13:33] Upgraded libdatrie (0.2.9-1 -> 0.2.10-1)
[2016-04-28 13:33] Upgraded libthai (0.1.22-1 -> 0.1.24-1)
[2016-04-28 13:33] Upgraded graphite (1:1.3.3-3 -> 1:1.3.8-1)
[2016-04-28 13:33] Upgraded freetype2 (2.6.2-1 -> 2.6.3-1)
[2016-04-28 13:33] Upgraded harfbuzz (1.1.2-3 -> 1.2.6-1)
[2016-04-28 13:33] Upgraded expat (2.1.0-4 -> 2.1.1-1)
[2016-04-28 13:33] updating font cache... done.
[2016-04-28 13:33] Upgraded fontconfig (2.11.1-2 -> 2.11.95-1)
[2016-04-28 13:33] Upgraded libx86emu (1.1.23.1-1 -> 1.7_1-1)
[2016-04-28 13:33] Upgraded hwinfo (21.12_1-1 -> 21.23_1.2-1)
[2016-04-28 13:33] Upgraded libgcrypt (1.6.4-1 -> 1.7.0-1)
[2016-04-28 13:33] Upgraded hwids (20150717-1 -> 20160306-1)
[2016-04-28 13:33] Upgraded gmp (6.1.0-2 -> 6.1.0-3)
[2016-04-28 13:33] Upgraded coreutils (8.24-1 -> 8.25-1)
[2016-04-28 13:33] Upgraded util-linux (2.27.1-1 -> 2.28-1)
[2016-04-28 13:33] Upgraded eudev (3.1.5-2 -> 3.1.5-3)
[2016-04-28 13:33] Upgraded eudev-systemdcompat (226-1 -> 229-1)
[2016-04-28 13:33] Upgraded libxml2 (2.9.3-1 -> 2.9.3+14+gd5bd2a9-1)
[2016-04-28 13:33] Upgraded wayland (1.9.0-1 -> 1.10.0-1)
[2016-04-28 13:33] Upgraded libdrm (2.4.65-1 -> 2.4.67-2)
[2016-04-28 13:33] Upgraded libelf (0.164-2 -> 0.166-1)
[2016-04-28 13:33] Upgraded elfutils (0.164-2 -> 0.166-1)
[2016-04-28 13:33] Upgraded llvm-libs (3.7.0-6 -> 3.7.1-1)
[2016-04-28 13:33] Upgraded mesa (11.1.0-2 -> 11.2.1-1)
[2016-04-28 13:33] Upgraded mhwd-nvidia (1:352.63-1 -> 1:361.42-1)
[2016-04-28 13:33] Installed mhwd-amdgpu (1.1.0-1)
[2016-04-28 13:33] Upgraded mhwd-db (0.5.6-8 -> 0.5.7-4)
[2016-04-28 13:33] ==> Appending keys from archlinux.gpg...
[2016-04-28 13:33] gpg: 3 marginal(s) needed, 1 complete(s) needed, PGP trust model
[2016-04-28 13:33] gpg: depth: 0  valid:   1  signed:  14  trust: 0-, 0q, 0n, 0m, 0f, 1u
[2016-04-28 13:33] gpg: depth: 1  valid:  14  signed:  66  trust: 0-, 0q, 0n, 14m, 0f, 0u
[2016-04-28 13:33] gpg: depth: 2  valid:  66  signed:   7  trust: 66-, 0q, 0n, 0m, 0f, 0u
[2016-04-28 13:33] gpg: next trustdb check due at 2016-10-19
[2016-04-28 13:33] ==> Locally signing trusted keys in keyring...
[2016-04-28 13:33]   -> Locally signing key 0E8B644079F599DFC1DDC3973348882F6AC6A4C2...
[2016-04-28 13:33]   -> Locally signing key 684148BB25B49E986A4944C55184252D824B18E8...
[2016-04-28 13:33]   -> Locally signing key 91FFE0700E80619CEB73235CA88E23E377514E00...
[2016-04-28 13:33]   -> Locally signing key 44D4A033AC140143927397D47EFD567D4C7EA887...
[2016-04-28 13:33]   -> Locally signing key 27FFC4769E19F096D41D9265A04F9397CDFD6BB0...
[2016-04-28 13:33]   -> Locally signing key AB19265E5D7D20687D303246BA1DFB64FFF979E7...
[2016-04-28 13:33] ==> Importing owner trust values...
[2016-04-28 13:33] gpg: setting ownertrust to 4
[2016-04-28 13:33] ==> Disabling revoked keys in keyring...
[2016-04-28 13:33]   -> Disabling key F5A361A3A13554B85E57DDDAAF7EF7873CFD4BB6...
[2016-04-28 13:33]   -> Disabling key 7FA647CD89891DEDC060287BB9113D1ED21E1A55...
[2016-04-28 13:33]   -> Disabling key D4DE5ABDE2A7287644EAC7E36D1A9E70E19DAA50...
[2016-04-28 13:33]   -> Disabling key BC1FBE4D2826A0B51E47ED62E2539214C6C11350...
[2016-04-28 13:33]   -> Disabling key 9515D8A8EAB88E49BB65EDBCE6B456CAF15447D5...
[2016-04-28 13:33]   -> Disabling key 4A8B17E20B88ACA61860009B5CED81B7C2E5C0D2...
[2016-04-28 13:33]   -> Disabling key 63F395DE2D6398BBE458F281F2DBB4931985A992...
[2016-04-28 13:33]   -> Disabling key 0B20CA1931F5DA3A70D0F8D2EA6836E1AB441196...
[2016-04-28 13:33]   -> Disabling key 8F76BEEA0289F9E1D3E229C05F946DED983D4366...
[2016-04-28 13:33]   -> Disabling key 66BD74A036D522F51DD70A3C7F2A16726521E06D...
[2016-04-28 13:33]   -> Disabling key 81D7F8241DB38BC759C80FCE3A726C6170E80477...
[2016-04-28 13:33]   -> Disabling key E7210A59715F6940CF9A4E36A001876699AD6E84...
[2016-04-28 13:33] ==> Updating trust database...
[2016-04-28 13:33] Upgraded archlinux-keyring (20151220-1 -> 20160402-1)
[2016-04-28 13:33] Upgraded libssh2 (1.6.0-1 -> 1.7.0-2)
[2016-04-28 13:33] Upgraded findutils (4.4.2-6 -> 4.6.0-1)
[2016-04-28 13:33] Upgraded gzip (1.6-1 -> 1.7-1)
[2016-04-28 13:33] Upgraded texinfo (6.0-1 -> 6.1-1)
[2016-04-28 13:33] Upgraded libtasn1 (4.7-1 -> 4.8-1)
[2016-04-28 13:33] Upgraded p11-kit (0.23.1-3 -> 0.23.2-1)
[2016-04-28 13:33] Upgraded ca-certificates-mozilla (3.20.1-1 -> 3.23-3)
[2016-04-28 13:33] Upgraded curl (7.46.0-1 -> 7.48.0-1)
[2016-04-28 13:33] ==> Appending keys from manjaro.gpg...
[2016-04-28 13:33] gpg: depth: 0  valid:   1  signed:  15  trust: 0-, 0q, 0n, 0m, 0f, 1u
[2016-04-28 13:33] gpg: depth: 1  valid:  15  signed:  68  trust: 0-, 0q, 0n, 15m, 0f, 0u
[2016-04-28 13:33] gpg: depth: 2  valid:  68  signed:   7  trust: 68-, 0q, 0n, 0m, 0f, 0u
[2016-04-28 13:33]   -> Locally signing key 7C89F4D439B2BFACF425107B62443D89B35859F8...
[2016-04-28 13:33]   -> Locally signing key 22C903DE964E6FE321656E318DB9F8C18DF53602...
[2016-04-28 13:33]   -> Locally signing key 16DC688DF3EECC72323954237EC47C82A42D53A2...
[2016-04-28 13:33]   -> Locally signing key 5A97ED6B72418199F0C22B23137C934B5DCB998E...
[2016-04-28 13:33]   -> Locally signing key B4663188A692DB1E45A98EE95BD96CC4247B52CC...
[2016-04-28 13:33]   -> Locally signing key 35B4FF23EA9477582C2A0AF12B80869C5C0102A6...
[2016-04-28 13:33]   -> Locally signing key 1E7908935AAB9A00D6B47503363DFFFD59152F77...
[2016-04-28 13:33]   -> Locally signing key 77DC01C9971AC3C39A0626F72C089F09AC97B894...
[2016-04-28 13:33]   -> Locally signing key 74C2F2CC05A0AB7D859839938934292D604F8BA2...
[2016-04-28 13:33]   -> Locally signing key 39F0EC1AE50B37E5F3196F09DAD3B211663CA268...
[2016-04-28 13:33]   -> Locally signing key E4CDFE50A2DA85D58C8A8C70CAA6A59611C7F07E...
[2016-04-28 13:33]   -> Disabling key FAA6840E8C3FC7F89BEE0DC8AC7AB10BCB6CDD17...
[2016-04-28 13:33]   -> Disabling key 540DE7083B89314CF70EA6F0C1B1AD0DA80EBF3E...
[2016-04-28 13:33] gpg: depth: 0  valid:   1  signed:  17  trust: 0-, 0q, 0n, 0m, 0f, 1u
[2016-04-28 13:33] gpg: depth: 1  valid:  17  signed:  66  trust: 0-, 0q, 0n, 17m, 0f, 0u
[2016-04-28 13:33] Upgraded manjaro-keyring (20150809-1 -> 20160416-1)
[2016-04-28 13:33] Upgraded python (3.5.1-1 -> 3.5.1-2)
[2016-04-28 13:33] :: Querying servers, this may take some time...
[2016-04-28 13:34] :: Generated and saved '/etc/pacman.d/mirrorlist' mirrorlist.
[2016-04-28 13:34]
[2016-04-28 13:34] hint: use `pacman-mirrors` to generate and update your pacman mirrorlist.
[2016-04-28 13:34] Upgraded pacman-mirrorlist (20151220-1 -> 20160423-1)
[2016-04-28 13:34] Upgraded nettle (3.1.1-1 -> 3.2-1)
[2016-04-28 13:34] Upgraded gnutls (3.4.7-2 -> 3.4.11-1)
[2016-04-28 13:34] Upgraded sqlite (3.9.2-1 -> 3.12.2-1)
[2016-04-28 13:34] Upgraded gnupg (2.1.10-3 -> 2.1.11-1)
[2016-04-28 13:34] Upgraded pacman (4.2.1-4.1 -> 5.0.1-2)
[2016-04-28 13:34] Upgraded linux-firmware (20150904.6ebf5d5-1 -> 20160315.deb1d83-1)
[2016-04-28 13:34] Upgraded grep (2.22-1 -> 2.25-1)
[2016-04-28 13:34] Upgraded mkinitcpio-busybox (1.21.1-2 -> 1.24.1-1)
[2016-04-28 13:34] Upgraded mpfr (3.1.3.p4-1 -> 3.1.4-1)
[2016-04-28 13:34] Upgraded mkinitcpio (18-2 -> 19-1)
[2016-04-28 13:34] >>> Updating module dependencies. Please wait ...
[2016-04-28 13:34] >>> Generating initial ramdisk, using mkinitcpio.  Please wait...
[2016-04-28 13:34] ==> Building image from preset: /etc/mkinitcpio.d/linux41.preset: 'default'
[2016-04-28 13:34]   -> -k /boot/vmlinuz-4.1-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.1-x86_64.img
[2016-04-28 13:34] ==> Starting build: 4.1.23-1-MANJARO
[2016-04-28 13:34]   -> Running build hook: [base]
[2016-04-28 13:34]   -> Running build hook: [udev]
[2016-04-28 13:34]   -> Running build hook: [autodetect]
[2016-04-28 13:34]   -> Running build hook: [modconf]
[2016-04-28 13:34]   -> Running build hook: [block]
[2016-04-28 13:34]   -> Running build hook: [filesystems]
[2016-04-28 13:34]   -> Running build hook: [keyboard]
[2016-04-28 13:34]   -> Running build hook: [keymap]
[2016-04-28 13:34]   -> Running build hook: [fsck]
[2016-04-28 13:34]   -> Running build hook: [usr]
[2016-04-28 13:34]   -> Running build hook: [shutdown]
[2016-04-28 13:34] ==> Generating module dependencies
[2016-04-28 13:34] ==> Creating gzip-compressed initcpio image: /boot/initramfs-4.1-x86_64.img
[2016-04-28 13:34] ==> Image generation successful
[2016-04-28 13:34] ==> Building image from preset: /etc/mkinitcpio.d/linux41.preset: 'fallback'
[2016-04-28 13:34]   -> -k /boot/vmlinuz-4.1-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.1-x86_64-fallback.img -S autodetect
[2016-04-28 13:35]   -> Running build hook: [keyboard]
[2016-04-28 13:35]   -> Running build hook: [keymap]
[2016-04-28 13:35]   -> Running build hook: [fsck]
[2016-04-28 13:35]   -> Running build hook: [usr]
[2016-04-28 13:35]   -> Running build hook: [shutdown]
[2016-04-28 13:35] ==> Generating module dependencies
[2016-04-28 13:35] ==> Creating gzip-compressed initcpio image: /boot/initramfs-4.1-x86_64-fallback.img
[2016-04-28 13:35] ==> Image generation successful
[2016-04-28 13:35] Generating grub configuration file ...
[2016-04-28 13:35] Found background: /usr/share/grub/background.png
[2016-04-28 13:35] Found linux image: /boot/vmlinuz-4.1-x86_64
[2016-04-28 13:35] Found initrd image: /boot/initramfs-4.1-x86_64.img
[2016-04-28 13:35] Found initrd fallback image: /boot/initramfs-4.1-x86_64-fallback.img
[2016-04-28 13:35] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2016-04-28 13:35] done
[2016-04-28 13:35] Upgraded linux41 (4.1.15-1 -> 4.1.23-1)
[2016-04-28 13:35] Sourcing /etc/mhwd-x86_64.conf
[2016-04-28 13:35] Default lib32 support: false
[2016-04-28 13:35] xorg configuration symlink valid...
[2016-04-28 13:35] libGl and libglx symlinks valid...
[2016-04-28 13:35] ==> use mhwd-gpu to set catalyst as default: 'mhwd-gpu --setgl catalyst'
[2016-04-28 13:35] ==> use mhwd-gpu to set mesa as default: 'mhwd-gpu --setgl mesa'
[2016-04-28 13:35] Upgraded mhwd (0.5.6-7 -> 0.5.7-1)
[2016-04-28 13:35] Upgraded pixman (0.32.8-1 -> 0.34.0-1)
[2016-04-28 13:35] Upgraded pango (1.38.1-1 -> 1.40.1-1)
[2016-04-28 13:35] Upgraded librsvg (2:2.40.11-1 -> 2:2.40.15-1)
[2016-04-28 13:35] Upgraded adwaita-icon-theme (3.18.0-1 -> 3.20-1)
[2016-04-28 13:35] Upgraded alsa-lib (1.1.0-1 -> 1.1.1-1)
[2016-04-28 13:35] Upgraded alsa-plugins (1.1.0-1 -> 1.1.1-1)
[2016-04-28 13:35] Upgraded pciutils (3.3.1-1 -> 3.4.1-1)
[2016-04-28 13:35] Upgraded libsndfile (1.0.25-3 -> 1.0.26-1)
[2016-04-28 13:35] Upgraded alsa-utils (1.1.0-1 -> 1.1.1-1)
[2016-04-28 13:35] Upgraded libdbus (1.10.6-1 -> 1.10.8-1)
[2016-04-28 13:35] Installed dbus (1.10.8-1)
[2016-04-28 13:35] Upgraded inputproto (2.3.1-1 -> 2.3.2-1)
[2016-04-28 13:35] Upgraded at-spi2-core (2.18.3-1 -> 2.20.1-1)
[2016-04-28 13:35] Upgraded atk (2.18.0-1 -> 2.20.0-1)
[2016-04-28 13:35] Upgraded at-spi2-atk (2.18.1-1 -> 2.20.1-1)
[2016-04-28 13:35] Upgraded avahi (0.6.32rc-3 -> 0.6.32-2)
[2016-04-28 13:35] Upgraded binutils (2.25.1-3 -> 2.26-3)
[2016-04-28 13:35] Upgraded libical (1.0.1-2 -> 2.0.0-2)
[2016-04-28 13:35] Upgraded bluez (5.36-1.1 -> 5.39-1)
[2016-04-28 13:35] Upgraded bluez-libs (5.36-1.1 -> 5.39-1)
[2016-04-28 13:35] Upgraded libcups (2.1.2-3 -> 2.1.3-1)
[2016-04-28 13:35] Upgraded shared-mime-info (1.5-1 -> 1.6-1)
[2016-04-28 13:35] Upgraded libgusb (0.2.8-1 -> 0.2.9-1)
[2016-04-28 13:35] Upgraded dconf (0.24.0-1 -> 0.26.0-1)
[2016-04-28 13:35] Upgraded nspr (4.10.10-1 -> 4.12-1)
[2016-04-28 13:35] Upgraded colord (1.2.12-1 -> 1.3.2-1)
[2016-04-28 13:35] Upgraded xkeyboard-config (2.16-1 -> 2.17-2)
[2016-04-28 13:35] Upgraded libxkbcommon (0.5.0-1 -> 0.6.1-1)
[2016-04-28 13:35] Upgraded json-glib (1.0.4-1 -> 1.2.0-1)
[2016-04-28 13:35] Installed wayland-protocols (1.3-1)
[2016-04-28 13:35] Upgraded libproxy (0.4.11-8 -> 0.4.12-1)
[2016-04-28 13:35] Upgraded gsettings-desktop-schemas (3.18.1-1 -> 3.20.0-1)
[2016-04-28 13:35] Upgraded glib-networking (2.46.1-1 -> 2.48.0-1)
[2016-04-28 13:35] Upgraded libsoup (2.52.2-1 -> 2.54.0.1-1)
[2016-04-28 13:35] Upgraded gtk3 (3.18.6-1 -> 3.20.3-1)
[2016-04-28 13:35] Upgraded libnotify (0.7.6-1 -> 0.7.6-2)
[2016-04-28 13:35] Upgraded python-dbus-common (1.2.0-5 -> 1.2.4-1)
[2016-04-28 13:35] Upgraded python-dbus (1.2.0-5 -> 1.2.4-1)
[2016-04-28 13:35] Upgraded gobject-introspection-runtime (1.46.0-1 -> 1.48.0-1)
[2016-04-28 13:35] Upgraded pygobject-devel (3.18.2-1 -> 3.20.0-1)
[2016-04-28 13:35] Upgraded python-gobject (3.18.2-1 -> 3.20.0-1)
[2016-04-28 13:35] Upgraded blueman (2.0.2-1 -> 2.0.4-1)
[2016-04-28 13:35] Upgraded btrfs-progs (4.3.1-2 -> 4.5.1-1)
[2016-04-28 13:35] Upgraded cantarell-fonts (0.0.19-1 -> 1:0.0.24-1)
[2016-04-28 13:35] Upgraded python-ptyprocess (0.5-2 -> 0.5.1-1)
[2016-04-28 13:35] Upgraded xdg-utils (1.1.1-1 -> 1.1.1-2)
[2016-04-28 13:35] Upgraded catfish (1.3.3-3 -> 1.4.1-2)
[2016-04-28 13:35] Upgraded libevdev (1.4.5-1 -> 1.4.6-1)
[2016-04-28 13:35] Installed libwacom (0.18-1)
[2016-04-28 13:35] Upgraded libinput (1.1.4-1 -> 1.2.4-1)
[2016-04-28 13:35] Upgraded clutter (1.24.2-1 -> 1.26.0-1)
[2016-04-28 13:35] Upgraded clutter-gtk (1.6.6-1 -> 1.8.0-1)
[2016-04-28 13:35] Upgraded compton (0.1_beta2.r82.gd7f95b5-1 -> 0.1_beta2.5-2)
[2016-04-28 13:35] Upgraded consolekit (1.0.0-4 -> 1.1.0-6)
[2016-04-28 13:35] Upgraded cpupower (4.3-1 -> 4.5-2)
[2016-04-28 13:35] Upgraded device-mapper (2.02.137-1 -> 2.02.149-1)
[2016-04-28 13:35] Upgraded cryptsetup (1.7.0-1 -> 1.7.1-1)
[2016-04-28 13:35] Upgraded poppler (0.39.0-1 -> 0.42.0-1)
[2016-04-28 13:35] Upgraded ocl-icd (2.2.8-1 -> 2.2.9-1)
[2016-04-28 13:35] Upgraded imagemagick (6.9.2.6-3 -> 6.9.3.8-1)
[2016-04-28 13:35] Upgraded cups-filters (1.5.0-2 -> 1.8.3-2)
[2016-04-28 13:35] Upgraded run-parts (4.5.1-1 -> 4.7-1)
[2016-04-28 13:35] Upgraded cups (2.1.2-3 -> 2.1.3-1)
[2016-04-28 13:35] Upgraded dbus-glib (0.104-1 -> 0.106-1)
[2016-04-28 13:35] ==> run 'rc-update add dbus default'
[2016-04-28 13:35] Upgraded dbus-openrc (1.10.6-2 -> 20160322-1)
[2016-04-28 13:35] Upgraded dcadec (0.1.0-3 -> 0.2.0-1)
[2016-04-28 13:35] Upgraded dconf-editor (3.18.2-1 -> 3.20.1-1)
[2016-04-28 13:35] ==> run 'rc-update add device-mapper boot'
[2016-04-28 13:35] ==> run 'rc-update add dmeventd boot'
[2016-04-28 13:35] Upgraded device-mapper-openrc (20151020-1 -> 20160322-1)
[2016-04-28 13:35] Installed libmnl (1.0.3-2)
[2016-04-28 13:35] Installed libnftnl (1.0.5-1)
[2016-04-28 13:35] Upgraded iptables (1.4.21-3 -> 1.6.0-1)
[2016-04-28 13:35] Upgraded iproute2 (4.1.1-1 -> 4.5.0-2)
[2016-04-28 13:35] Upgraded dhclient (4.3.3-2 -> 4.3.4-1)
[2016-04-28 13:35] Upgraded dhcpcd (6.9.4-1 -> 6.10.2-1)
[2016-04-28 13:35] Upgraded downgrade (5.1.5-1 -> 5.2.3-1)
[2016-04-28 13:35] Upgraded nss (3.20.1-1 -> 3.23-3)
[2016-04-28 13:35] Upgraded ecryptfs-utils (108-1 -> 108-2)
[2016-04-28 13:35] Upgraded ethtool (1:4.2-1 -> 1:4.5-1)
[2016-04-28 13:35] Upgraded fuse (2.9.4-1 -> 2.9.5-1)
[2016-04-28 13:35] Upgraded exfat-utils (1.2.0-1 -> 1.2.3-2)
[2016-04-28 13:35] Upgraded f2fs-tools (1.4.1-1 -> 1.6.1-1)
[2016-04-28 13:35] Upgraded gsm (1.0.13-8 -> 1.0.14-1)
[2016-04-28 13:35] Upgraded libass (0.13.0-1 -> 0.13.2-1)
[2016-04-28 13:35] Upgraded libpulse (7.1-3 -> 8.0-3)
[2016-04-28 13:35] Upgraded libssh (0.7.2-1 -> 0.7.3-1)
[2016-04-28 13:35] Upgraded libva (1.6.2-1 -> 1.7.0-1)
[2016-04-28 13:35] Upgraded giflib (5.1.1-1 -> 5.1.2-1)
[2016-04-28 13:35] Upgraded libwebp (0.4.4-1 -> 0.5.0-1)
[2016-04-28 13:35] Upgraded opus (1.1.1-1 -> 1.1.2-1)
[2016-04-28 13:35] Upgraded v4l-utils (1.6.3-3 -> 1.10.0-1)
[2016-04-28 13:35] Upgraded libvpx (1.5.0-3 -> 1.5.0-4)
[2016-04-28 13:35] Upgraded libx264 (2:148.20150725-1 -> 2:148.20160103-1)
[2016-04-28 13:35] Upgraded x265 (1.8-3 -> 1.9-1)
[2016-04-28 13:35] Upgraded libraw1394 (2.1.1-1 -> 2.1.2-1)
[2016-04-28 13:35] Upgraded orc (0.4.24-1 -> 0.4.25-1)
[2016-04-28 13:35] Upgraded ffmpeg (1:2.8.4-1 -> 1:3.0.1-1)
[2016-04-28 13:35] Upgraded file (5.25-1 -> 5.26-1)
[2016-04-28 13:35] Upgraded gtk2 (2.24.29-1 -> 2.24.30-1)
[2016-04-28 13:35] Upgraded icu (56.1-2 -> 57.1-1)
[2016-04-28 13:35] Upgraded libevent (2.0.22-1 -> 2.0.22-2)
[2016-04-28 13:35] Upgraded hunspell (1.3.3-3 -> 1.3.4-1)
[2016-04-28 13:35] Upgraded ttf-dejavu (2.34-2 -> 2.35-1)
[2016-04-28 13:35] Updating font cache... done.
[2016-04-28 13:35] Upgraded ttf-liberation (2.00.1-5 -> 2.00.1-6)
[2016-04-28 13:35] Upgraded firefox (43.0.1-2 -> 45.0.2-1)
[2016-04-28 13:35] Upgraded flex (2.6.0-1 -> 2.6.0-2)
[2016-04-28 13:35] Upgraded gcc (5.3.0-3 -> 5.3.0-5)
[2016-04-28 13:35] Upgraded gcr (3.18.0-1 -> 3.20.0-1)
[2016-04-28 13:35] Upgraded gettext (0.19.6-2 -> 0.19.7-1)
[2016-04-28 13:35] Upgraded libsigc++ (2.6.2-1 -> 2.8.0-1)
[2016-04-28 13:35] Upgraded glibmm (2.46.3-1 -> 2.48.1-1)
[2016-04-28 13:35] Upgraded gnome-keyring (1:3.18.3-1 -> 1:3.20.0-1)
[2016-04-28 13:35] Upgraded gnome-themes-standard (3.18.0-1 -> 3.20-1)
[2016-04-28 13:35] Upgraded pangomm (2.38.1-2 -> 2.40.0-1)
[2016-04-28 13:35] Upgraded gparted (0.24.0-1.1 -> 0.25.0-1)
[2016-04-28 13:35] Upgraded groff (1.22.3-5 -> 1.22.3-6)
[2016-04-28 13:35] Upgraded grub (2.02.beta2-14 -> 2.02.beta2-15)
[2016-04-28 13:35] Upgraded gstreamer (1.6.2-1 -> 1.8.1-1)
[2016-04-28 13:35] Upgraded videoproto (2.3.2-1 -> 2.3.3-1)
[2016-04-28 13:35] Upgraded gst-plugins-base-libs (1.6.2-1 -> 1.8.1-1)
[2016-04-28 13:35] Upgraded gst-libav (1.6.2-1 -> 1.8.1-1)
[2016-04-28 13:35] Upgraded gst-plugins-base (1.6.2-1 -> 1.8.1-1)
[2016-04-28 13:35] Upgraded libshout (1:2.3.1-2 -> 1:2.4.1-2)
[2016-04-28 13:35] Upgraded imlib2 (1.4.7-1 -> 1.4.8-1)
[2016-04-28 13:35] Upgraded libcaca (0.99.beta18-3 -> 0.99.beta19-1)
[2016-04-28 13:35] Upgraded gst-plugins-good (1.6.2-1 -> 1.8.1-1)
[2016-04-28 13:35] Upgraded gtksourceview3 (3.18.1-1 -> 3.20.1-1)
[2016-04-28 13:35] Upgraded udisks2 (2.1.6-1 -> 2.1.7-1)
[2016-04-28 13:35] Upgraded libsecret (0.18.3-1 -> 0.18.5-1)
[2016-04-28 13:35] Upgraded gvfs (1.26.2-1 -> 1.28.1-1)
[2016-04-28 13:35] Upgraded libmtp (1.1.10-1 -> 1.1.11-1)
[2016-04-28 13:35] Upgraded gvfs-mtp (1.26.2-1 -> 1.28.1-1)
[2016-04-28 13:35] Upgraded libcanberra (0.30-5 -> 0.30-6)
[2016-04-28 13:35] Upgraded hexchat (2.10.2-4 -> 2.12.0-1)
[2016-04-28 13:35] Upgraded htop (1.0.3-3 -> 2.0.1-1)
[2016-04-28 13:35] Upgraded inxi (2.2.31-1 -> 2.2.38-1)
[2016-04-28 13:35] Upgraded iputils (20140519.fad11dc-1 -> 20160308.0db72a4-1)
[2016-04-28 13:35] Upgraded iso-codes (3.63-1 -> 3.67-1)
[2016-04-28 13:35] Upgraded libnl (3.2.26-1 -> 3.2.27-1)
[2016-04-28 13:35] Upgraded iw (4.1-1 -> 4.3-1)
[2016-04-28 13:35] Installed tslib (1.1-1)
[2016-04-28 13:35] Upgraded libxkbcommon-x11 (0.5.0-1 -> 0.6.1-1)
[2016-04-28 13:36] Upgraded qt5-base (5.5.1-6 -> 5.6.0-4)
[2016-04-28 13:36] Upgraded kitemmodels (5.17.0-1 -> 5.21.0-1)
[2016-04-28 13:36] Upgraded ldns (1.6.17-3 -> 1.6.17-4)
[2016-04-28 13:36] Upgraded libburn (1.4.2-1 -> 1.4.2.pl01-1)
[2016-04-28 13:36] Upgraded libgtop (2.32.0-1 -> 2.34.0-1)
[2016-04-28 13:36] Upgraded libimobiledevice (1.2.0-1 -> 1.2.0-3)
[2016-04-28 13:36] Upgraded libmbim (1.12.2-2 -> 1.12.4-1)
[2016-04-28 13:36] Upgraded libmm-glib (1.4.12-1 -> 1.4.14-1)
[2016-04-28 13:36] Upgraded libnewt (0.52.18-3 -> 0.52.19-1)
[2016-04-28 13:36] Upgraded libnm-glib (1.0.8-1 -> 1.0.12-1)
[2016-04-28 13:36] Upgraded libqmi (1.12.6-1 -> 1.12.10-1)
[2016-04-28 13:36] Upgraded libsodium (1.0.8-1 -> 1.0.10-1)
[2016-04-28 13:36] Upgraded zeromq (4.1.3-4 -> 4.1.4-1)
[2016-04-28 13:36] Upgraded libteam (1.22-1 -> 1.23-1)
[2016-04-28 13:36] Upgraded lightdm (1:1.16.6-2 -> 1:1.18.1-1)
[2016-04-28 13:36] Upgraded lightdm-gtk-greeter (1:2.0.1-2 -> 1:2.0.1-2.2)
[2016-04-28 13:36] Upgraded linux41-ndiswrapper (1.59-6 -> 1.59-13)
[2016-04-28 13:36] Upgraded linux41-virtualbox-guest-modules (5.0.12-1 -> 5.0.18-1)
[2016-04-28 13:36] Upgraded logrotate (3.9.1-1 -> 3.9.2-1)
[2016-04-28 13:36] Upgraded thin-provisioning-tools (0.5.6-2 -> 0.6.1-2)
[2016-04-28 13:36] Upgraded lvm2 (2.02.137-1 -> 2.02.149-1)
[2016-04-28 13:36] ==> run 'rc-update add lvm boot'
[2016-04-28 13:36] Upgraded lvm2-openrc (20151014-1 -> 20160322-1)
[2016-04-28 13:36] Upgraded lxappearance (0.6.1-1 -> 0.6.2-1)
[2016-04-28 13:36] Upgraded xorg-xrandr (1.4.3-1 -> 1.5.0-1)
[2016-04-28 13:36] Upgraded lxrandr (0.3.0-1 -> 0.3.1-1)
[2016-04-28 13:36] Upgraded make (4.1-1 -> 4.1-3)
[2016-04-28 13:36] Upgraded man-pages (4.03-1 -> 4.05-1)
[2016-04-28 13:36] Upgraded manjaro-firmware (20150723-2 -> 20160419-1)
[2016-04-28 13:36] Upgraded manjaro-settings-manager (0.4.13-1 -> 0.4.14-2)
[2016-04-28 13:36] Upgraded openssh (7.1p1-1 -> 7.2p2-1)
[2016-04-28 13:36] Upgraded rsync (3.1.1-4 -> 3.1.2-1)
[2016-04-28 13:36] Upgraded manjaro-tools-base (0.9.15-3 -> 0.11.5-2)
[2016-04-28 13:36] Upgraded mdadm (3.3.4-1 -> 3.4-1)
[2016-04-28 13:36] Upgraded menda-themes (20151217-1 -> 20160329-1)
[2016-04-28 13:36] Upgraded modemmanager (1.4.12-1 -> 1.4.14-1)
[2016-04-28 13:36] Upgraded python-distutils-extra (2.38-3 -> 2.39-1)
[2016-04-28 13:36] Upgraded mugshot (0.2.5-6 -> 0.3.0-5)
[2016-04-28 13:36] Upgraded nano (2.5.0-1 -> 2.5.3-1)
[2016-04-28 13:36] Upgraded nbd (3.12.1-1 -> 3.13-1)
[2016-04-28 13:36] Upgraded nm-connection-editor (1.0.8-1 -> 1.0.10-1)
[2016-04-28 13:36] Upgraded network-manager-applet (1.0.8-1 -> 1.0.10-1)
[2016-04-28 13:36] Upgraded wpa_supplicant (1:2.5-1 -> 1:2.5-3)
[2016-04-28 13:36] Upgraded networkmanager-consolekit (1.0.8-2 -> 1.0.12-1)
[2016-04-28 13:36] ==> run 'rc-update add NetworkManager default'
[2016-04-28 13:36] Upgraded networkmanager-openrc (20151014-1 -> 20160402-1)
[2016-04-28 13:36] Upgraded openvpn (2.3.9-1 -> 2.3.10-1)
[2016-04-28 13:36] Upgraded networkmanager-openvpn (1.0.8-1 -> 1.0.9-1)
[2016-04-28 13:36] Upgraded ntfs-3g (2015.3.14-1 -> 2016.2.22-1)
[2016-04-28 13:36] Upgraded ntp (4.2.8.p4-1 -> 4.2.8.p6-3)
[2016-04-28 13:36] Upgraded python2 (2.7.11-1 -> 2.7.11-3)
[2016-04-28 13:36] Upgraded openbox (3.6.1-2 -> 3.6.1-3)
[2016-04-28 13:36] Upgraded obmenu (1.0-10 -> 1.0-11)
[2016-04-28 13:36] Upgraded perl-uri (1.69-1 -> 1.71-1)
[2016-04-28 13:36] Upgraded orage (4.12.1-1 -> 4.12.1-2)
[2016-04-28 13:36] Upgraded package-query (1.7-1 -> 1.8-1)
[2016-04-28 13:36] Upgraded vte-common (0.42.1-1 -> 0.44.1-1)
[2016-04-28 13:36] Upgraded vte3 (0.42.1-1 -> 0.44.1-1)
[2016-04-28 13:36] gtk-update-icon-cache: Cache file created successfully.
[2016-04-28 13:36] ==> The polkit-gnome agent is no longer autostarted by default
[2016-04-28 13:36]     except in GNOME Flashback.
[2016-04-28 13:36]     For Xfce, LXDE etc., lxsession is the suggested lightweight alternative.
[2016-04-28 13:36]     See https://wiki.archlinux.org/index.php/Polkit#Authentication_agents
[2016-04-28 13:36]     for more details.
[2016-04-28 13:36] Upgraded pamac (2.4.3-3 -> 3.2.1-1)
[2016-04-28 13:36] Upgraded perl-data-dump (1.22-1 -> 1.23-1)
[2016-04-28 13:36] Upgraded pkg-config (0.29-1 -> 0.29.1-1)
[2016-04-28 13:36] Upgraded poppler-qt5 (0.39.0-1 -> 0.42.0-1)
[2016-04-28 13:36] Upgraded python-psutil (3.3.0-1 -> 4.1.0-1)
[2016-04-28 13:36] Upgraded python2-gobject (3.18.2-1 -> 3.20.0-1)
[2016-04-28 13:36] Upgraded qt5-svg (5.5.1-6 -> 5.6.0-1)
[2016-04-28 13:36] >>> The kernel-mode plugin has a new place.
[2016-04-28 13:36] >>> It's now located under /usr/lib/rp-pppoe/rp-pppoe.so
[2016-04-28 13:36] >>> Change LINUX_PLUGIN to the new path in your /etc/ppp/pppoe.conf
[2016-04-28 13:36] Upgraded rp-pppoe (3.11-7 -> 3.12-1)
[2016-04-28 13:36] Upgraded s-nail (14.8.5-1 -> 14.8.8-1)
[2016-04-28 13:36] Upgraded sudo (1.8.15-1 -> 1.8.16-1)
[2016-04-28 13:36]
[2016-04-28 13:36] ==> For setting up Syslinux BIOS using the syslinux-install_update script follow
[2016-04-28 13:36]     https://wiki.archlinux.org/index.php/Syslinux#Automatic_Install
[2016-04-28 13:36] Upgraded syslinux (6.03-3 -> 6.03-6)
[2016-04-28 13:36] Upgraded syslog-ng (3.6.3-1 -> 3.6.3-2)
[2016-04-28 13:36] Upgraded testdisk (7.0-2 -> 7.0-3)
[2016-04-28 13:36] Upgraded tint2 (0.12.3-1 -> 0.12.9-1)
[2016-04-28 13:36] Upgraded unrar (1:5.3.4-2 -> 1:5.3.11-1)
[2016-04-28 13:36] Upgraded unzip (6.0-11 -> 6.0-12)
[2016-04-28 13:36] Upgraded upower (0.99.3-1 -> 0.99.4-2)
[2016-04-28 13:36] Upgraded usb_modeswitch (2.2.6-1 -> 2.3.0-1)
[2016-04-28 13:36] Upgraded xf86-input-evdev (2.10.0-1 -> 2.10.1-1)
[2016-04-28 13:36] Upgraded virtualbox-guest-utils (5.0.12-0.1 -> 5.0.18-0.1)
[2016-04-28 13:36] Upgraded wget (1.17.1-0.1 -> 1.17.1-1)
[2016-04-28 13:36] Upgraded xarchiver (0.5.4-3 -> 0.5.4.6-1)
[2016-04-28 13:36] /tmp/alpm_26YwDS/.INSTALL: line 8: systemctl: command not found
[2016-04-28 13:36] Upgraded xdg-user-dirs (0.15-2 -> 0.15-4)
[2016-04-28 13:36] Upgraded xfce-theme-greenbird (20150412-1 -> 20150412-2)
[2016-04-28 13:36] Upgraded xfce4-whiskermenu-plugin (1.5.1-2 -> 1.5.3-1)
[2016-04-28 13:36] Upgraded xfsprogs (4.2.0-1 -> 4.3.0-1)
[2016-04-28 13:36] Upgraded xorg-xrdb (1.1.0-1 -> 1.1.0-2)
[2016-04-28 13:36] Upgraded xorg-xinit (1.3.4-3 -> 1.3.4-4)
[2016-04-28 13:36] Upgraded yaourt (1.7-1 -> 1.8.1-1)
[2016-04-28 13:36] Upgraded zip (3.0-6 -> 3.0-7)
[2016-04-28 13:38] Installed vim-runtime (7.4.1689-1)
[2016-04-28 13:38] Installed vim (7.4.1689-1)
« Last Edit: 28. April 2016, 12:35:24 by v17564 »
Offline aaditya
  • OpenRC Team
    • My Website
  • Branch: Testing
  • Desktop: Xfce, Openbox
  • GPU Card: Intel HD 4000
  • Kernel: Linux 4.4 x86_64
  • Skill: Intermediate
Re: LightDM does not start after 2016-04-26 Update
« Reply #5 on: 28. April 2016, 14:10:23 »
Hello @aaditya.
I follw the instrucctions but don't work.
- First install the theme with the command:
Code: [Select]
sudo pacman -S vertex-maia-themes vertex-maia-icon-theme xcursor-maiaThen I select the new icons theme to Vertex-maia and the style to Menda. After this I install the update but lightdm don't start and the error is the same of the previos post.
This is my complete pacman.log :
Code: [Select]
[2016-04-19 06:09] [PACMAN] Running 'pacman -Syy'
[2016-04-19 06:09] [PACMAN] synchronizing package lists
[2016-04-19 06:09] [PACMAN] Running 'pacman --noconfirm --cachedir /var/cache/pacman/pkg --config /opt/livecd/pacman-gfx.conf --root / --needed -Sy virtualbox-guest-utils linux44-virtualbox-guest-modules'
[2016-04-19 06:09] [ALPM] transaction started
[2016-04-19 06:09] [ALPM] installed linux44-virtualbox-guest-modules (5.0.16-8)
[2016-04-19 06:09] [ALPM-SCRIPTLET] ===> You may want to load vboxguest, vboxsf and vboxvideo
[2016-04-19 06:10] [ALPM] installed virtualbox-guest-utils (5.0.16-0.1)
[2016-04-19 06:10] [ALPM] transaction completed
[2016-04-19 13:07] [ALPM] transaction started
[2016-04-19 13:07] [ALPM] removed xarchiver (0.5.4-3)
[2016-04-19 13:07] [ALPM] removed orage (4.12.1-2)
[2016-04-19 13:07] [ALPM] installed p7zip (15.14.1-0.1)
[2016-04-19 13:07] [ALPM] installed bleachbit (1.10-1)
[2016-04-19 13:07] [ALPM] installed file-roller (3.16.4-1)
[2016-04-19 13:07] [ALPM] installed gamin (0.1.10-8)
[2016-04-19 13:07] [ALPM] installed medit (1.2.0-2)
[2016-04-19 13:07] [ALPM] installed tangerine-icon-theme (0.27-3)
[2016-04-19 13:07] [ALPM] installed human-icon-theme (0.36-4)
[2016-04-19 13:07] [ALPM] transaction completed
[2016-04-19 13:08] [ALPM] transaction started
[2016-04-19 13:08] [ALPM] installed ufw (0.34-1)
[2016-04-19 13:08] [ALPM] installed python2-netifaces (0.10.4-2)
[2016-04-19 13:08] [ALPM] installed libxslt (1.1.28-4)
[2016-04-19 13:08] [ALPM] installed aspell (0.60.6.1-4)
[2016-04-19 13:08] [ALPM-SCRIPTLET] ==> aspell comes with no default dictionary
[2016-04-19 13:08] [ALPM] installed hspell (1.3-1)
[2016-04-19 13:08] [ALPM] installed libvoikko (4.0.2-1)
[2016-04-19 13:08] [ALPM] installed enchant (1.6.0-7)
[2016-04-19 13:08] [ALPM] installed geoclue2 (2.4.3-1)
[2016-04-19 13:08] [ALPM] installed harfbuzz-icu (1.2.4-1)
[2016-04-19 13:08] [ALPM] installed webkitgtk (2.4.10-1)
[2016-04-19 13:08] [ALPM] installed gufw (15.10.0-1)
[2016-04-19 13:08] [ALPM] installed ufw-openrc (20151014-1)
[2016-04-19 13:08] [ALPM-SCRIPTLET] ==> run 'rc-update add ufw default'
[2016-04-19 13:08] [ALPM] transaction completed
[2016-04-19 13:20] [PACMAN] Running 'pacman --noconfirm --noprogressbar -Sy'
[2016-04-19 13:20] [PACMAN] synchronizing package lists
[2016-04-19 13:20] [PACMAN] starting full system upgrade
[2016-04-19 13:20] [PACMAN] Running 'pacman --noconfirm --noprogressbar -S firefox-i18n-en-us aspell-en hunspell-en vim-spell-en firefox-i18n-es-es aspell-es hunspell-es vim-spell-es'
[2016-04-19 13:20] [ALPM] transaction started
[2016-04-19 13:20] [ALPM] installed firefox-i18n-en-us (45.0.1-1)
[2016-04-19 13:20] [ALPM] installed aspell-en (2016.01.19-1)
[2016-04-19 13:20] [ALPM] installed hunspell-en (2016.01.19-1)
[2016-04-19 13:20] [ALPM] installed vim-spell-en (20120802-1)
[2016-04-19 13:20] [ALPM] installed firefox-i18n-es-es (45.0.1-1)
[2016-04-19 13:20] [ALPM] installed aspell-es (1.11-6)
[2016-04-19 13:20] [ALPM] installed hunspell-es (1:2.0-1)
[2016-04-19 13:20] [ALPM] installed vim-spell-es (20120802-1)
[2016-04-19 13:20] [ALPM] transaction completed
[2016-04-28 09:17] [PACMAN] Running 'pacman -S vertex-maia-themes vertex-maia-icon-theme xcursor-maia'
[2016-04-28 09:17] [ALPM] transaction started
[2016-04-28 09:17] [ALPM] installed vertex-maia-themes (20160425-1)
[2016-04-28 09:17] [ALPM-SCRIPTLET]
[2016-04-28 09:17] [ALPM-SCRIPTLET] ==> vertex-maia-themes:
[2016-04-28 09:17] [ALPM-SCRIPTLET]   -> For seamless integration of Firefox and Palemoon browsers
[2016-04-28 09:17] [ALPM-SCRIPTLET]   -> please copy the 'chrome' folder of the desired theme to your browser profile
[2016-04-28 09:17] [ALPM-SCRIPTLET]   -> or create a symlink.
[2016-04-28 09:17] [ALPM-SCRIPTLET] ==> For example:
[2016-04-28 09:17] [ALPM-SCRIPTLET]   -> 'ln -s /usr/share/themes/Palemoon/Vertex-Maia-Dark/chrome/ ~/.moonchild\ productions/pale\ moon/<xyz123>.default/chrome'
[2016-04-28 09:17] [ALPM] installed vertex-maia-icon-theme (20160421-1)
[2016-04-28 09:17] [ALPM] installed xcursor-maia (20160417-1)
[2016-04-28 09:17] [ALPM] transaction completed
[2016-04-28 09:36] [ALPM] transaction started
[2016-04-28 09:36] [ALPM] upgraded tzdata (2016c-1 -> 2016d-1)
[2016-04-28 09:36] [ALPM] upgraded glib2 (2.46.2-4 -> 2.48.0-1)
[2016-04-28 09:36] [ALPM] upgraded gtk-update-icon-cache (3.18.9-1 -> 3.20.3-1)
[2016-04-28 09:36] [ALPM] upgraded harfbuzz (1.2.4-1 -> 1.2.6-1)
[2016-04-28 09:36] [ALPM] upgraded fontconfig (2.11.94-1 -> 2.11.95-1)
[2016-04-28 09:36] [ALPM-SCRIPTLET] updating font cache... done.
[2016-04-28 09:36] [ALPM] upgraded libelf (0.165-1 -> 0.166-1)
[2016-04-28 09:36] [ALPM] upgraded elfutils (0.165-1 -> 0.166-1)
[2016-04-28 09:36] [ALPM] upgraded libgcrypt (1.6.5-1 -> 1.7.0-1)
[2016-04-28 09:36] [ALPM] upgraded libxml2 (2.9.3-1 -> 2.9.3+14+gd5bd2a9-1)
[2016-04-28 09:36] [ALPM] upgraded libutil-linux (2.27.1-1 -> 2.28-1)
[2016-04-28 09:36] [ALPM] upgraded cracklib (2.9.4-1 -> 2.9.6-1)
[2016-04-28 09:36] [ALPM] upgraded util-linux (2.27.1-1 -> 2.28-1)
[2016-04-28 09:36] [ALPM] upgraded mesa (11.1.2-1 -> 11.2.1-1)
[2016-04-28 09:36] [ALPM] upgraded mhwd-db (0.5.7-1 -> 0.5.7-4)
[2016-04-28 09:36] [ALPM] upgraded linux-firmware (20160113.40e9ae8-1 -> 20160315.deb1d83-1)
[2016-04-28 09:36] [ALPM] upgraded grep (2.24-1 -> 2.25-1)
[2016-04-28 09:36] [ALPM] upgraded gzip (1.6-1 -> 1.7-1)
[2016-04-28 09:36] [ALPM] upgraded linux44 (4.4.6-1 -> 4.4.8-1)
[2016-04-28 09:36] [ALPM-SCRIPTLET] >>> Updating module dependencies. Please wait ...
[2016-04-28 09:36] [ALPM-SCRIPTLET] >>> Generating initial ramdisk, using mkinitcpio.  Please wait...
[2016-04-28 09:36] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux44.preset: 'default'
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-4.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.4-x86_64.img
[2016-04-28 09:36] [ALPM-SCRIPTLET] ==> Starting build: 4.4.8-1-MANJARO
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Running build hook: [usr]
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Running build hook: [shutdown]
[2016-04-28 09:36] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2016-04-28 09:36] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-4.4-x86_64.img
[2016-04-28 09:36] [ALPM-SCRIPTLET] ==> Image generation successful
[2016-04-28 09:36] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux44.preset: 'fallback'
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-4.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.4-x86_64-fallback.img -S autodetect
[2016-04-28 09:36] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-4.4-x86_64-fallback.img
[2016-04-28 09:36] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2016-04-28 09:36] [ALPM-SCRIPTLET] Found background: /usr/share/grub/background.png
[2016-04-28 09:36] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-4.4-x86_64
[2016-04-28 09:36] [ALPM-SCRIPTLET] Found initrd image: /boot/initramfs-4.4-x86_64.img
[2016-04-28 09:36] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-4.4-x86_64-fallback.img
[2016-04-28 09:36] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2016-04-28 09:36] [ALPM-SCRIPTLET] done
[2016-04-28 09:36] [ALPM] upgraded archlinux-keyring (20160215-1 -> 20160402-1)
[2016-04-28 09:36] [ALPM-SCRIPTLET] ==> Appending keys from archlinux.gpg...
[2016-04-28 09:36] [ALPM-SCRIPTLET] gpg: marginals needed: 3  completes needed: 1  trust model: PGP
[2016-04-28 09:36] [ALPM-SCRIPTLET] gpg: depth: 0  valid:   1  signed:  16  trust: 0-, 0q, 0n, 0m, 0f, 1u
[2016-04-28 09:36] [ALPM-SCRIPTLET] gpg: depth: 1  valid:  16  signed:  66  trust: 0-, 0q, 0n, 16m, 0f, 0u
[2016-04-28 09:36] [ALPM-SCRIPTLET] gpg: depth: 2  valid:  66  signed:   7  trust: 66-, 0q, 0n, 0m, 0f, 0u
[2016-04-28 09:36] [ALPM-SCRIPTLET] gpg: next trustdb check due at 2016-10-19
[2016-04-28 09:36] [ALPM-SCRIPTLET] ==> Locally signing trusted keys in keyring...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Locally signing key 0E8B644079F599DFC1DDC3973348882F6AC6A4C2...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Locally signing key 684148BB25B49E986A4944C55184252D824B18E8...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Locally signing key 91FFE0700E80619CEB73235CA88E23E377514E00...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Locally signing key 44D4A033AC140143927397D47EFD567D4C7EA887...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Locally signing key 27FFC4769E19F096D41D9265A04F9397CDFD6BB0...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Locally signing key AB19265E5D7D20687D303246BA1DFB64FFF979E7...
[2016-04-28 09:36] [ALPM-SCRIPTLET] ==> Importing owner trust values...
[2016-04-28 09:36] [ALPM-SCRIPTLET] ==> Disabling revoked keys in keyring...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Disabling key F5A361A3A13554B85E57DDDAAF7EF7873CFD4BB6...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Disabling key 7FA647CD89891DEDC060287BB9113D1ED21E1A55...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Disabling key D4DE5ABDE2A7287644EAC7E36D1A9E70E19DAA50...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Disabling key BC1FBE4D2826A0B51E47ED62E2539214C6C11350...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Disabling key 9515D8A8EAB88E49BB65EDBCE6B456CAF15447D5...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Disabling key 4A8B17E20B88ACA61860009B5CED81B7C2E5C0D2...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Disabling key 63F395DE2D6398BBE458F281F2DBB4931985A992...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Disabling key 0B20CA1931F5DA3A70D0F8D2EA6836E1AB441196...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Disabling key 8F76BEEA0289F9E1D3E229C05F946DED983D4366...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Disabling key 66BD74A036D522F51DD70A3C7F2A16726521E06D...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Disabling key 81D7F8241DB38BC759C80FCE3A726C6170E80477...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Disabling key E7210A59715F6940CF9A4E36A001876699AD6E84...
[2016-04-28 09:36] [ALPM-SCRIPTLET] ==> Updating trust database...
[2016-04-28 09:36] [ALPM] upgraded manjaro-keyring (20160302-2 -> 20160416-1)
[2016-04-28 09:36] [ALPM-SCRIPTLET] ==> Appending keys from manjaro.gpg...
[2016-04-28 09:36] [ALPM-SCRIPTLET] gpg: depth: 1  valid:  16  signed:  67  trust: 0-, 0q, 0n, 16m, 0f, 0u
[2016-04-28 09:36] [ALPM-SCRIPTLET] gpg: depth: 2  valid:  67  signed:   7  trust: 67-, 0q, 0n, 0m, 0f, 0u
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Locally signing key 7C89F4D439B2BFACF425107B62443D89B35859F8...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Locally signing key 22C903DE964E6FE321656E318DB9F8C18DF53602...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Locally signing key 16DC688DF3EECC72323954237EC47C82A42D53A2...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Locally signing key 5A97ED6B72418199F0C22B23137C934B5DCB998E...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Locally signing key B4663188A692DB1E45A98EE95BD96CC4247B52CC...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Locally signing key 35B4FF23EA9477582C2A0AF12B80869C5C0102A6...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Locally signing key 1E7908935AAB9A00D6B47503363DFFFD59152F77...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Locally signing key 77DC01C9971AC3C39A0626F72C089F09AC97B894...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Locally signing key 74C2F2CC05A0AB7D859839938934292D604F8BA2...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Locally signing key 39F0EC1AE50B37E5F3196F09DAD3B211663CA268...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Locally signing key E4CDFE50A2DA85D58C8A8C70CAA6A59611C7F07E...
[2016-04-28 09:36] [ALPM-SCRIPTLET] gpg: setting ownertrust to 4
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Disabling key FAA6840E8C3FC7F89BEE0DC8AC7AB10BCB6CDD17...
[2016-04-28 09:36] [ALPM-SCRIPTLET]   -> Disabling key 540DE7083B89314CF70EA6F0C1B1AD0DA80EBF3E...
[2016-04-28 09:36] [ALPM-SCRIPTLET] gpg: depth: 0  valid:   1  signed:  17  trust: 0-, 0q, 0n, 0m, 0f, 1u
[2016-04-28 09:36] [ALPM-SCRIPTLET] gpg: depth: 1  valid:  17  signed:  66  trust: 0-, 0q, 0n, 17m, 0f, 0u
[2016-04-28 09:36] [ALPM] upgraded pacman-mirrorlist (20160404-1 -> 20160423-1)
[2016-04-28 09:36] [ALPM-SCRIPTLET] :: Querying servers, this may take some time...
[2016-04-28 09:37] [ALPM-SCRIPTLET] :: Generated and saved '/etc/pacman.d/mirrorlist' mirrorlist.
[2016-04-28 09:37] [ALPM-SCRIPTLET] hint: use `pacman-mirrors` to generate and update your pacman mirrorlist.
[2016-04-28 09:37] [ALPM] upgraded libtasn1 (4.7-1 -> 4.8-1)
[2016-04-28 09:37] [ALPM] upgraded sqlite (3.12.0-1 -> 3.12.2-1)
[2016-04-28 09:37] [ALPM] upgraded gnutls (3.4.10-1 -> 3.4.11-1)
[2016-04-28 09:37] [ALPM] upgraded pango (1.39.0-1 -> 1.40.1-1)
[2016-04-28 09:37] [ALPM] upgraded adwaita-icon-theme (3.18.0-1 -> 3.20-1)
[2016-04-28 09:37] [ALPM] upgraded at-spi2-core (2.18.3-1 -> 2.20.1-1)
[2016-04-28 09:37] [ALPM] upgraded atk (2.18.0-1 -> 2.20.0-1)
[2016-04-28 09:37] [ALPM] upgraded at-spi2-atk (2.18.1-1 -> 2.20.1-1)
[2016-04-28 09:37] [ALPM] upgraded btrfs-progs (4.4.1-1 -> 4.5.1-1)
[2016-04-28 09:37] [ALPM] upgraded shared-mime-info (1.5-1 -> 1.6-1)
[2016-04-28 09:37] [ALPM] upgraded dconf (0.24.0-1 -> 0.26.0-1)
[2016-04-28 09:37] [ALPM] upgraded colord (1.2.12-1 -> 1.3.2-1)
[2016-04-28 09:37] [ALPM] upgraded libxkbcommon (0.6.0-1 -> 0.6.1-1)
[2016-04-28 09:37] [ALPM] upgraded json-glib (1.0.4-1 -> 1.2.0-1)
[2016-04-28 09:37] [ALPM] installed wayland-protocols (1.3-1)
[2016-04-28 09:37] [ALPM] upgraded gsettings-desktop-schemas (3.18.1-1 -> 3.20.0-1)
[2016-04-28 09:37] [ALPM] upgraded glib-networking (2.46.1-1 -> 2.48.0-1)
[2016-04-28 09:37] [ALPM] upgraded libsoup (2.52.2-1 -> 2.54.0.1-1)
[2016-04-28 09:37] [ALPM] upgraded gtk3 (3.18.9-1 -> 3.20.3-1)
[2016-04-28 09:37] [ALPM] upgraded libinput (1.2.2-1 -> 1.2.4-1)
[2016-04-28 09:37] [ALPM] upgraded clutter (1.24.2-1 -> 1.26.0-1)
[2016-04-28 09:37] [ALPM] upgraded clutter-gtk (1.6.6-1 -> 1.8.0-1)
[2016-04-28 09:37] [ALPM] upgraded consolekit (1.1.0-3 -> 1.1.0-6)
[2016-04-28 09:37] [ALPM] upgraded cpupower (4.5-1 -> 4.5-2)
[2016-04-28 09:37] [ALPM] upgraded poppler (0.41.0-1 -> 0.42.0-1)
[2016-04-28 09:37] [ALPM] upgraded ocl-icd (2.2.8-1 -> 2.2.9-1)
[2016-04-28 09:37] [ALPM] upgraded imagemagick (6.9.3.7-1 -> 6.9.3.8-1)
[2016-04-28 09:37] [ALPM] upgraded cups-filters (1.8.3-1 -> 1.8.3-2)
[2016-04-28 09:37] [ALPM] upgraded dconf-editor (3.18.2-1 -> 3.20.1-1)
[2016-04-28 09:37] [ALPM] upgraded device-mapper (2.02.148-1 -> 2.02.149-1)
[2016-04-28 09:37] [ALPM] upgraded dhcpcd (6.10.1-1 -> 6.10.2-1)
[2016-04-28 09:37] [ALPM] upgraded ethtool (1:4.2-1 -> 1:4.5-1)
[2016-04-28 09:37] [ALPM] upgraded f2fs-tools (1.6.0-1 -> 1.6.1-1)
[2016-04-28 09:37] [ALPM] upgraded file (5.25-1 -> 5.26-1)
[2016-04-28 09:37] [ALPM] upgraded unzip (6.0-11 -> 6.0-12)
[2016-04-28 09:37] [ALPM] upgraded file-roller (3.16.4-1 -> 3.20.1-1)
[2016-04-28 09:37] [ALPM] upgraded icu (56.1-2 -> 57.1-1)
[2016-04-28 09:37] [ALPM] upgraded libraw1394 (2.1.1-1 -> 2.1.2-1)
[2016-04-28 09:38] [ALPM] upgraded firefox (45.0.1-1 -> 45.0.2-1)
[2016-04-28 09:38] [ALPM] upgraded firefox-i18n-en-us (45.0.1-1 -> 45.0.2-1)
[2016-04-28 09:38] [ALPM] upgraded firefox-i18n-es-es (45.0.1-1 -> 45.0.2-1)
[2016-04-28 09:38] [ALPM] upgraded gcr (3.18.0-1 -> 3.20.0-1)
[2016-04-28 09:38] [ALPM] upgraded glibmm (2.46.3-1 -> 2.48.1-1)
[2016-04-28 09:38] [ALPM] upgraded gnome-keyring (1:3.18.3-1 -> 1:3.20.0-1)
[2016-04-28 09:38] [ALPM] upgraded gnome-themes-standard (3.18.0-1 -> 3.20-1)
[2016-04-28 09:38] [ALPM] upgraded gobject-introspection-runtime (1.46.0-1 -> 1.48.0-1)
[2016-04-28 09:38] [ALPM] upgraded gstreamer (1.6.3-1 -> 1.8.1-1)
[2016-04-28 09:38] [ALPM] upgraded gst-plugins-base-libs (1.6.3-1 -> 1.8.1-1)
[2016-04-28 09:38] [ALPM] upgraded gst-libav (1.6.3-3 -> 1.8.1-1)
[2016-04-28 09:38] [ALPM] upgraded gst-plugins-base (1.6.3-1 -> 1.8.1-1)
[2016-04-28 09:38] [ALPM] upgraded imlib2 (1.4.7-1 -> 1.4.8-1)
[2016-04-28 09:38] [ALPM] upgraded gst-plugins-good (1.6.3-1 -> 1.8.1-1)
[2016-04-28 09:38] [ALPM] upgraded gtksourceview3 (3.18.2-1 -> 3.20.1-1)
[2016-04-28 09:38] [ALPM] upgraded gvfs (1.26.3-1 -> 1.28.1-1)
[2016-04-28 09:38] [ALPM] upgraded gvfs-mtp (1.26.3-1 -> 1.28.1-1)
[2016-04-28 09:38] [ALPM] upgraded harfbuzz-icu (1.2.4-1 -> 1.2.6-1)
[2016-04-28 09:38] [ALPM] upgraded inxi (2.2.36-1 -> 2.2.38-1)
[2016-04-28 09:38] [ALPM] installed libmnl (1.0.3-2)
[2016-04-28 09:38] [ALPM] installed libnftnl (1.0.5-1)
[2016-04-28 09:38] [ALPM] upgraded iptables (1.4.21-3 -> 1.6.0-1)
[2016-04-28 09:38] [ALPM] upgraded iproute2 (4.4.0-1 -> 4.5.0-2)
[2016-04-28 09:38] [ALPM] upgraded iputils (20150815.1c59920-3 -> 20160308.0db72a4-1)
[2016-04-28 09:38] [ALPM] upgraded libxkbcommon-x11 (0.6.0-1 -> 0.6.1-1)
[2016-04-28 09:38] [ALPM] upgraded qt5-base (5.6.0-2 -> 5.6.0-4)
[2016-04-28 09:38] [ALPM] upgraded kitemmodels (5.20.0-1 -> 5.21.0-1)
[2016-04-28 09:38] [ALPM] upgraded libcanberra (0.30-5 -> 0.30-6)
[2016-04-28 09:38] [ALPM] upgraded libgtop (2.32.0-1 -> 2.34.0-1)
[2016-04-28 09:38] [ALPM] upgraded libqmi (1.12.8-1 -> 1.12.10-1)
[2016-04-28 09:38] [ALPM] upgraded lightdm (1:1.18.0-1 -> 1:1.18.1-1)
[2016-04-28 09:38] [ALPM] upgraded linux44-ndiswrapper (1.59-7 -> 1.59-9)
[2016-04-28 09:38] [ALPM] upgraded linux44-virtualbox-guest-modules (5.0.16-8 -> 5.0.18-1)
[2016-04-28 09:38] [ALPM] upgraded logrotate (3.9.1-1 -> 3.9.2-1)
[2016-04-28 09:38] [ALPM] upgraded lvm2 (2.02.148-1 -> 2.02.149-1)
[2016-04-28 09:38] [ALPM] upgraded manjaro-firmware (20160117-1 -> 20160419-1)
[2016-04-28 09:38] [ALPM] upgraded manjaro-settings-manager (0.4.14-1 -> 0.4.14-2)
[2016-04-28 09:38] [ALPM] upgraded pangomm (2.38.1-2 -> 2.40.0-1)
[2016-04-28 09:38] [ALPM] upgraded poppler-qt5 (0.41.0-1 -> 0.42.0-1)
[2016-04-28 09:38] [ALPM] upgraded pygobject-devel (3.18.2-1 -> 3.20.0-1)
[2016-04-28 09:38] [ALPM] upgraded python-gobject (3.18.2-1 -> 3.20.0-1)
[2016-04-28 09:38] [ALPM] upgraded python2-gobject (3.18.2-1 -> 3.20.0-1)
[2016-04-28 09:38] [ALPM] upgraded syslinux (6.03-5 -> 6.03-6)
[2016-04-28 09:38] [ALPM-SCRIPTLET]
[2016-04-28 09:38] [ALPM-SCRIPTLET] ==> For setting up Syslinux BIOS using the syslinux-install_update script follow
[2016-04-28 09:38] [ALPM-SCRIPTLET]     https://wiki.archlinux.org/index.php/Syslinux#Automatic_Install
[2016-04-28 09:38] [ALPM] upgraded tint2 (0.12.8-1 -> 0.12.9-1)
[2016-04-28 09:38] [ALPM] warning: /usr/lib/ufw/user6.rules saved as /usr/lib/ufw/user6.rules.pacsave
[2016-04-28 09:38] [ALPM] warning: /usr/lib/ufw/user.rules saved as /usr/lib/ufw/user.rules.pacsave
[2016-04-28 09:38] [ALPM] upgraded ufw (0.34-1 -> 0.35-1)
[2016-04-28 09:38] [ALPM] upgraded vim-spell-en (20120802-1 -> 20150901-1)
[2016-04-28 09:38] [ALPM] upgraded vim-spell-es (20120802-1 -> 20150901-1)
[2016-04-28 09:38] [ALPM] upgraded virtualbox-guest-utils (5.0.16-0.1 -> 5.0.18-0.1)
[2016-04-28 09:38] [ALPM] upgraded vte-common (0.42.5-1 -> 0.44.1-1)
[2016-04-28 09:38] [ALPM] upgraded vte3 (0.42.5-1 -> 0.44.1-1)
[2016-04-28 09:38] [ALPM] upgraded webkitgtk (2.4.10-1 -> 2.4.11-1)
[2016-04-28 09:38] [ALPM] upgraded xdg-user-dirs (0.15-2 -> 0.15-4)
[2016-04-28 09:38] [ALPM-SCRIPTLET] /tmp/alpm_4ZMuGH/.INSTALL: line 8: systemctl: command not found
[2016-04-28 09:38] [ALPM] upgraded xdg-utils (1.1.1-1 -> 1.1.1-2)
[2016-04-28 09:38] [ALPM] upgraded xfce-theme-greenbird (20150412-1 -> 20150412-2)
[2016-04-28 09:38] [ALPM] upgraded xfce4-whiskermenu-plugin (1.5.2-1 -> 1.5.3-1)
[2016-04-28 09:38] [ALPM] transaction completed
It was the gtk theme that needed to be changed, not the icon theme.
Offline thrasymachus
  • Neuling
  • I'm new. Be nice!
  • Desktop: Awesome WM
« Reply #6 on: 28. April 2016, 17:01:15 »
yes, that's what I changed, with the line
Code: [Select]
theme-name = Vertex-Maia in /etc/lightdm/lightdm-gtk-greeter.conf.  But that produced no change in the problem.
Offline curiouseag
  • Sr. Mitglied
  • I'm new. Be nice!
  • Branch: stable
  • Desktop: undicieded
  • GPU Card: Intel Core i3-5010U
  • GPU driver: Intel
  • Kernel: grsec self build
  • Skill: Advanced
« Reply #7 on: 28. April 2016, 17:37:56 »
I have openrc and I changed the theme. It works for me.
Offline Holmes
  • Mirror Support Team
  • Brazilian and Hispanic Support Team
    • Manjaro Brasil
  • Branch: Stable
  • Desktop: Manjaro XFCE
  • GPU Card: Mobile Intel (R) 945
  • GPU driver: Non-free
  • Kernel: kernellinux
  • Skill: Novice
« Reply #8 on: 28. April 2016, 19:34:29 »
hi all,
here'm also this with problem with LightDM of the Manjaro JWM OpenRC, see image:
that chaos is updated...
vlw fwi, Holmes :)
==> Manjaro Brasil I Manjaro Hispano
==> IRC Manjaro Brasil: #manjaro-br I IRC Manjaro Hispano: #manjaro-es
Offline v17564
  • Vollwertiges Mitglied
  • I'm new. Be nice!
  • Skill: Novice
« Reply #9 on: 28. April 2016, 19:49:36 »
Hello.
What iso version are you using? To me with the system installed last summer with the iso 0.8.13 also works, but does not work with the iso 15.12 and 16.03 .
hi all,
vlw fwi, Holmes :)
Sorry but: what image is that we have to see? A black box? we have already seen it.  :D
@aaditya.
The following attempts haven't worked:
- I change the theme manually in /etc/lightdm/lightdm-gtk-greeter.conf
- I install the package lightdm-gtk-greeter-settings and run it with this result:
Code: [Select]
# cat /etc/lightdm/lightdm-gtk-greeter.conf
[greeter]
background = /usr/share/backgrounds/Madera_Manjaro-FrankoM3.png
font-name = Droid Sans 11
active-monitor = #cursor
icon-theme-name = Vertex-Maia
and also don't change the icon-theme-name to Vertex-Maia.
- I configure the system with autologin and without autologin.
- I activate the "rc_verbose=yes" but OpenRC don't write anything in the file /var/log/rc.log after update and reboot.
- After update and reboot, the file everything.log remains unchangeable, there is no entry of log in the file ???.
- In the subdirectory /var/log/lightdm there isn't logs
Quote
[manjaro lightdm]# ls -la
total 68
drwx--x--x 2 root lightdm  4096 abr 28 20:02 .
drwxr-xr-x 7 root root     4096 abr 28 20:02 ..
-rw------- 1 root root        0 abr 28 20:02 lightdm.log
-rw------- 1 root root     5860 abr 28 20:01 lightdm.log.old
-rw------- 1 root root    42448 abr 28 19:45 x-0-greeter.log
-rw------- 1 root root     1988 abr 28 17:04 x-0-greeter.log.old
-rw------- 1 root root        0 abr 28 20:02 x-0.log
-rw------- 1 root root     1015 abr 28 20:01 x-0.log.old
Finally, I do not find any log that could help to solve the problem.
« Last Edit: 28. April 2016, 19:59:56 by v17564 »
Offline Holmes
    • Manjaro Brasil
  • Branch: Stable
  • Skill: Novice
« Reply #10 on: 28. April 2016, 19:58:50 »
@v17564,
it does not appear, but the cursor is blinking. i remember this image when i made the first iso jwm openrc with lxdm.i think it has to do with the lightdm.
vlw fwi, Holmes :)
« Last Edit: 28. April 2016, 20:00:27 by Holmes »
Offline v17564
  • I'm new. Be nice!
  • Skill: Novice
« Reply #11 on: 28. April 2016, 20:05:57 »
@v17564,
it does not appear, but the cursor is blinking. i think it has to do with the lightdm.
vlw fwi, Holmes :)
@Holmes
I understand the first time, i put it only for a joke ;)
lightdm don't start and only appear a black screen with a blinking cursor.
By the way, I just updated my second home computer installed with the iso 0.8.13 and has worked all to the first.
Offline curiouseag
  • Sr. Mitglied
  • I'm new. Be nice!
  • Branch: stable
  • GPU driver: Intel
  • Skill: Advanced
« Reply #12 on: 28. April 2016, 20:21:53 »
Hello.
good question, I think I used xfce openrc iso the latest one.
I read about the problems and did not reboot for a day but finally my battery died. Had no problem login in. But my lightdm "redraws" after load. Something is wrong. But I can login
  • Neuling
  • I'm new. Be nice!
« Reply #13 on: 28. April 2016, 23:25:18 »
I am working off of either 15.09 or 15.12, I am not sure.  And xdm is still crashing, even after changing the lightdm theme to Vertex-Maia
« Last Edit: 28. April 2016, 23:29:20 by thrasymachus »
Offline xircon
  • Held Mitglied
  • Branch: Unstable
  • Desktop: Plasma
  • GPU Card: Intel 4th gen
  • GPU driver: free
  • Kernel: Always the newest!
  • Skill: Advanced
« Reply #14 on: 29. April 2016, 00:54:19 »
Change to sddm it is qt based...................
