Author Topic: [Daniella] Third preview release  (Read 6437 times)
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • Desktop: i3, Deepin, Cinnamon
  • GPU Card: Intel ValleyView Gen7
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
  • Skill: Intermediate
Re: [Daniella] Third preview release
« Reply #15 on: 28. April 2016, 16:43:09 »
Ok. good you solved it like that for now. What I meant was to install linux41 because that one doesn't amdgpu in the first place ;) It was meant as an emergency measure ;) Your workaround makes certainly more sense! ;D
manjaro is addictive ::)
* manjaro-i3  * manjaro-cinnamon  * manjaro-deepin
Offline zzz
  • Vollwertiges Mitglied
  • Skill: Novice
« Reply #16 on: 28. April 2016, 17:45:38 »
This release for kernel 4.4.8-1 appears to have the most stable non-free catalyst driver (linux44-catalyst  1:15.201.1151-9).
« Last Edit: 28. April 2016, 17:48:36 by zzz »
Offline stephane
  • Neuling
  • I'm new. Be nice!
  • Branch: Stable
  • Desktop: 16.06.1 Xfce ( mac) & 16.06.1 ( pc)
  • GPU Card: ATI 5770 Mac & Geforce 970GTX ( pc)
  • GPU driver: Free Driver & non Free Driver
  • Kernel: Linux 4.6.2 (mac) - Linux 4.6.2 (pc)
  • Skill: Novice
« Reply #17 on: 28. April 2016, 19:19:34 »
skylake ( z170 )  + Nvidia Free drivers , same error  ( ok with non free drivers)
and check also libdrm version
http://www.phoronix.com/scan.php?page=news_item&px=Skylake-Missing-IDs-Libdrm
« Last Edit: 29. April 2016, 17:30:59 by stephane »
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • GPU driver: non-free
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
« Reply #18 on: 28. April 2016, 19:48:07 »
amdgpu has experimental support for sea island. its a good thing that manjaro makes it possible to test this, but it should not be the default :D
post me the output of mhwd. Check also this. I got a bug report regarding this on our mailing list. Therefore I enabled it also for these cards.
But if you say it is broken on your end, it makes not so much sense. Also try to add following kernel parameter before booting, so we can see if you get a valid picture: amdgpu.exp_hw_support=1.
« Last Edit: 28. April 2016, 19:50:25 by philm »
Offline Strangiato
  • Neuling
  • Branch: Testing
  • Desktop: Plasma 5
  • GPU Card: Radeon HD 4350
  • GPU driver: Open source driver
  • Kernel: 3.18.2
  • Skill: Novice
« Reply #19 on: 29. April 2016, 00:57:47 »
bugs in kde edition:
screen tearing with intel hd 4000
printscreen keyboard key does not work to take screenshots
Offline elav
  • Jr. Mitglied
  • SystemInside.net
    • SystemInside
  • Branch: Unstable
  • Desktop: Plasma
  • GPU Card: Intel
  • GPU driver: SNA
  • Kernel: linux43-x64
  • Skill: Novice
« Reply #20 on: 29. April 2016, 02:42:53 »
My problem remains the same. When I turn on the computer for the first time, I put my password in SDDM, the screen is frozen. I have to go to a TTY, and then back to the graphical session. However, I close the session, I restart my password and no problem loading the desktop.
Firefox still looks awful :(
SystemInside - www.systeminside.net
Offline zzz
  • Skill: Novice
« Reply #21 on: 29. April 2016, 07:09:38 »
Just updated machine with AMD A-Series APU from k4.1.16-1 to k4.1.23-1
OS boots faster.
Video is stable and responsive even with window maximized. CPU temperature does ramp-up initially (and with jumping to different video time or launching different app) but heat is removed by the heat sink quickly. Not sure how a stock heat sink would fare as the stock heat sink is half the size of the one being used.
Then upgraded kernel to 4.4.8-1.
Catalyst non-free driver delivers stable and responsive video with temperature ramp-up initially.
So far OK.
« Last Edit: 29. April 2016, 07:53:43 by zzz »
Offline alpargyenge
  • Neuling
  • Branch: Stable
  • Desktop: Cinnamon
  • GPU Card: Geforce 9600Gt
  • GPU driver: free
  • Kernel: 3.8
  • Skill: Novice
« Reply #22 on: 29. April 2016, 07:12:41 »
Kde version run great with amd non free driver
Offline Tids
  • Jr. Mitglied
  • Rawr :3
    • Telegram
  • Desktop: Plasma
  • GPU Card: Radeon R7 (APU AMD A8-760)
  • GPU driver: free
  • Kernel: x86_64
« Reply #23 on: 29. April 2016, 12:06:02 »
this line wont change anything... however i've figured out how it will work:
first we need a newer version of "linux-firmware" (i've tried it with master, so this will work for sure) (i'm not sure how important this actually is)
secound we need to blacklist "radeon" /etc/modprobe.d/blacklist-radeon.conf
Code: [Select]
blacklist radeonnote: THIS IS IMPORTANT - otherwise the kernel will load the radeonsi driver instead of amdgpu and XOrg amdgpu ddx wont work with radeonsi, so x can not start
third just to be sure, load amdgpu /etc/modules-load.d/mhwd-gpu.conf
Code: [Select]
## Generated by mhwd - Manjaro Hardware Detection
amdgpu
and of course
Code: [Select]
mkinitcpio -p linux46 #or whatever your kernel is
now a restart and amdgpu will work.
Manjaro б(>ε<)∂ Telegram - Steam - Hatchet
Offline zzz
  • Skill: Novice
« Reply #24 on: 29. April 2016, 13:47:53 »
Code: [Select]
Code: [Select]
amdgpu
and of course
Code: [Select]
1. Please explain the difference between radeons and amdgpu.
Both of my machines are using radeons: Radeon HD 6450 and Radeon HD 8470D
2. If the manjaro installer defaults to amdgpu, how would someone with radeons install non-free catalyst drivers?
« Last Edit: 29. April 2016, 13:58:59 by zzz »
Offline Tids
  • Jr. Mitglied
  • Rawr :3
    • Telegram
  • Desktop: Plasma
  • GPU driver: free
  • Kernel: x86_64
« Reply #25 on: 29. April 2016, 15:36:22 »
amdgpu is the next generation graphicsdriver. its the only one that will have features like vulkan somewhere in the future.
Quote
lets hope its not possible anymore cause manjaro finally shipps with xorg 1.18 or 1.19. catalyst is EOL, because it wont support xorg 1.8 anymore. they now build a new "pro" driver that is based on amdgpu. so if you need pro features, you'll need a newer graphicscard.
and just to say this once more ..... for sea island manjaro needs to use "radeon" by default. amdgpu is *not* an option for them, its experimental.
« Last Edit: 29. April 2016, 15:38:20 by Tids »
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #26 on: 29. April 2016, 21:54:47 »
So I should remove the IDs from amdgpu for now for these cards? Please comment also here.
Code: [Select]
The affected PCI IDs are 0x6900, 0x6901, 0x6902, 0x6903, and 0x6907 for the Topaz/Iceland GPUs that are marked as experimental.
« Last Edit: 29. April 2016, 21:56:38 by philm »
Offline Antwone
  • Neuling
  • I'm new. Be nice!
  • Branch: Unstable
  • Desktop: KDE
  • GPU Card: Radeon
  • Kernel: 4.4
« Reply #27 on: 30. April 2016, 08:35:25 »
I tried Manjaro KDE 16.06 Pre 3 64-bit running non-free.  Notes:
1.  In the live environment, everything was in the Maia color scheme expect the title bars (they were light blue).
2.  (Random) The last install of Manjaro I did with Thus created a swap equal to my RAM (5.3GB).  Calamares in this version created a slightly larger swap at 8.8 GB.  I never noticed the two installers create different size swap paritions.
3.  4.4 kernel was extremely sluggish loading the desktop.  At one point the screen was black and a white rectange appeared where the welcome window appears.
4.  4.4 was also sluggish shutting down.
5.  I tried installing kernel 3.18 through kernel system settings.  The command finishes "done" but did not install the kernel.  I installed it through Octopi.
Feature request:  I'd like to see an option during install to choose the default kernel you want to install.  If I already know which kernel is going to work for me, I'd like to start with it.
Offline fabdo
    • fabdo.net
  • Branch: stable
  • Desktop: Xfce
  • GPU Card: NVIDIA GTX 750
  • GPU driver: Dual core AMD Phenom II X2 550
  • Kernel: 4.4.8
« Reply #28 on: 30. April 2016, 09:45:28 »
it works by me without a problem: the installation with thus and the normal workflow!
thanks!!!
Desktop: Xfce, 64bit, NVIDIA, nonfree, linux448 (testing)
Laptop: Xfce, 64bit, ATI, free, linux448 (stable)
http://fabdo.net
Offline Gr3gor3uo
  • Neuling
  • I'm new. Be nice!
  • Branch: Stable
  • Desktop: Xfce 16.06
  • GPU Card: nVidia GTX 970
  • GPU driver: Non-free driver
  • Kernel: linux4.4.8-1-x64
  • Skill: Novice
« Reply #29 on: 30. April 2016, 12:31:22 »
Hi Manjaro Team
Thank you for the best Linux experience! 3rd Review release runs butter smooth and no issues!  :)
Kind Regards
Stephen
