Poll
Did you experience any issue with this update?
No issues, everything went smoothly.
132 (62.9%)
Yes there was an issue. I was able to resolve it myself. (Please post your solution)
30 (14.3%)
Yes I am currently experiencing an issue due to the update. (Please post about it)
48 (22.9%)
Total Members Voted: 210
Author Topic: [Update] 2016-04-26 - Cinnamon 3.0, Pamac, Gnome 3.20, KDE, Virtualbox  (Read 28216 times)
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • Desktop: i3, Deepin, Cinnamon
  • GPU Card: Intel ValleyView Gen7
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
  • Skill: Intermediate
Yes, confirming that. The scrollbar issue in Firefox is only party solved in the original Vertex theme. So there's hope that once this is properly fixed it will also work for light...
manjaro is addictive ::)
* manjaro-i3  * manjaro-cinnamon  * manjaro-deepin
Offline minjaro
  • Neuling
  • Branch: stable
  • Desktop: the legendary fluxbox (openrc edition)
  • GPU Card: Intel 945 GM
  • GPU driver: i915
  • Kernel: 4.4.5-1 x86
well... just thought I'd chime in and get in on all the action, how could anyone resist right? first off, I'd like to thank this thread for thoroughly scaring the pooh out of me. in the end this update was really harmless for me. it gave me a chance to switch up some stylistic elements & minimize my system's installed packages. awesome keyboard-shortcut-fix for palemoon, yay! loving the vertex theme. thanks gang... for the clear caveats and the seething edge progression. you're the man... jaro!
Offline sbaragnaus
  • Jr. Mitglied
  • Branch: Stable
  • Desktop: Kde
  • GPU Card: Intel HD Graphics 530
  • GPU driver: free
  • Kernel: x64
After this update Nixnote won't start anymore.
Code: [Select]
$ nixnote2
nixnote2: error while loading shared libraries: libopencv_core.so.2.4: cannot open shared object file: No such file or directory
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
nixote is an AUR package. You should maybe rebuild it when there are library errors.
Also make sure that you have opencv installed - maybe reinstall that one...
Offline Fekete
  • Neuling
  • Branch: stable
  • Desktop: LXDE+Awesome
  • GPU Card: Nvidia GT 740
  • GPU driver: proprietary
  • Kernel: 4.4.5-1-MANJARO x86_64
  • Skill: Novice
Ever since I installed this update tuxguitar won't start anymore. It just hangs on the splash screen consuming 100% from one core forever. Doesn't output any errors into the terminal or any log I know of either, so I don't really have a clue about what's happening.
Nevertheless I'm highly suspicious it's due to the latest JRE update. I'll probably try and downgrade it later, even though I know I probably shouldn't.
Offline emmedi
  • Neuling
  • I'm new. Be nice!
  • Branch: stable
  • Desktop: KDE
  • GPU Card: RS780D [Radeon HD 3300]
  • GPU driver: free
  • Skill: Novice
KShisen stopped working. Solutions?
Code: [Select]
[emmedi@pc ~]$ kshisen
connect(2) call to /dev/shm/jack-1000/default/jack_0 failed (err=File o directory non esistente)
attempt to connect to server failed
log_libkmahjongg: Using background at "/usr/share/kmahjongglib/backgrounds/default.svg"
terminate called after throwing an instance of 'std::out_of_range'
  what():  vector::_M_range_check: __n (which is 0) >= this->size() (which is 0)
KCrash: Application 'kshisen' crashing...
KCrash: Attempting to start /usr/lib/drkonqi from kdeinit
sock_file=/run/user/1000/kdeinit5__0
pa_write() failed while trying to wake up the mainloop: Descrittore di file errato
Invalid write to eventfd: Descrittore di file errato
Code should not be reached at pulsecore/fdsem.c:199, function pa_fdsem_post(). Aborting.
Unable to start Dr. Konqi
Offline Adr1an
  • Vollwertiges Mitglied
  • Kudos to the Devs
  • Branch: Stable
  • Desktop: Gnome-LightDM
  • GPU Card: AMD/ATI
  • GPU driver: Free
  • Kernel: 344 LTS
Little update on themes: I had to switch from Numix Frost to standard Numix, that's all :)
Win7 & Manjaro Gnome dual boot; 2011 Dell Studio 15; Intel Core i5 M450 @ 2.40GHz × 4; 4GB RAM; AMD ATI Mobility Radeon HD 5400 series
Offline koukourikos
  • Jr. Mitglied
  • Branch: stable
  • Desktop: Xfce
  • GPU Card: Intel 3000
  • GPU driver: free
  • Kernel: 4.1 x86_64
  • Skill: Novice
In case that you do not like Vertex-Maia or you want to try something else, with GTK 3.20 support, there is also the Arc theme.
https://github.com/horst3180/Arc-theme
available via pacman:
Code: [Select]
arc-themes
Offline aaditya
  • OpenRC Team
    • My Website
  • Branch: Testing
  • Desktop: Xfce, Openbox
  • GPU Card: Intel HD 4000
  • Kernel: Linux 4.4 x86_64
1st post
following post
This virtual machine is a replica of my laptop, and I don't want to update the latter because others had this issue on a non-vm as well.
Can anyone from the team at least say if this is going to be solved in the next update?
Hi,
Yup, X seems broken under virtualbox currently (at least on OpenRC).
https://forum.manjaro.org/index.php?topic=33422.0;
Most people have reported that it works on bare metal.
Offline Heart Of A Lion
  • Sr. Mitglied
  • I'm new. Be nice!
  • Branch: Stable
  • Desktop: Xfce, Enlightenment
  • GPU Card: ATi 7770 . . . . . . . CPU: AMD octacore 4GHz
  • GPU driver: Free (video-ATI)
  • Kernel: 4.6 (x64)
Code: [Select]
arc-themes
Thanks.
Offline Monro
  • Neuling
  • Monro of Fyrish coat of arms
  • Branch: stable
  • Desktop: OpenBOx
  • Skill: Novice
Hi,
I also have Arch vm, and X broke there too.
As for the bare metal, you're probably right, but I prefer to be on the safe side. There was one guy who reported trouble on regular laptop, so, I'll wait for the next update to see.
Offline Adr1an
  • Kudos to the Devs
  • Branch: Stable
  • GPU Card: AMD/ATI
  • GPU driver: Free
  • Kernel: 344 LTS
Numix Frost (in AUR) was just updated, and it seems all works fine now.
Offline Hypnoglow
  • Neuling
  • I'm new. Be nice!
I can also confirm that X is broken for my VirtualBox Manjaro.
I have tried a fresh install on a new VirtualBox machine, and after I updated my packages, I'm still getting this error.
UPD:
For anyone interested: solution is here https://forum.manjaro.org/index.php?topic=33422.45
« Last Edit: 10. May 2016, 09:54:36 by Hypnoglow »
